BlackHole Vu+ Duo 1.6.6
When you are watching a recording and you try to put a timer for recording the box crashes!
Here my interpretation of your crashlogs:
1318813787: your box doesen't have a stable Internet connection and the box cannot get a complete output from the BH Addon Server or the server was in maintenance mode for a little period of time.
1320013209: do you use PIP? Disable it :)
1320015257: uhm this is strange. The error was into Timer Panel but I don't know where is the problem :(
1318813787: i find no reason is an Operating System to crash if it doesnt have a stable internet connection :)
1320013209: Never used PIP and never try to enable it and also i dont know how to enable it or disable it so please help me out to check, thanks
1320015257: The problem lies in the code because is a BUG, maybe :P
1320015257: The problem lies in the code because is a BUG, maybe :p
1318813787: OS? The GUI is not a part of Operating System but it's an external package. I think this crashlog appear when the Addon Server is in maintenance mode.
1320013209: Ok.
1320015257: if it's a BUG some people should report this. If you are the only one... it's not a bug, but we investigate in any case :)
Hi masters of the 1.66 software is changing TV resolution image u is the blue screen is a second, I wonder why such a short period of time was a year after the end of the previous image imagen birisindede it did not have a problem until the bole vti, aaf imagelerdede doing just wonder does not imagen pleat Thank you very imagen answer is that the webbrowser
R U using BH (Original, from image server) skins,,,,or other modified ones!
As I understood from U'r post ,that U have added timer for a program, then when it turns (automatically 2record) while U'r watching a recording, the STB crashes,,,is this whats happening....:confused:?
I will do testing, after few hours for verification, (I am far from my toy, right now,,,:cool:)!
RgdZ
a911
Nop...Every Things Check fine,,:thumbup:,,,No crashes what so ever!
Hi,
You got it wrong.
Here it is what you have to do:
Play a recording from hdd, as you play it try to put a timer (recording) while your recording still plays, crash! :)
I have a problem with meoboot. The intalled Images on USB ( VTI, Cubic, AAF Summer, Powerboard; - all last image), WIFI no run. WIFI-Stick out and in, then is run !!
Hi guys I need to make a question about the card readers (if this is not allowed pleaser remove the post)
I have an issue with previous versions to 1.6.5 the image used to show configuration options for 2 readers and 2 CI slots but now it only shows for 1 Reader.
do you have any idea why? at the moment I don't have any card inserted, but I would like start testing with my tntsat (original card) Just for viewing nothing unlawfull.
Thanks in advance.
Hi,
You got it wrong.
Ok fine!
But how U can put a timer , while U'r playing a recordings...:confused:!
Love 2know how?
I do not think meoboot has any thing 2do with that!
Thanks in advance.
TNTSat is a Via4/5 card. It's a CA not natively supported into Vu+ card readers.
angelofsky1980 Thanks for your answer you save me a lot of time messing arround with that tntsat card.
however I'm still have one doubt wich you might be able to answer.
the thing is that on -the blue panel- it sais 1 CAM installed when it used to say 2 CAM as the vu+duo has 2 readers.
I have checked the messages and it looks like both of the readers are recognized sci0 and sci1.
could you explain why is that I can only see one. and if it is normal.
thanks.
here you have an extract of my messages log. (sorry for the big log).
Jan  1 01:01:04 bm750 user.info kernel: input: dreambox remote control (native) as /class/input/input0
Jan  1 01:01:04 bm750 user.info kernel: [LCD]: registered
Jan  1 01:01:04 bm750 user.err kernel: ^[[0;35m[CI]:^[[0;0m-BM750_PCB_2_1
Jan  1 01:01:04 bm750 user.info kernel: [CI]: registered ci0
Jan  1 01:01:04 bm750 user.info kernel: [CI]: registered ci1
Jan  1 01:01:04 bm750 user.info kernel: [DFP]: registered dbox fp
Jan  1 01:01:04 bm750 user.err kernel: [DFP]: bcm7335_i2c_write: Error 1114113
Jan  1 01:01:04 bm750 user.err kernel: [DFP]: bcm7335_max_i2c_write: Error 1114113
Jan  1 01:01:04 bm750 user.info kernel: [DFP]: Scart 4707 is found 4
Jan  1 01:01:04 bm750 user.info kernel: [SC]: registered sci0
Jan  1 01:01:04 bm750 user.info kernel: [SC]: registered sci1
Jan  1 01:01:04 bm750 user.warn kernel: system_time_set wakeup mode get
Jan  1 01:01:04 bm750 user.warn kernel: system_time_set wakeup mode get 0xc4
Jan  1 01:01:13 bm750 user.warn kernel: [CI]:ci_dev_open
Jan  1 01:01:13 bm750 user.warn kernel: [CI]:Opening A GPIO's for 7335 platform
Jan  1 01:01:13 bm750 user.warn kernel: [CI]:Opening A GPIO's for 7335 platform....done
Jan  1 01:01:13 bm750 user.warn kernel: [CI]:entering.. A NEXUS_DvbCi_Open
Jan  1 01:01:13 bm750 user.warn kernel: [CI]:NEXUS_DvbCi_Open done..
Jan  1 01:01:13 bm750 user.warn kernel: [CI]:Installing callbacks
Jan  1 01:01:13 bm750 user.warn kernel: [CI]:Forcing card check
Jan  1 01:01:13 bm750 user.warn kernel: [CI]:Card insertion status changed
Jan  1 01:01:13 bm750 user.warn kernel: [CI]:Opening B GPIO's for 7335 platform
Jan  1 01:01:13 bm750 user.warn kernel: [CI]:Opening B GPIO's for 7335 platform....done
Jan  1 01:01:13 bm750 user.warn kernel: [CI]:entering.. B NEXUS_DvbCi_Open
Jan  1 01:01:13 bm750 user.warn kernel: [CI]:Card B insertion status changed
Jan  1 01:01:13 bm750 user.info kernel: [CI]: CI interface initialised
Jan  1 01:01:13 bm750 user.warn kernel: [CI]:ci1_dev_open
Jan  1 01:01:13 bm750 user.warn kernel: [CI]:NEXUS_Remux_Start
Jan  1 01:01:13 bm750 user.warn kernel: [CI]:>>close_mpod tuner:0
Jan  1 01:01:13 bm750 user.warn kernel: [CI]:remux stop
Jan  1 01:01:13 bm750 user.warn kernel: [CI]:get_remux_startcnt() count : 1
Jan  1 01:01:13 bm750 user.warn kernel: [CI]:>>close_mpod tuner:1
Jan  1 01:01:13 bm750 user.warn kernel: [CI]:get_remux_startcnt() count : 0
thanks.
SCIs devices are internal readers.
About CI I've made some tests with older CI CAMs but I haven't an answer ATM to your answer :(
I'm confused. (may be I should read more) ;-)
the vu+duo has 4 let's say places to put cards.
2 two wich are already ready to insert a card. and another 2 to insert the CI CAM modules (the one like pcmcia)
is there any other option? inside the deco?
I have always thought that sci were the slot to insert the card directly and the ci where the one for the PCMCIA.
I thought that the blue panel was about the sci the place where you can insert a card directly.
I will have to read more. to find out what kind of things I can do with this awesome hardware.
Ok now the question is more clear :)
You can use (natively) into Vu+ HW 2 Conax cards into internal readers and use 2 CI CAMs into CAM slots. These 2 CAMs can be used to use other CAs like Viaccess, Irdeto, Cryptoworks, etc in accordance to your PayTV provider card and the corresponding CI CAM :)
Thanks, Just changed from a DM800 to VU+ Duo and this image is fantastic.
A question regarding skins, when in EPG bouquets which skin gives a now/next program detail when scrolling down on channels such as in the modified version of DM concinnity for my old DM800.
If I understood your post correctly....all skins @BH image server can do this!
As an example, see how at the bottom right hand side of this screen we get to to see what is next for that channel. Which skin for BH VU= Duo will show that.
