BlackHole Vu+ Duo 1.6.6
For your 1st Q?
Its part of the skin coding...so if the skinner choose tp put it he can do, make a request @ Skins section and wait for reply!
For 2nd Q?
Try to make Epg back up, make settings @ BH menu to store the data @USB or HDD!
When ever U reboot your STB, the data may be lost,,,so U can bring back for the data storage!
RgdZ
a911
A911 thanks for the suggestion to the skin section, i'll do that :).
For the EPG loss, I'll try changing the settings, but I think I have the automatic backup turned on,
Do I still need to do the restore manually or does it load automatically when the data is lost. ( My guess would be, to have to do it manually).[/quote]
I do things manually....and do not like plugins to enforce data or any info on my BH image!
The EPG Backup @ menu will make automatic back and store data @USB or other media of your choice!
The EPG Backup @ menu will make automatic back and store data @USB or other media of your choice![/quote]
* Ok , yes I figured also that it's best to control everything yourself. And I also realized that sometimes it needs a " Forced Conversion epg.dat" after an update, because otherwise it seems that some data is not showing,
I got that especially with the Spanish channels (D+). A reload was not enough.
Well thanks again for the precious help :) !
