BlackHole Vu+ Duo 1.6.6
At this time, drivers are fully compatible with current BH image and there is not needs to repack all image for this update.
I need a plugin gst-plugin-faad. I need it because I do not have sound files recorded phone samsung galaxy SII. So I need gst-plugin-faad. Please urgent help.
I've found this IPKs related to Faad but I cannot test it.
I installed without a problem this file libfaad0_2.0-r2_mipsel.ipk but the second file: faad2_2.0-r2_mipsel.ipk can not be installed. As a result, I still do not sound files recorded on samsung galaxy SII. Please urgent help.
What error is reported when you try to install faad2 ipk?
I wanted to ask how tests fared? When drivers become available so I can play files recorded phone samsung galaxy SII. Image plays perfectly but still I have no sound. Please urgent help.
I haven't tested your file.
I will do some tests ASAP.
SAT (and Vu) for me are HOBBY, not WORK.
I have problems with my USB tuner AF-9015 in BH 6.6. A lot of bitmapping. After going back to BH 6.1 no problems with this tuner. Strange is that I restore the drivers used with Personal backup, same results, lot of bitmapping in BH6.6.
It looks like a driver problem, will post in the driver forum
I"ve tested the V. File ( the length of 2 sec.....:grin:) and my findings as follow:-
1-Used 2 media plugins players : Media Center & Media Center Extended.
2-Pictures plays fine!
3-No Sound.
4-The plugin identified the file format as .mp4.
5- File plays ok in my PC : Picture & Sound!
So do I need a file patch or a plugin that can read .m4 Audio .....:confused:?
RgdZ
a911
Hi, First things first ! Thank you very much for this great image, i've tried many until now, but i think this is the most stable one and also a lot of good features. Great Work !!
Although, I was wondering if there is any way to get, in the channel list, like in the VTI image, the amount of time that the programs have been going on : in percentage.
I don't know if i made myself clear ... :-/ . In the VIX image this is shown as a bar, as well as in the plugin cool tv guide : "cool easy guide".
Thank you for help and suggestions.
Hi, I installed BH 1.6.6 today. Everything is OK Except HDMI CEC doesn't initialize with my TV RC ( Samsung 46 C8000) . after manual starting, ( 2 x blue >BH HDMI cec >red) it works fine. While it was working with BH 1.6.4 perfectly before . Any help?
You can have this also in BH:
Menu -> Setup -> System -> Customize -> Show Event Progress in Channle List = yes
Thank you very much !! :), that was very helpful. I have my nice bars, showing how far the movies/events are. Any chance to get this into percentage ?
By the way a little thing about EPG, how come it disappears totally sometimes. I have to do a "forced reload" in Cross EPG,
I also get this problem when it updating on rytec servers (i did a server update before) I have seleted 6 in the list.
While updating, enigma restarts, and everything I had listed until that, is gone.
I don't have that when I do it manually one by one, really weird, I've read that some people experience the same kind of problems.
Anybody can do a flawless EPG update that lasts until the next update ?
Thanks again for the help and advice :).
I love this image, it works GREAT
CHeers guys
[quote="babelina, post: 35167" .I have my nice bars, showing how far the movies/events are. Any chance to get this into percentage ?
CHeers guys[/quote]
For your 1st Q?
Its part of the skin coding...so if the skinner choose tp put it he can do, make a request @ Skins section and wait for reply!
For 2nd Q?
Try to make Epg back up, make settings @ BH menu to store the data @USB or HDD!
When ever U reboot your STB, the data may be lost,,,so U can bring back for the data storage!
RgdZ
a911
CHeers guys
For your 1st Q?
For 2nd Q?
RgdZ
a911[/quote]
A911 thanks for the suggestion to the skin section, i'll do that :).
For the EPG loss, I'll try changing the settings, but I think I have the automatic backup turned on,
Do I still need to do the restore manually or does it load automaticaly when the data is lost. ( My guess would be, to have to do it manually).
