BlackHole Vu+ Duo 1.6.6
It seems that there is a problem with the virtual keyboard in Web Browser in samo of the skins. For example Army Gradient. I press the yellow button, but nothing happens. Such problem doen't exist in the default skin.
i have a problem with virtual keyboard in default skin
tonight i will try with mmark skin and my favourite army smoke
How i can config Duo to switch to recording channel, now it doesnt and is recording blanks.
Default skin updated.
Thank you
Thank you
That is strange.
Check tuner setting and try in menu, system, personal settings, expert mode, set yes in recording has priority, it should be the second menu you have.
I've had to switch back to BlackHole 1.6.5 because BlackHole crashes when I attempt to play dvds.
It's gibberish to me but here's the crash log for those who know more.
<?xml version="1.0" encoding="utf-8"?>
<opendreambox>
<enigma2>
<crashdate>Sat Oct 22 19:09:36 2011</crashdate>
<compiledate>Oct 12 2011</compiledate>
<contactemail>crashlog</contactemail>
<skin>skin.xml</skin>
<sourcedate>Oct 12 2011</sourcedate>
<branch>vuplus_experimental</branch>
<rev></rev>
<version></version>
</enigma2>
<image>
<dreamboxmodel>dm500hd</dreamboxmodel>
<kernelcmdline>rootfstype=jffs2 root=/dev/mtdblock0 rw mem=0x8000000 bcmrac=3 console=ttyS0,115200</kernelcmdline>
<imageversion>
<![CDATA[
version=1000201110121508
comment=Vuplus
target=9
creator=OpenEmbedded <oe@vuplus.com>
url=http://www.vuplus.com/
catalog=http://www.vuplus.com/
</imageversion>
<imageissue>
<![CDATA[
Vuplus 2.1.0 + BlackHole 1.6.6 %h
</imageissue>
</image>
<software>
<enigma2software>
<![CDATA[
enigma2 - experimental-git20110922-r0
enigma2-defaultservices - 1.0-r5
enigma2-drivers-meta - 1.0-r0
enigma2-meta - experimental-git20110922-r0
enigma2-plugin-extensions-cutlisteditor - experimental-git20110922-r0
enigma2-plugin-extensions-dvdplayer - experimental-git20110922-r0
enigma2-plugin-extensions-graphmultiepg - experimental-git20110922-r0
enigma2-plugin-extensions-mediaplayer - experimental-git20110922-r0
enigma2-plugin-extensions-mediascanner - experimental-git20110922-r0
enigma2-plugin-extensions-mytube - experimental-git20110215-r3
enigma2-plugin-extensions-pictureplayer - experimental-git20110922-r0
enigma2-plugin-extensions-webbrowser - experimental-git20110922-r0
enigma2-plugin-extensions-webinterface - experimental-git20110215-r3
enigma2-plugin-systemplugins-autoresolution - experimental-git20110215-r3
enigma2-plugin-systemplugins-commoninterfaceassignment - experimental-git20110922-r0
enigma2-plugin-systemplugins-factorytest - experimental-git20110922-r0
enigma2-plugin-systemplugins-fancontrol - experimental-git20110922-r0
enigma2-plugin-systemplugins-hotplug - experimental-git20110922-r0
enigma2-plugin-systemplugins-networkbrowser - experimental-git20110215-r3
enigma2-plugin-systemplugins-networkwizard - experimental-git20110922-r0
enigma2-plugin-systemplugins-positionersetup - experimental-git20110922-r0
enigma2-plugin-systemplugins-satfinder - experimental-git20110922-r0
enigma2-plugin-systemplugins-skinselector - experimental-git20110922-r0
enigma2-plugin-systemplugins-softwaremanager - experimental-git20110922-r0
enigma2-plugin-systemplugins-ui3dsetup - experimental-git20110922-r0
enigma2-plugin-systemplugins-uipositionsetup - experimental-git20110922-r0
enigma2-plugin-systemplugins-videoenhancement - experimental-git20110922-r0
enigma2-plugin-systemplugins-videomode - experimental-git20110922-r0
enigma2-plugin-systemplugins-videotune - experimental-git20110922-r0
enigma2-plugin-systemplugins-wirelesslan - experimental-git20110922-r0
enigma2-plugins-meta - experimental-git20110215-r3
enigma2-skins-meta - experimental-git20110128-r0
enigma2-streamproxy - 1.0cvs20101014-r0
task-vuplus-enigma2 - 1.0-r8
</enigma2software>
<dreamboxsoftware>
<![CDATA[
libdreamdvd0 - 0.10+git20110129-r0
</dreamboxsoftware>
<gstreamersoftware>
<![CDATA[
gst-plugin-alsa - 0.10.35-r0.0
gst-plugin-apetag - 0.10.30-r0.0
gst-plugin-app - 0.10.35-r0.0
gst-plugin-audioconvert - 0.10.35-r0.0
gst-plugin-audioparsers - 0.10.30-r0.0
gst-plugin-audioresample - 0.10.35-r0.0
gst-plugin-autodetect - 0.10.30-r0.0
gst-plugin-avi - 0.10.30-r0.0
gst-plugin-cdio - 0.10.18-r0.0
gst-plugin-cdxaparse - 0.10.22-r0.1
gst-plugin-decodebin - 0.10.35-r0.0
gst-plugin-decodebin2 - 0.10.35-r0.0
gst-plugin-dvbmediasink - 0.10+git20110210-r1
gst-plugin-dvdsub - 0.10.18-r0.0
gst-plugin-flac - 0.10.30-r0.0
gst-plugin-flv - 0.10.30-r0.0
gst-plugin-icydemux - 0.10.30-r0.0
gst-plugin-id3demux - 0.10.30-r0.0
gst-plugin-isomp4 - 0.10.30-r0.0
gst-plugin-mad - 0.10.18-r0.0
gst-plugin-matroska - 0.10.30-r0.0
gst-plugin-mpegaudioparse - 0.10.18-r0.0
gst-plugin-mpegdemux - 0.10.22-r0.1
gst-plugin-mpegstream - 0.10.18-r0.0
gst-plugin-ogg - 0.10.35-r0.0
gst-plugin-playbin - 0.10.35-r0.0
gst-plugin-rtp - 0.10.30-r0.0
gst-plugin-rtpmanager - 0.10.30-r0.0
gst-plugin-rtsp - 0.10.30-r0.0
gst-plugin-souphttpsrc - 0.10.30-r0.0
gst-plugin-subparse - 0.10.35-r0.0
gst-plugin-typefindfunctions - 0.10.35-r0.0
gst-plugin-udp - 0.10.30-r0.0
gst-plugin-vcdsrc - 0.10.22-r0.1
gst-plugin-vorbis - 0.10.35-r0.0
gst-plugin-wavparse - 0.10.30-r0.0
gstreamer - 0.10.35-r0
libgstapp-0.10-0 - 0.10.35-r0.0
libgstaudio-0.10-0 - 0.10.35-r0.0
libgstcdda-0.10-0 - 0.10.35-r0.0
libgstinterfaces-0.10-0 - 0.10.35-r0.0
libgstnetbuffer-0.10-0 - 0.10.35-r0.0
libgstpbutils-0.10-0 - 0.10.35-r0.0
libgstriff-0.10-0 - 0.10.35-r0.0
libgstrtp-0.10-0 - 0.10.35-r0.0
libgstrtsp-0.10-0 - 0.10.35-r0.0
libgstsdp-0.10-0 - 0.10.35-r0.0
libgsttag-0.10-0 - 0.10.35-r0.0
libgstvideo-0.10-0 - 0.10.35-r0.0
</gstreamersoftware>
</software>
<crashlogs>
<enigma2crashlog>
<![CDATA[
t 0x19d2770>)
action -> SetupActions ok
nim 0
is compatible with DVB-S
add sat transponder
Add Sat: frequ: 10818 symbol: 22000 pol: 1 fec: 0 inversion: 2 modulation: 1 system: 0 rolloff0 pilot2
orbpos: 282
stopService
allocating new converter!
reused converter!
reused converter!
ServiceScanCreateSummary
opening frontend 0
allocate demux
resolve: resolve ${sysconfdir}/scan_tp_valid_check.py
resolve: -> /etc/scan_tp_valid_check.py
(0)tune
RotorCmd ffffffff, lastRotorCmd ffffffff
prepare_sat System 0 Freq 10818000 Pol 1 SR 22000000 INV 2 FEC 0 orbpos 282 system 0 modulation 1 pilot 2, rolloff 0
tuning to 1068 mhz
OURSTATE: tuning
[SEC] set static current limiting
[SEC] invalidate current switch params
[SEC] setVoltage 1
[SEC] sleep 10ms
set sequence pos 3
[SEC] update current switch params
[SEC] startTuneTimeout 5000
[SEC] setFrontend 1
setting frontend 0
[SEC] sleep 500ms
(0)fe event: status 0, inversion off, m_tuning 1
(0)fe event: status 1f, inversion off, m_tuning 2
OURSTATE: ok
no version filtering
0000: 00 00 00 00 00 00
mask: ff 00 00 00 00 00
mode: 00 00 00 00 00 00
+ 1/1 TID 00
done!
got pat
got pmt -2
0102: 02 28 71 00 00 00
mask: ff ff ff 00 00 00
0011: 42 08 00 00 00 00
mask: fb ff ff 00 00 00
+ 1/1 TID 02
done!
got pmt 0
0103: 02 28 72 00 00 00
[SEC] set dynamic current limiting
+ 1/1 TID 02
done!
got pmt 0
0104: 02 28 73 00 00 00
+ 1/1 TID 02
done!
got pmt 0
0105: 02 28 74 00 00 00
+ 1/1 TID 02
done!
got pmt 0
0114: 02 28 75 00 00 00
+ 1/1 TID 02
done!
got pmt 0
0107: 02 28 79 00 00 00
+ 1/1 TID 02
done!
got pmt 0
0108: 02 28 7a 00 00 00
+ 1/1 TID 02
done!
got pmt 0
0106: 02 28 83 00 00 00
+ 1/1 TID 02
done!
got pmt 0
-+ 1/2 TID 42
++ 2/2 TID 42
done!
got sdt 0
SDT:
ONID: 0002
SID 2871: name 'BBC 1 South', provider_name 'BSkyB'
descr<49>
descr<5f>
descr<b2>
SID 2872: name 'BBC 1 S West', provider_name 'BSkyB'
descr<49>
descr<5f>
descr<b2>
SID 2873: name 'BBC 1 NE & C', provider_name 'BSkyB'
descr<49>
descr<5f>
descr<b2>
SID 2874: name 'BBC 1 Oxford', provider_name 'BSkyB'
descr<49>
descr<5f>
descr<b2>
SID 2875: name 'BBC ALBA', provider_name 'BSkyB'
descr<49>
descr<5f>
descr<b2>
SID 2879: name 'BBC 1 NI', provider_name 'BSkyB'
descr<49>
descr<5f>
descr<b2>
ONID: 0002
SID 287a: name 'BBC 2 NI', provider_name 'BSkyB'
descr<49>
descr<5f>
descr<b2>
SID 2883: name 'ETV6', provider_name 'BSkyB'
descr<49>
descr<5f>
descr<b2>
channel done!
no channels left to scan.
1 channels scanned, 0 were unavailable.
1 channels in database.
resolve: resolve ${sysconfdir}/enigma2/lamedb
resolve: -> /etc/enigma2/lamedb
---- saving lame channel db
saved 1 channels and 8 services!
scan done!
action -> OkCancelActions ok
ok
action -> SetupActions cancel
nr_read 47 nr_write 12
sum 59 prev_sum 59
hdd IDLE!
[IDLE] 60.0000050068 600 False
action -> OkCancelActions cancel
close frontend 0
action -> InfobarChannelSelection switchChannelDown
reused converter!
reused converter!
reused converter!
action -> ChannelSelectBaseActions showProviders
eStaticServiceDVBBouquetInformation::getName failed.. getBouquet failed!
playing 1:0:1:2879:800:2:11A0000:0:0:0:
not pauseable.
RemovePopup, id = ZapError
allocate channel.. 0800:0002
opening frontend 0
[eDVBCAService] new channel 0x1a96df8!
(0)tune
tuning to 1068 mhz
OURSTATE: tuning
allocate Channel: res 0
[eDVBCIInterfaces] addPMTHandler 1:0:1:2879:800:2:11A0000:0:0:0:
allocate demux
[SEC] setVoltage 1
[SEC] sleep 10ms
set sequence pos 3
[SEC] setFrontend 1
setting frontend 0
[SEC] sleep 500ms
OURSTATE: ok
[eDVBCAService] channel 0x1a96df8 running
[eDVBLocalTimerHandler] channel 0x1a96df8 running
0014: 70 00 00 00 00 00
mask: fc 00 00 00 00 00
[eEPGCache] channel 0x1a96df8 running
stop release channel timer
0012: 4e 28 79 00 00 00
ok ... now we start!!
+ 1/1 TID 00
done!
PATready
use pmtpid 0107 for service_id 2879
doing version filtering
0000: 00 00 00 1b 00 00
mask: ff 00 00 3f 00 00
mode: 00 00 00 3e 00 00
+ 1/1 TID 02
done!
eventNewProgramInfo 0 0
have 1 video stream(s) (15e0), and 1 audio stream(s) (15e1), and the pcr pid is 15e0, and the text pid is 15e3
allocate demux
disable teletext subtitles
decoder state: play, vpid=5600, apid=5601
DMX_SET_PES_FILTER(0x15e0) - pcr - ok
DEMUX_START - pcr - ok
DMX_SET_PES_FILTER(0x15e1) - audio - ok
DEMUX_START - audio - ok
AUDIO_SET_BYPASS(1) - ok
AUDIO_PAUSE - ok
AUDIO_PLAY - ok
Video Device: /dev/dvb/adapter0/video0
demux device: /dev/dvb/adapter0/demux0
VIDEO_SET_STREAMTYPE 0 - ok
DMX_SET_PES_FILTER(0x15e0) - video - ok
DEMUX_START - video - ok
VIDEO_FREEZE - ok
VIDEO_PLAY - ok
DMX_SET_PES_FILTER(0x15e3) - ttx - ok
DEMUX_START - ttx - ok
VIDEO_SLOWMOTION(0) - ok
VIDEO_FAST_FORWARD(0) - ok
VIDEO_CONTINUE - ok
AUDIO_CONTINUE - ok
AUDIO_CHANNEL_SELECT(0) - ok
not pauseable.
[AutoRes] service changed
[eDVBCAService] new service 1:0:1:2879:800:2:11A0000:0:0:0:
[eDVBCAService] add demux 0 to slot 0 service 1:0:1:2879:800:2:11A0000:0:0:0:
[eDVBCIInterfaces] gotPMT
demux 0 mask 01 prevhash 00000000
0107: 02 28 79 13 00 00
mask: ff ff ff 3f 00 00
VIDEO_GET_EVENT - ok
[AutoRes] got event evVideoSizeChanged
[AutoRes] got event evFramerateChanged
[AutoRes] got event evVideoProgressiveChanged
+- 1/2 TID 4e
++ 2/2 TID 4e
done!
0012: 4e 28 79 0b 00 00
sdt update done!
[AutoRes] determineContent
[eDVBLocalTimerHandler] dont have correction.. set Transponder Diff
[eDVBLocalTimerHandler] update RTC
[eDVBLocalTimerHandler] time update to 19:05:39
[eDVBLocalTimerHandler] m_time_difference is 372618133
[eDVBLocalTimerHandler] set Linux Time
[EPGC] time updated.. start EPG Mainloop
before: 1
after: 1
[EPGC] 2876 events read from /hdd/epg.dat
[EPGC] start cleanloop
[EPGC] stop cleanloop
[EPGC] 251189 bytes for cache used
[EPGC] next update in 2 sec
action -> GlobalActions volumeDown
Setvolume: 95 95 (raw)
Setvolume: 4 4 (-1db)
setValue 95
Setvolume: 90 90 (raw)
Setvolume: 7 7 (-1db)
setValue 90
Setvolume: 85 85 (raw)
Setvolume: 10 10 (-1db)
setValue 85
Setvolume: 80 80 (raw)
Setvolume: 13 13 (-1db)
setValue 80
Setvolume: 75 75 (raw)
Setvolume: 16 16 (-1db)
setValue 75
Setvolume: 70 70 (raw)
Setvolume: 19 19 (-1db)
setValue 70
[EPGC] start caching events(1319303142)
Setvolume: 65 65 (raw)
Setvolume: 23 23 (-1db)
setValue 65
Setvolume: 60 60 (raw)
Setvolume: 26 26 (-1db)
setValue 60
Setvolume: 55 55 (raw)
Setvolume: 29 29 (-1db)
setValue 55
Setvolume: 50 50 (raw)
Setvolume: 32 32 (-1db)
setValue 50
Setvolume: 45 45 (raw)
Setvolume: 35 35 (-1db)
setValue 45
Setvolume: 40 40 (raw)
Setvolume: 38 38 (-1db)
setValue 40
Setvolume: 35 35 (raw)
Setvolume: 41 41 (-1db)
setValue 35
Setvolume: 30 30 (raw)
Setvolume: 45 45 (-1db)
setValue 30
Setvolume: 25 25 (raw)
Setvolume: 48 48 (-1db)
setValue 25
Setvolume: 20 20 (raw)
Setvolume: 51 51 (-1db)
setValue 20
[EPGC] abort non avail schedule reading
[EPGC] abort non avail schedule other reading
[EPGC] abort non avail viasat reading
[EPGC] abort non avail mhw reading
[EPGC] nownext finished(1319303149)
[EPGC] stop caching events(1319303149)
[EPGC] next update in 60 min
no ancillary data in audio stream... abort radiotext pes parser
nr_read 56 nr_write 18
sum 74 prev_sum 59
hdd was accessed since previous check!
[IDLE] 0 600 False
[EPGC] 254807 bytes for cache used
[CrossEPG_Auto] poll
It's now Sat Oct 22 19:07:00 2011
[timer.py] next activation: 1319303320 (in 99998 ms)
[timer.py] next activation: 1319303320 (in 99997 ms)
sum 74 prev_sum 74
hdd IDLE!
[IDLE] 59.9999969006 600 False
sum 74 prev_sum 74
hdd IDLE!
[IDLE] 120.000020981 600 False
It's now Sat Oct 22 19:08:40 2011
[timer.py] next activation: 1319303420 (in 99999 ms)
[timer.py] next activation: 1319303420 (in 99997 ms)
hotplug: {'SUBSYSTEM': 'block', 'MAJOR': '11', 'DEVPATH': '/block/sr0', 'SEQNUM': '336', 'PHYSDEVPATH': '/devices/platform/brcm-ehci.0/usb1/1-1/1-1:1.0/host2/target2:0:0/2:0:0:0', 'PHYSDEVDRIVER': 'sr', 'add@/block/sr': 'add@/block/sr0', 'PHYSDEVBUS': 'scsi', 'ACTION': 'add', 'MINOR': '0'}
found block device 'sr0': ok, removable=True, cdrom=True, partitions=[]
mountpoint /autofs/sr0/
description CDDVDW SE-S084F
force_mounted True
scanning ('CDDVDW SE-S084F', '/autofs/sr0/', <__main__.Session instance at 0x179f3a0>)
scanner: [<Scanner STB-Package>, <Scanner Movie>, <Scanner Video CD>, <Scanner Music>, <Scanner Pictures>, <Scanner DVD>, <Scanner Ipkg>]
main thread is non-idle! display spinner!
ignore /autofs/sr0/ because its not accessible
add device sr0 to bdpoll current state: medium inserted
media removal detected on sr0
ioctl BLKRRPART failed Function not implemented
MSG_MEDIUM_REMOVED
sum 74 prev_sum 74
hdd IDLE!
[IDLE] 180.000072956 600 False
media insertion detected on sr0
MSG_MEDIUM_INSERTED
force_mounted True
open cdrom exclusive failed: mounted... try non exclusive
execute ('Play DVD', <Scanner DVD>, [<ScanFile /autofs/sr0/VIDEO_TS/VIDEO_TS.IFO (video/x-dvd, None MB)>], <__main__.Session instance at 0x179f3a0>)
splitted ['', 'autofs', 'sr0', 'VIDEO_TS', 'VIDEO_TS.IFO']
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
not pauseable.
Looking for embedded skin
stopService
[eDVBCAService] free slot 0 demux 0 for service 1:0:1:2879:800:2:11A0000:0:0:0:
[eDVBCAService] free service 1:0:1:2879:800:2:11A0000:0:0:0:
decoder state: play, vpid=-1, apid=-1
DEMUX_STOP - pcr - ok
DEMUX_STOP - video - ok
VIDEO_STOP - ok
AUDIO_STOP - ok
DEMUX_STOP - audio - ok
AUDIO_CONTINUE - ok
DEMUX_STOP - ttx - ok
start release channel timer
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
File "/usr/lib/enigma2/python/mytest.py", line 201, in processDelay
callback(*retval)
File "/usr/lib/enigma2/python/Plugins/Extensions/MediaScanner/plugin.py", line 12, in execute
scanner.open(files, session)
File "/usr/lib/enigma2/python/Components/Scanner.py", line 53, in open
self.openfnc(list, *args, **kwargs)
File "/usr/lib/enigma2/python/Plugins/Extensions/DVDPlayer/plugin.py", line 745, in filescan_open
session.open(DVDPlayer, dvd_device="/dev/%s" %(splitted[2]))
File "/usr/lib/enigma2/python/mytest.py", line 312, in open
dlg = self.current_dialog = self.instantiateDialog(screen, *arguments, **kwargs)
File "/usr/lib/enigma2/python/mytest.py", line 247, in instantiateDialog
return self.doInstantiateDialog(screen, arguments, kwargs, self.desktop)
File "/usr/lib/enigma2/python/mytest.py", line 278, in doInstantiateDialog
dlg.applySkin()
File "/usr/lib/enigma2/python/Components/GUISkin.py", line 112, in applySkin
self.createGUIScreen(self.instance, self.desktop)
File "/usr/lib/enigma2/python/Components/GUISkin.py", line 21, in createGUIScreen
if not val.applySkin(desktop, self):
File "/usr/lib/enigma2/python/Components/GUIComponent.py", line 39, in applySkin
skin.applyAllAttributes(self.instance, desktop, self.skinAttributes, parent.scale)
File "/usr/lib/enigma2/python/skin.py", line 254, in applyAllAttributes
applySingleAttribute(guiObject, desktop, attrib, value, scale)
File "/usr/lib/enigma2/python/skin.py", line 142, in applySingleAttribute
guiObject.resize(parseSize(value, scale))
File "/usr/lib/enigma2/python/skin.py", line 96, in parseSize
x, y = str.split(',')
ValueError: too many values to unpack
(PyObject_CallObject(<bound method Session.processDelay of <__main__.Session instance at 0x179f3a0>>,()) failed)
</enigma2crashlog>
<pythonMD5sum>
<![CDATA[
02045a85d05a3cde1b5d97443b72ae2c /usr/lib/enigma2/python/enigma.py
c8cb7ffe121f512968813014bcabf0cd /usr/lib/enigma2/python/e2reactor.py
0ff6b1d31b6b25a6b7745658f179b22f /usr/lib/enigma2/python/RecordTimer.py
dbbb881f6c856e4cab017f518ba4a68a /usr/lib/enigma2/python/Tools/CList.py
cbe6d03d0dd9d165c8ec776c5c9adcce /usr/lib/enigma2/python/Tools/ASCIItranslit.py
a2218e726395499f00c72c393da3ba2c /usr/lib/enigma2/python/Tools/LoadPixmap.py
d9d83467815003e745113b9a16a1473d /usr/lib/enigma2/python/Tools/DreamboxHardware.py
9cb37012dc10aab1d5a6f0128093e9de /usr/lib/enigma2/python/Tools/KeyBindings.py
b59a24f3c4925c36ab2b5c20a47d70cd /usr/lib/enigma2/python/Tools/ISO639.py
09af65390e201fdc839573e5a5bc43f6 /usr/lib/enigma2/python/Tools/FuzzyDate.py
a0639de72e3006e1001f4bf549017bb9 /usr/lib/enigma2/python/Tools/Directories.py
b3422d679770a129342e52f6ca2978ad /usr/lib/enigma2/python/Tools/NumericalTextInput.py
b4011bd490319162c0bb7ab1fe0816f9 /usr/lib/enigma2/python/Tools/BoundFunction.py
5e58ee8495c6b18b588e7c5b6069fa4c /usr/lib/enigma2/python/Tools/Downloader.py
e3356c99fc63880d7cbe4495a03adb68 /usr/lib/enigma2/python/Tools/__init__.py
8c8b3e4062f8e5e9c72cceac90320a2f /usr/lib/enigma2/python/Tools/Profile.py
fec44e3c680135b636adcbc71044cab4 /usr/lib/enigma2/python/Tools/Event.py
2bb2eab34660b5fcdf0b30f9bd1e8f44 /usr/lib/enigma2/python/Tools/Notifications.py
d364549956b3cfabe13d9b6b561232df /usr/lib/enigma2/python/Tools/Import.py
fc8e1e93a7429fba50acb0261f7f5268 /usr/lib/enigma2/python/Tools/RedirectOutput.py
c542bb10e8db238b1bd7cf3e2ca06aa9 /usr/lib/enigma2/python/Tools/XMLTools.py
47611e868aaa72c9c0ca79c4810dbe97 /usr/lib/enigma2/python/Tools/Transponder.py
a428aeab8edfef7d2dc4025084898ac4 /usr/lib/enigma2/python/Tools/HardwareInfo.py
9d0761269aedda651639c75a21f15702 /usr/lib/enigma2/python/skin.py
c96070e276dd1207f742dbb835016b02 /usr/lib/enigma2/python/Navigation.py
41d347a6305f5523347e1d4e7b5e9989 /usr/lib/enigma2/python/GlobalActions.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Blackhole/__init__.py
eb9426c13bfa9868aacb87f050a8c40e /usr/lib/enigma2/python/ServiceReference.py
46cf5439c0702ae3d52adf1e0df028af /usr/lib/enigma2/python/NavigationInstance.py
0b4897696936a4c0799525c7f1e73166 /usr/lib/enigma2/python/timer.py
2847ae9cd6ce7ef306501d30d1b675d3 /usr/lib/enigma2/python/SleepTimer.py
c8ccccf312cc9a35d1f786f965d57b0b /usr/lib/enigma2/python/Plugins/Plugin.py
953c1e21d433a3140a6ba6c2b93cf472 /usr/lib/enigma2/python/Plugins/Extensions/GraphMultiEPG/GraphMultiEpg.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/GraphMultiEPG/__init__.py
e495f59341b9d41c810732b50b001dc1 /usr/lib/enigma2/python/Plugins/Extensions/GraphMultiEPG/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/WebBrowser/__init__.py
84372c04cb57d74c788de058904f5c34 /usr/lib/enigma2/python/Plugins/Extensions/WebBrowser/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/BhEpgBackup/__init__.py
ab0a07e9fec70ae0abb9a1f539509a2b /usr/lib/enigma2/python/Plugins/Extensions/MeoBoot/__init__.py
377585531a915f167fd63413e6a09647 /usr/lib/enigma2/python/Plugins/Extensions/MeoBoot/ex_init.py
d784fa8b6d98d27699781bd9a7cf19f0 /usr/lib/enigma2/python/Plugins/Extensions/MediaPlayer/__init__.py
7bf99b4b797254f0536fbd08fef66f6f /usr/lib/enigma2/python/Plugins/Extensions/MediaPlayer/settings.py
d67f186f0a9ba8aba7955bb6598c6d2f /usr/lib/enigma2/python/Plugins/Extensions/MediaPlayer/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/__init__.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/CutListEditor/__init__.py
150f218b4461c255a04f694ad68dc75a /usr/lib/enigma2/python/Plugins/Extensions/CutListEditor/plugin.py
a9dcef2da426bd609d09b6e9d0316b5e /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebScreens.py
98a8dae8e0496adb08f5d8dd8e4f8820 /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/__init__.py
93eaef30e956b12b47081b0d585fad64 /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/webif.py
02fe34452f1274d0025626361a69e6c9 /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebComponents/__init__.py
91479b6a9e25f99be4798d5bf6fd3914 /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebComponents/Converter/HddInfo.py
c3bae94be7328e3d5c6a811c150bee88 /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebComponents/Converter/VolumeInfo.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebComponents/Converter/__init__.py
e3ef925e28eded7dcef05c99318f476f /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebComponents/Converter/SimpleResult.py
6b90d645fb75ee1ffda73b2688425f30 /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebComponents/Converter/SleepTimer.py
da991165af5e3d0d53a40d01b1628f85 /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebComponents/Converter/NetworkInterfaceInfo.py
d436a4138e98d39005d78f0f72932501 /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebComponents/Sources/ServiceListRecursive.py
275867d2408ad16b9ae31a7d4a404076 /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebComponents/Sources/AudioTracks.py
5eb9ae2ca60efb007202c111c8930ec3 /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebComponents/Sources/AT.py
c820acea417a939a08364b876c7a9575 /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebComponents/Sources/MP.py
fe6b0a509f87a3b4075f9a226a0fc376 /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebComponents/Sources/About.py
9392b9c41ab74782173a5437cbb52928 /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebComponents/Sources/RemoteControl.py
1499a53f194576871251884a3edbca4f /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebComponents/Sources/ReadPluginList.py
4b47929ce7aa9c84f8d103f09a1951a1 /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebComponents/Sources/RequestData.py
39e382bca61070d7985791ef6a8909fd /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebComponents/Sources/WAPfunctions.py
71e9fcc6eeb03c4048e9309e8f74cdcc /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebComponents/Sources/ServicePlayable.py
688712d930947ba359307613daee7d60 /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebComponents/Sources/CurrentService.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebComponents/Sources/__init__.py
905c5c437f4485b84d8b73c7305a7c14 /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebComponents/Sources/PowerState.py
cdbb85a69593d2ae79e71b3c3f2bd068 /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebComponents/Sources/EPG.py
38d8dd227714fde94bf51483ea24e63d /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebComponents/Sources/Hdd.py
c450a6398e9176138302187f8f006e51 /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebComponents/Sources/ParentControl.py
7e22dc36a163607329af91a97ca775cc /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebComponents/Sources/SleepTimer.py
d2917af6478144bb8cf2a2942b05dca9 /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebComponents/Sources/SubServices.py
8a1bb12c3a13a11bcbd65e500d78dc05 /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebComponents/Sources/Movie.py
8711a7c84d1f416fe2aa57537240f12f /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebComponents/Sources/Frontend.py
2e99f33878883c0c70c85f5cae001618 /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebComponents/Sources/ServiceListReload.py
20951943bf124116381d56543268ec93 /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebComponents/Sources/Timer.py
913acf90a36620ef3e50f022f0f157ad /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebComponents/Sources/Settings.py
207af2bbaa6844ebf5f417c76be70ccd /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebComponents/Sources/Network.py
e32ce2bc670c4db4654091cc9643bb6c /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebComponents/Sources/Volume.py
57870159f31ca8c7e0186ce32f67b2cc /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebComponents/Sources/LocationsAndTags.py
8c7be840b00156f0b13b45cd9a4b2739 /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebComponents/Sources/SwitchService.py
bfd03a4831f9b7740c090ac43afb9f87 /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebComponents/Sources/Message.py
d05559ffc439af48d1fd42a57db948a6 /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebChilds/Toplevel.py
0a3eb362ab8fb9c10902c741a706fc5f /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebChilds/FileStreamer.py
d5321b64c8f8e01353326fecef6cb810 /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebChilds/ServiceListSave.py
8d3fa4368e0ddd4961449b4b0f9df747 /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebChilds/Screenpage.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebChilds/__init__.py
09f98acb513db8a7d1326d281fe3ac2f /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebChilds/PlayService.py
1a3c00d2c16f15eba8157dc8e7cdac71 /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebChilds/Screengrab.py
2286a839f700469863379baff1622743 /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebChilds/RedirecToCurrentStream.py
75d6cfcd2d531f46f9b333a8993f1151 /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebChilds/External/__init__.py
a06638596d63924d58d72a8efc161092 /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebChilds/External/AutoTimer.py
3e646a20e5af4e6a2d51d29fa31a4f9c /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebChilds/External/EPGRefresh.py
b63f4f117c2d2b02904ceab8904a9cb3 /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebChilds/External/Example.py
88fec6376a97cbf19a487daf6f7da30f /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebChilds/IPKG.py
4bc7690ecc1453e5a016b36e1653a7e3 /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebChilds/Uploader.py
564292b61bcb675e9fa84dc0cfc63183 /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebIfConfig.py
a7872e255e6937e7121275943dae7ae3 /usr/lib/enigma2/python/Plugins/Extensions/MyTube/ThreadQueue.py
3f2553ad4f45959f17f2afdb617d8f45 /usr/lib/enigma2/python/Plugins/Extensions/MyTube/MyTubeSearch.py
c221d4bc9938619b19d98ce788e271f2 /usr/lib/enigma2/python/Plugins/Extensions/MyTube/MyTubeService.py
10e24c344b41265a6b7c75375757beca /usr/lib/enigma2/python/Plugins/Extensions/MyTube/__init__.py
7c658f6b7edc9421bc8b09eae7ff8338 /usr/lib/enigma2/python/Plugins/Extensions/MyTube/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/Tuxtxt/__init__.py
fd9ff9eca1e4c86996e811b95f8eb0e4 /usr/lib/enigma2/python/Plugins/Extensions/Tuxtxt/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/PicturePlayer/__init__.py
b72c7859893a76cafdfc32c65e1df0fb /usr/lib/enigma2/python/Plugins/Extensions/PicturePlayer/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/BhPersonalBackup/__init__.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/MediaScanner/__init__.py
2ae0e1640ea4267540f2922afab4eb5b /usr/lib/enigma2/python/Plugins/Extensions/MediaScanner/plugin.py
d784fa8b6d98d27699781bd9a7cf19f0 /usr/lib/enigma2/python/Plugins/Extensions/DVDPlayer/__init__.py
4f8608960caf0228c0beadd0f4fb38d1 /usr/lib/enigma2/python/Plugins/Extensions/DVDPlayer/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/DemoPlugins/__init__.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/__init__.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/Hotplug/__init__.py
d8f9b54aeb4984c2c49cb649196d3b30 /usr/lib/enigma2/python/Plugins/SystemPlugins/Hotplug/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/UI3DSetup/__init__.py
e2d2fb551f54380e2e1e616382e0e6a0 /usr/lib/enigma2/python/Plugins/SystemPlugins/UI3DSetup/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/FactoryTest/__init__.py
b69cabc88200dbc2c8301d13f3ca4c67 /usr/lib/enigma2/python/Plugins/SystemPlugins/FactoryTest/plugin.py
2fac60170cdd3cc068dc058f582f3cb7 /usr/lib/enigma2/python/Plugins/SystemPlugins/FactoryTest/sctest.py
d0efff1ceb51425323e870c0d5b8b39f /usr/lib/enigma2/python/Plugins/SystemPlugins/WirelessLan/Wlan.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/WirelessLan/__init__.py
dae1e2f79278d8ff4d3e4fd3cfef2690 /usr/lib/enigma2/python/Plugins/SystemPlugins/WirelessLan/plugin.py
9f565e180deab436b5175874ee919ca6 /usr/lib/enigma2/python/Plugins/SystemPlugins/VideoTune/VideoFinetune.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/VideoTune/__init__.py
6307b4f8a6952cfd3532bc8bed7cb817 /usr/lib/enigma2/python/Plugins/SystemPlugins/VideoTune/plugin.py
c954129f81aef46f117be2b995d919ba /usr/lib/enigma2/python/Plugins/SystemPlugins/Videomode/VideoWizard.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/Videomode/__init__.py
d2d2d6d90b128e0f8221dd862d934081 /usr/lib/enigma2/python/Plugins/SystemPlugins/Videomode/plugin.py
1b7a6f60792410a7d6f101a9dd537ac1 /usr/lib/enigma2/python/Plugins/SystemPlugins/Videomode/VideoHardware.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/SkinSelector/__init__.py
1584d91b9c0e5c3cd70b8f3a9e655e04 /usr/lib/enigma2/python/Plugins/SystemPlugins/SkinSelector/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/Fancontrol/__init__.py
3777baba890fa85711592db07697088c /usr/lib/enigma2/python/Plugins/SystemPlugins/Fancontrol/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/__init__.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/AutoResolution/__init__.py
31f058e8405b2b292ab9c0ed042ad783 /usr/lib/enigma2/python/Plugins/SystemPlugins/AutoResolution/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/BlackHoleApi/__init__.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkWizard/__init__.py
a2008372ff89c62d07cb31e6a9de091f /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkWizard/plugin.py
2ac4b1eee155bde62cda348383e117e9 /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkWizard/NetworkWizard.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/CommonInterfaceAssignment/__init__.py
a246ce4f2ff625bbecc9f64437f6197a /usr/lib/enigma2/python/Plugins/SystemPlugins/CommonInterfaceAssignment/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/UIPositionSetup/__init__.py
8a7b85f81517a5b62e89c872b83d1d25 /usr/lib/enigma2/python/Plugins/SystemPlugins/UIPositionSetup/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/Satfinder/__init__.py
61f98a769c5ded0c8a64451697891120 /usr/lib/enigma2/python/Plugins/SystemPlugins/Satfinder/plugin.py
b7c161d59170e825a894dec1d8b8c951 /usr/lib/enigma2/python/Plugins/SystemPlugins/SoftwareManager/ImageWizard.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/SoftwareManager/__init__.py
afeadfb665c0e1b468d19f98f3ade7de /usr/lib/enigma2/python/Plugins/SystemPlugins/SoftwareManager/plugin.py
5cd63078da8d66aa7081d64b74692f40 /usr/lib/enigma2/python/Plugins/SystemPlugins/SoftwareManager/SoftwareTools.py
d1e4f463eeb0272a2f86f40c3a77a7aa /usr/lib/enigma2/python/Plugins/SystemPlugins/SoftwareManager/BackupRestore.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/PositionerSetup/__init__.py
1440586470e4335ea4e9838d1c785379 /usr/lib/enigma2/python/Plugins/SystemPlugins/PositionerSetup/plugin.py
4153403ed295cdd099ba056109e40ce7 /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepg_locale.py
438360c99adf10d37bb2bb1aba2c06d0 /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepg_xepgdb_update.py
33e59bb91c77a56393b89d14bf4432f4 /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepg_converter.py
4548e0dbbf15553d959498e7f81f7a4c /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepg_importer.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/__init__.py
c1debda1e760193f7e9a9c655b2c0f4b /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepg_info.py
0e72a14f8d25f355de48d645539790de /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/plugin.py
5fbe402f3c67003c92c2b2f96861bf26 /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepg_downloader.py
1106bfab8a8ac81bbdfdc42525c42a26 /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepg_ordering.py
13245153d2e1301eabb55634bb60732f /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepg_setup.py
0571a881aed68645a3c8224b0f514c8f /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepg_rytec_update.py
cfb9986cbbe4b74beaf0c1413f79bd19 /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepglib.py
2dcad2a8ed9782badaecbfd127441f29 /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepg_main.py
74457affa498021694ec972e3659f564 /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepg_menu.py
ce2502ef4098977d59e2272f89c94664 /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepg_providers.py
fad20b74cb80966a0985b23807372f2e /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepg_about.py
ab25a10ca1c6276dedd44a32802070ba /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepg_loader.py
a4579a396c439a2449dd9f0bff3df85f /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/crossepg_auto.py
fdfef44222724f489ae3cd438e81b871 /usr/lib/enigma2/python/Plugins/SystemPlugins/CrossEPG/version.py
b70bb2961078b2dc8156f46281c0ff97 /usr/lib/enigma2/python/Plugins/SystemPlugins/VideoEnhancement/VideoEnhancement.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/VideoEnhancement/__init__.py
556423529be882b7c105365bca27b25b /usr/lib/enigma2/python/Plugins/SystemPlugins/VideoEnhancement/plugin.py
286db9f715fa9c074016e0132750128e /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/NetworkBrowser.py
340b79e10fdf7e759e103704b12fa2a9 /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/MountManager.py
2db4069db43044a52e20a46811b64164 /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/MountEdit.py
44cca1ed648f0d92ba14d531d477c7db /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/AutoMount.py
7010636521d6a0183f317e43ace396e2 /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/__init__.py
da2d19e7d6c97c2f645bd34ce7fa7ff8 /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/plugin.py
2fd13d35fa6df0843208e85cfcf3bef7 /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/UserManager.py
6a352b0bfe8173ec89e5ce895b01eb6d /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/MountView.py
19b45c6ada80382a72629591ba86580a /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/UserDialog.py
cbc39aa5935ab3119f74e97329d4fef7 /usr/lib/enigma2/python/Components/SetupDevices.py
b0e458255e15f1a8aec85f6288ef085d /usr/lib/enigma2/python/Components/Button.py
0e01a1e3e304e69f8d1b89a8ef22cd31 /usr/lib/enigma2/python/Components/About.py
aef22114ab5ec5233d363994f8c87b6f /usr/lib/enigma2/python/Components/SystemInfo.py
d232dc74bc439432f3308bab607ad3ad /usr/lib/enigma2/python/Components/ServiceList.py
293601b503ad89e0ebe9bc8ef85c9dd8 /usr/lib/enigma2/python/Components/MultiContent.py
776023a14682d64e78dec7b3816a70fa /usr/lib/enigma2/python/Components/NimManager.py
7be136b6d1eaa13aaa08832390bd53ca /usr/lib/enigma2/python/Components/Ipkg.py
fda2884a50d71cf31c89a54de97be5a2 /usr/lib/enigma2/python/Components/ResourceManager.py
464c8a0e511dc879697d1a0d9766ef3c /usr/lib/enigma2/python/Components/Pixmap.py
3bf2c3379296e6d363ef68553dbdaf80 /usr/lib/enigma2/python/Components/GUISkin.py
0d707152124791c90b82fbc6e844918d /usr/lib/enigma2/python/Components/HTMLSkin.py
878322c744ce79649d47b8e599c01cdf /usr/lib/enigma2/python/Components/HelpMenuList.py
6b97ff9a5291eb296cfcefc28ceaceef /usr/lib/enigma2/python/Components/VariableValue.py
b2fe45714c4a542dc0aea365aabd3bb1 /usr/lib/enigma2/python/Components/ServiceEventTracker.py
7f3b46d858f45c88bcadef484c575ae0 /usr/lib/enigma2/python/Components/VolumeControl.py
ab2eef0ec82f8afbd8e5f6ed5128f02c /usr/lib/enigma2/python/Components/Keyboard.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Components/components.py
8bcf68f46c11af120dcfc5e51ee0e720 /usr/lib/enigma2/python/Components/Playlist.py
8468ca158afbf972070020f0efd34475 /usr/lib/enigma2/python/Components/HdmiCec.py
6bfb33d04cb60ca5288d680b65d01608 /usr/lib/enigma2/python/Components/Input.py
9f73b7497ad108747f09bb672255f99f /usr/lib/enigma2/python/Components/ChoiceList.py
ed446633b70188c44fcd2d4866044bbe /usr/lib/enigma2/python/Components/VideoWindow.py
6d4f8f7e30285110a59c0e30c62640fd /usr/lib/enigma2/python/Components/PerServiceDisplay.py
1bd1c3e110097a9e5e15b7a7ccd225ee /usr/lib/enigma2/python/Components/GUIComponent.py
4da8c35225b2dd62dacf3ad8099d9706 /usr/lib/enigma2/python/Components/PluginList.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Components/__init__.py
c9da57a45f2d4465e16b51dd994bc79e /usr/lib/enigma2/python/Components/DiskInfo.py
73fb7af94ab02923d0e8365be10a96a4 /usr/lib/enigma2/python/Components/ParentalControlList.py
62c655bbacc907e84cd14c4dc9972546 /usr/lib/enigma2/python/Components/BlinkingPixmap.py
4b27f5f16806fde8c7e6b0528082319f /usr/lib/enigma2/python/Components/Scanner.py
9622e6cba82f6bfd81979c039689dc3d /usr/lib/enigma2/python/Components/Harddisk.py
4a5d006fa9b187e5008608b1b89bbff0 /usr/lib/enigma2/python/Components/ActionMap.py
bd1cad92310c93542e71ebbbce2798f7 /usr/lib/enigma2/python/Components/ServiceScan.py
15bea5fc9dbe47aac657be4a34439961 /usr/lib/enigma2/python/Components/Converter/Streaming.py
616a46e34dfb272ea76092906cf0546d /usr/lib/enigma2/python/Components/Converter/EventName.py
b13c107d6ad058ba60856abcb94cb0c2 /usr/lib/enigma2/python/Components/Converter/BhAnalogic.py
919b568ec0ddeddd7798d2641e444c9e /usr/lib/enigma2/python/Components/Converter/StaticText.py
58fee00295729a2adb7033bf68371de7 /usr/lib/enigma2/python/Components/Converter/ProgressToText.py
38362c2c04914861eb86b7a7d69afa4b /usr/lib/enigma2/python/Components/Converter/ServiceName.py
28dde32d3346086a1ec64dc3ee1627f9 /usr/lib/enigma2/python/Components/Converter/FrontendInfo.py
dc9a4c4fc79c6e128e0179fc30d19895 /usr/lib/enigma2/python/Components/Converter/StringListSelection.py
e90e83fd0a8fc7b634792ecd2a6edbda /usr/lib/enigma2/python/Components/Converter/StaticMultiList.py
5d971edffdd2cd735683bb4c9093ef35 /usr/lib/enigma2/python/Components/Converter/ConfigEntryTest.py
4078e76e1346d8f2a5e874efd2b904ac /usr/lib/enigma2/python/Components/Converter/RdsInfo.py
87e4bbae4ce58464d0c7ca9319726cd7 /usr/lib/enigma2/python/Components/Converter/MovieInfo.py
58b6e06f16433368d76847d3aba80372 /usr/lib/enigma2/python/Components/Converter/ValueToPixmap.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Components/Converter/__init__.py
c34a0a1a3f90265b36cbf8336ea7b7c1 /usr/lib/enigma2/python/Components/Converter/ConditionalShowHide.py
17956139931985e8f54cb633cc1af8e4 /usr/lib/enigma2/python/Components/Converter/EventTime.py
87c95b795e765d0651b875064d114541 /usr/lib/enigma2/python/Components/Converter/ServicePosition.py
2f5e9df85dd9c531dcf62a3aab5ecfe1 /usr/lib/enigma2/python/Components/Converter/Combine.py
af3845fb48965e926fd51a7439c85ee6 /usr/lib/enigma2/python/Components/Converter/Converter.py
73a07616a11fe77a022194d58b0940e7 /usr/lib/enigma2/python/Components/Converter/ValueRange.py
42b16b575d76c0e130ff3f007497d354 /usr/lib/enigma2/python/Components/Converter/ValueBitTest.py
450c953359065349aac382f76b21fdae /usr/lib/enigma2/python/Components/Converter/Poll.py
a6ecc808c0328a437c61eb2ade05bea6 /usr/lib/enigma2/python/Components/Converter/ServiceTime.py
4b8d476929f2c17190baf9d38fa70afc /usr/lib/enigma2/python/Components/Converter/SensorToText.py
da60ed1a4fde0806990486a01bd727e9 /usr/lib/enigma2/python/Components/Converter/ClockToText.py
3176888cde9c0efeed9ae52282e73dec /usr/lib/enigma2/python/Components/Converter/TemplatedMultiContent.py
4c78fa5f5bf79d7fffe80a9a568043c0 /usr/lib/enigma2/python/Components/Converter/RemainingToText.py
212ed83b27cd52d0e697c09820e4fca3 /usr/lib/enigma2/python/Components/Converter/ServiceInfo.py
2c2d157ea7d28a4a43f20b6408ac0394 /usr/lib/enigma2/python/Components/Converter/TunerInfo.py
088bd12c66a5fe4c2b87678e274fc13a /usr/lib/enigma2/python/Components/Converter/MenuEntryCompare.py
a7de7fb276c23533cff437f8c978a4af /usr/lib/enigma2/python/Components/Converter/StringList.py
740cfba1ec935bde6fcf238d13cf103c /usr/lib/enigma2/python/Components/TimerSanityCheck.py
c498dfaa263d90bd6f75430b02ab7ee4 /usr/lib/enigma2/python/Components/MenuList.py
8a0fe43501d2ad168ea15b4b4f147b84 /usr/lib/enigma2/python/Components/ServicePosition.py
2e48b88dedea0fba6d98d45e9327c74c /usr/lib/enigma2/python/Components/FileList.py
a08636829f357ad582d52b123921b7ac /usr/lib/enigma2/python/Components/Lcd.py
441b7133abd36d565dc14c4a6f5ffee0 /usr/lib/enigma2/python/Components/UsageConfig.py
be3e16f7afa1dca9e6a8804b6fd09bbe /usr/lib/enigma2/python/Components/SelectionList.py
90d3d2dc3166c98afa087506e7974385 /usr/lib/enigma2/python/Components/MovieList.py
0e3a5c6ab96676dd5e82179bd6e0d6d4 /usr/lib/enigma2/python/Components/config.py
5ca34b71f3b1f9f09d32a4a150498935 /usr/lib/enigma2/python/Components/Timezones.py
2c1bd3117309881fef653c59d6d3b858 /usr/lib/enigma2/python/Components/RFmod.py
1c4cac0789e596a771af1c7d358f2f84 /usr/lib/enigma2/python/Components/Console.py
c49b29929b4e4162394dc2f7a8c772f8 /usr/lib/enigma2/python/Components/ScrollLabel.py
1f4cca2ae97c0322cc9e23acfca76276 /usr/lib/enigma2/python/Components/InputDevice.py
0750ee83cdf4bf9192a0f3d7b12218d1 /usr/lib/enigma2/python/Components/TimerList.py
630323f4905e84479b1ba21efdc799bd /usr/lib/enigma2/python/Components/PluginComponent.py
9f0161d7c0504b6ef817767d2bed97d5 /usr/lib/enigma2/python/Components/Label.py
4fdc9ae13b1284850d6f4153d44213cf /usr/lib/enigma2/python/Components/ProgressBar.py
3b2edd9b322ed121c8f2e88cf76fa11f /usr/lib/enigma2/python/Components/RecordingConfig.py
455a470bf796884de3cf5886fbbdbdb8 /usr/lib/enigma2/python/Components/FanControl.py
db075a06a00091ac91dfdaae6fc66e37 /usr/lib/enigma2/python/Components/language_cache.py
ae9baee8c742036b23345f88e775a15f /usr/lib/enigma2/python/Components/Slider.py
39f5958bd070caf59f8a4a7c9fab15cc /usr/lib/enigma2/python/Components/EpgList.py
295d6b590f174c8dd08a36d330a92352 /usr/lib/enigma2/python/Components/AVSwitch.py
6feeba1843947ec6baaeef017ad68230 /usr/lib/enigma2/python/Components/HTMLComponent.py
489d7215689628eec1890d5a943ff252 /usr/lib/enigma2/python/Components/Network.py
b0869deccb48eb53982607aef33c3978 /usr/lib/enigma2/python/Components/Gauge.py
3684fc75e398c2a2046c627a81ef2158 /usr/lib/enigma2/python/Components/ConfigList.py
ee73da21a06410074bb749968c680955 /usr/lib/enigma2/python/Components/TuneTest.py
3b5dc0f7bf90523b8401499ae1c7aaec /usr/lib/enigma2/python/Components/VariableText.py
fdd79c3bfa2aae2a5d0b6fe8951ce439 /usr/lib/enigma2/python/Components/Sensors.py
2e5c620136817ebddfa7b3331244113b /usr/lib/enigma2/python/Components/Task.py
347cefa17014ec18aa905407bcd658b9 /usr/lib/enigma2/python/Components/ParentalControl.py
7d06bd081dd0e10b7019d8ac58708949 /usr/lib/enigma2/python/Components/Element.py
c2929a5e2de2d1b3a94e2c38cd7274c5 /usr/lib/enigma2/python/Components/Sources/Progress.py
6a85468d2ac38a7f37dbc5f73415ca8f /usr/lib/enigma2/python/Components/Sources/ServiceList.py
ab296b833f2d34f06b5ac2a16c782df3 /usr/lib/enigma2/python/Components/Sources/Source.py
b8b12180202bc1ca61007fd6b7ec7009 /usr/lib/enigma2/python/Components/Sources/StaticText.py
b2b638612aa61f66e5c729d969dc96b6 /usr/lib/enigma2/python/Components/Sources/RdsDecoder.py
47312dcaaea9e981b3e22b2363898485 /usr/lib/enigma2/python/Components/Sources/FrontendInfo.py
ce001a44e6f7098624a6df98c1c5761b /usr/lib/enigma2/python/Components/Sources/Boolean.py
5723d19be11ccbffd48502ade1010767 /usr/lib/enigma2/python/Components/Sources/List.py
44460c27e2763fb358898dc34907c140 /usr/lib/enigma2/python/Components/Sources/Clock.py
11bd6ef9d574ab79c97d9f5160cabece /usr/lib/enigma2/python/Components/Sources/CanvasSource.py
78c43ab613a6166cf5858eb963ba62bd /usr/lib/enigma2/python/Components/Sources/Config.py
647e2f65fb79b2fae4a1c2ce5007b656 /usr/lib/enigma2/python/Components/Sources/CurrentService.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Components/Sources/__init__.py
c6f7285e3f449c301dab92d92cfb1fce /usr/lib/enigma2/python/Components/Sources/FrontendStatus.py
56c35c1b2af81757e84913b3eb816e6e /usr/lib/enigma2/python/Components/Sources/Sensor.py
f2edeec29b502db62369e2283816ead4 /usr/lib/enigma2/python/Components/Sources/Event.py
7c307f1c09f73fbd61de82c2e2544d3d /usr/lib/enigma2/python/Components/Sources/EventInfo.py
3059a135ceb0c3fca0867698f21fc2b7 /usr/lib/enigma2/python/Components/Sources/StreamService.py
1da1958b336de06b874c9facb97d8e3e /usr/lib/enigma2/python/Components/Sources/ServiceEvent.py
f68dc995f78cfc88e26483ea787746ab /usr/lib/enigma2/python/Components/Sources/TunerInfo.py
d421be00754d02d85df804e4faea908f /usr/lib/enigma2/python/Components/Sources/RecordState.py
8a566189add219ba26e3204f2eb21164 /usr/lib/enigma2/python/Components/Language.py
f43a627a5e8fb9b7a4a5ca67db7bb42a /usr/lib/enigma2/python/Components/Renderer/Progress.py
c947108f65672842ac96be1bf179690f /usr/lib/enigma2/python/Components/Renderer/Pixmap.py
ae4183381040270c96baa391d91fb26b /usr/lib/enigma2/python/Components/Renderer/Bhclock.py
7b0aa9b18eb25016e3b5b3f250281731 /usr/lib/enigma2/python/Components/Renderer/FixedLabel.py
83384daaed9da756f7866d192d26b4b2 /usr/lib/enigma2/python/Components/Renderer/Canvas.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Components/Renderer/__init__.py
5889f4cb2010a42a5d03706dca477b0a /usr/lib/enigma2/python/Components/Renderer/Picon.py
aa1249c9a1ce56691a227df891da902b /usr/lib/enigma2/python/Components/Renderer/FrontpanelLed.py
1d37518d1e9e86746b3167f8aaed0945 /usr/lib/enigma2/python/Components/Renderer/Renderer.py
6395adaf7ec9bd78244c6f24baf7489f /usr/lib/enigma2/python/Components/Renderer/Listbox.py
307cbe1c7396024115dbf83e5b77ef53 /usr/lib/enigma2/python/Components/Renderer/Pig.py
7779d00ec0633251a4b83020ef55551a /usr/lib/enigma2/python/Components/Renderer/Label.py
7dcaf7bebd1b96408b3b13f90a61d512 /usr/lib/enigma2/python/Components/Renderer/PositionGauge.py
0660039b7b6e30b0f2274b222ead3741 /usr/lib/enigma2/python/Components/ConditionalWidget.py
12c6615981e9b43e60c328fbc6fccffa /usr/lib/enigma2/python/Components/TunerInfo.py
4bb6712fcb467e24fbe9f4aec3ca4f0a /usr/lib/enigma2/python/Components/FIFOList.py
11000ec9591b9e5a9f5bed4037d2c91f /usr/lib/enigma2/python/Components/VolumeBar.py
4e8cb8eab18839f731ce14062e3c54d6 /usr/lib/enigma2/python/Components/MediaPlayer.py
bc97eb5963b13419cfe4f1d9dc4a7c6f /usr/lib/enigma2/python/Components/DreamInfoHandler.py
9ff38d1fbf23999885065144d273019f /usr/lib/enigma2/python/keyids.py
7a421281bce9b3cf7eff19fa38846588 /usr/lib/enigma2/python/Screens/Ci.py
1d812b4508da64c54eaf3aafe30eb1c5 /usr/lib/enigma2/python/Screens/Rc.py
07285289a6ed32043cd97aa9104e3673 /usr/lib/enigma2/python/Screens/About.py
8b6a8d2bd01d6f5e7f16dd47ace0d781 /usr/lib/enigma2/python/Screens/Subtitles.py
97df74fc6b9b85c68624ef71e18177a1 /usr/lib/enigma2/python/Screens/SubservicesQuickzap.py
ea3df01e230dfb0e76fe1f6b8755b247 /usr/lib/enigma2/python/Screens/TimerEdit.py
b5bc1d71a6b661898d46e07c8152d592 /usr/lib/enigma2/python/Screens/Ipkg.py
5e5b87e548b931e3af22f9402e4b57c3 /usr/lib/enigma2/python/Screens/VirtualKeyBoard.py
601db3ba6eb9a5f6217740c4d51dfbd0 /usr/lib/enigma2/python/Screens/InfoBarGenerics.py
616e4f5f8d67699c3564ac495ea4e091 /usr/lib/enigma2/python/Screens/ClockDisplay.py
2fbb9c8d85a3144ac01a5d09e5219a6e /usr/lib/enigma2/python/Screens/TutorialWizard.py
74dcf98e11a972d249ce5fd011b97cb8 /usr/lib/enigma2/python/Screens/SimpleSummary.py
c764df2104c9ef9f0f4fe6ff54b55d9b /usr/lib/enigma2/python/Screens/LanguageSelection.py
675e86c36c61c9174237b27b2d39aea1 /usr/lib/enigma2/python/Screens/Screen.py
a6c418ca660943e42fa2b2c72b8c2f7e /usr/lib/enigma2/python/Screens/FactoryReset.py
5c995a40de39886c79d9fe3c3d45d7f7 /usr/lib/enigma2/python/Screens/RdsDisplay.py
6b68c3e2070a4cadf05548549a43c785 /usr/lib/enigma2/python/Screens/Globals.py
ca0361953b30f5fc919c4b77abfca0fb /usr/lib/enigma2/python/Screens/TextBox.py
262b973b6346f1669ad83e2c67400a09 /usr/lib/enigma2/python/Screens/PVRState.py
e25a76cb782a927e20c7fa533a5db6fc /usr/lib/enigma2/python/Screens/Standby.py
c5c0ac1908fd39967894d1044d32520f /usr/lib/enigma2/python/Screens/RecordPaths.py
1caf3058700bdc87bc00c54f2a85eceb /usr/lib/enigma2/python/Screens/NumericalTextInputHelpDialog.py
cc48e2abc02be6319485ae5987791ebf /usr/lib/enigma2/python/Screens/Menu.py
abd5944eaa8c6af6d6e15c0e06fa1934 /usr/lib/enigma2/python/Screens/NetworkSetup.py
cfac1258e71864b1ce1e0874fd70d854 /usr/lib/enigma2/python/Screens/LocationBox.py
586378f913a22adf52d797d07007e082 /usr/lib/enigma2/python/Screens/MovieSelection.py
10cd614b1406b23db42fe1089e68f02d /usr/lib/enigma2/python/Screens/AudioSelection.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Screens/__init__.py
15b19e6f30826c97c7fdfe0b35ad71c2 /usr/lib/enigma2/python/Screens/UnhandledKey.py
2c371a88055a052e82401b97646771e5 /usr/lib/enigma2/python/Screens/Mute.py
910794de58e03cb7a9e68b5b15900fd5 /usr/lib/enigma2/python/Screens/InputBox.py
494d95e3c66df7ead1bf1adb38f7d2b1 /usr/lib/enigma2/python/Screens/Scart.py
f09c91475b4d47bac3112605a1d520e1 /usr/lib/enigma2/python/Screens/InputDeviceSetup.py
f49c2918da9b1870bac153faa8717f91 /usr/lib/enigma2/python/Screens/TimeDateInput.py
4b4246ba0ca9bf6b3f9ea8cf788dc7aa /usr/lib/enigma2/python/Screens/ServiceStopScreen.py
36e0fcf670092264a9f0aaed484ae119 /usr/lib/enigma2/python/Screens/ScanSetup.py
fce834ae8afec7499040564ca0fbc769 /usr/lib/enigma2/python/Screens/ChoiceBox.py
9e74b7dc6b09beedc90c65e6d1c9a4f0 /usr/lib/enigma2/python/Screens/ServiceScan.py
21b0cca3002cf88fa8868bce113ab96c /usr/lib/enigma2/python/Screens/SessionGlobals.py
d501bc67ff36572c521ab3bd01da6cca /usr/lib/enigma2/python/Screens/WizardLanguage.py
d7b2206ccd0121f068b0cad666dd65f3 /usr/lib/enigma2/python/Screens/InfoBar.py
524fa9ce443eae4668e581cb996f7364 /usr/lib/enigma2/python/Screens/Console.py
5c836403cce8a029cdec5afa8538eb3c /usr/lib/enigma2/python/Screens/PiPSetup.py
4c7cdc559cb51a0281d41d4a3da63592 /usr/lib/enigma2/python/Screens/StartWizard.py
3c44a1bb0a6687a3e8c4decd65b9fa43 /usr/lib/enigma2/python/Screens/MinuteInput.py
e7bc2feca9f12a9169bc74c79d034e65 /usr/lib/enigma2/python/Screens/TimerSelection.py
0483593598ac40874d9835af4f481f4f /usr/lib/enigma2/python/Screens/PluginBrowser.py
fafa8e1cdfb5c7994ec52f7a627e58bd /usr/lib/enigma2/python/Screens/HelpMenu.py
b0b2b95a755c5d9d15975fe028821f3e /usr/lib/enigma2/python/Screens/EventView.py
9fd6f2768180b538d3f35ce3e8cebcab /usr/lib/enigma2/python/Screens/SubtitleDisplay.py
847c257750e4fe93757b8b617d23afe6 /usr/lib/enigma2/python/Screens/Wizard.py
bccc795a82aab24bd114c264706fedeb /usr/lib/enigma2/python/Screens/TaskView.py
db2cc254ebc1a2806ad768c670bbd22b /usr/lib/enigma2/python/Screens/MessageBox.py
e59f49df2e8ff48a45fc865e24e63308 /usr/lib/enigma2/python/Screens/PictureInPicture.py
a1887da61746d8c7b190c1f9a6f79a5e /usr/lib/enigma2/python/Screens/Dish.py
03a45a3ec6fa65949569006c7f268909 /usr/lib/enigma2/python/Screens/Setup.py
2690da67e19ff3dc9c5bf2e9674c3353 /usr/lib/enigma2/python/Screens/ParentalControlSetup.py
202a551180e1dfdcf4e7ae135d8de685 /usr/lib/enigma2/python/Screens/EpgSelection.py
32afe8c8ca5e3bb865af86a296951d12 /usr/lib/enigma2/python/Screens/DefaultWizard.py
3ab0443a3d9581e7cdd17b4d1fc819c2 /usr/lib/enigma2/python/Screens/ChannelSelection.py
2026309d4bb26a778822e85541918335 /usr/lib/enigma2/python/Screens/Volume.py
d8ab85121817e311e336d530942f4e0c /usr/lib/enigma2/python/Screens/FixedMenu.py
30ace57c455e7f9755a5d1738671ba62 /usr/lib/enigma2/python/Screens/ConfigMenu.py
5190df554072e88200859f8c99096837 /usr/lib/enigma2/python/Screens/ServiceInfo.py
e5a84350b94e7e7c27dc57fcd00dff1c /usr/lib/enigma2/python/Screens/TimerEntry.py
372ed995725f003f56e3f231e0b3636c /usr/lib/enigma2/python/Screens/HarddiskSetup.py
a25013df9955e2429f2370543d4c721c /usr/lib/enigma2/python/Screens/SleepTimerEdit.py
aeab2785c1ada02f25a641d0d6e763f9 /usr/lib/enigma2/python/Screens/Satconfig.py
943167eb90dc3145e1b9f61dbd098c3b /usr/lib/enigma2/python/tools.py
27d752afe9f1f12d9732f09b6122ce3b /usr/lib/enigma2/python/mytest.py
3ca804f1c54bd4faaa654ebbe1c07795 /usr/lib/enigma2/python/keymapparser.py
</pythonMD5sum>
</crashlogs>
</opendreambox>
Thank you
Just run a quick test,,,and its true Duo will not switch to recording channel quickly , and a message will appear that says its failed to recored , however if U wait for a few seconds , while the message disappear , the Vu Due will switch and zap to the channel desired, and start recording that channel U selected @the timer!
Try that and see!
in this version of BH sometimes the hdd still works when the setup time of rest has passed,I have put to rest 10 seconds but sometimes still running, before other versions worked fine, i don´t know if it´s a bug of this image or is a problem that only affects me and maybe i have to reflash with the same image...
thanks...
would it be for any plugin installed?
i think is not the cause because when it´s running i go to blue-blue-hard disk settings-red(standby now) and the hdd stay in standby for a longtime but after i use the hdd it continuos running during hours...
regards..
thanks...
No,it is not BUG. For me all work fine. Try to reflash image.
i have reflash and the problem continues,for example when you enter blue-yellow(system info) the hdd starts working but does not stop after that.
I have advised because it can be dangerous to put the decoder in standby and the HDD without fan running for hours
thanks and regards.
thanks and regards.
Do not afraid for HDD, can not burn out.
