BlackHole Vu+ Duo 1.6.6
As an example, see how at the bottom right hand side of this screen we get to to see what is next for that channel. Which skin for BH VU= Duo will show that.
I donot remmber someting like that!
Its a good Idea!
May be BH skin Masters,,,can clear the issue!
RgdZ
a911
Hi,
I installed bh 1.6.6 on internal flash. after that I tried to install bh 1.6.6 on usb using meoboot but kept on having green screen when a booted to bh 1.6.6 on usb flash. same happened when i tried to install latest nfi vti image.
is meoboot working for bh 1.6.6
tia
Hi,
tia
It means the file did not install correctly in to meoboot!
Make sure the file is ok , then install normally,,,,and wait for complete installation,,,it may take more than 5 mints!
The USB (as external flash) should be clean formatted then mount with device manager.
I recommend to search the forum ,there are few hints for proper installation,,,and more!
attache the crash log,,,lets see it!
RgdZ
a911
BlackHole Vu+ Duo 1.6.6​
Warning: YOU MUST UPDATE DUO BOOT LOADER (duo_cfe_3_0_usb.zip) BEFORE TO FLASH THIS IMAGE: How To Update Bootloader​
- New Skin Rihanna 5 by Matrix10​
- Extended Hdmi-Cec functions (thanks to Meo, Pieterg & Sjaaki)​
- Crossepg updated from https://github.com/organizations/E2OpenPlugins (thanks to skaman)​
Based on official image 6.0:​
Open Embedded​
- Add WebBrowser plugin(Duo/Uno, Duo needs a bootloader update)​
- Add UI postion control plugin​
- Add 3D framebuffer control plugin​
- Add remote control system code control plugin​
- For details, please take a loot at git log.​
Driver update​
20111006​
- improve DVB-C/T tuning(uno)​
- Fix incorrect display of DVB-C/T SNR/AGC(uno)​
- Fix high-bitrate problem in CI​
- Support 3D framebuffer​
- Add interface for UI position setup​
- Add redundant fpga device at /dev (uno)​
- Add ioctl for hdmi_cec(get physical/logical addr.)​
- Fix audo mute in pass-through(uno)​
- Add interface to set the system code of the remote control(uno)​
- Add interface to disable REC VFD icon(uno,duo)​
- Add interface to control global alpha​
DUO Boot loader update(duo_cfe_3_0_usb.zip)​
- Increase update file size up to 128M Bytes​
- Change the flash memory map(kernel size : 4M, /boot : 2M)​
* Delete the cfe_cfe_auto.bin at /vuplus/duo in USB after update is complete.​
WARNING: This Image has the latest drivers and CAN NOT be installed in multiboot.​
The image MUST be installed in the flash.​
Black Hole can not support images not installed in the flash.​
Please note that of all images Black Hole now has the best epg system:​
- Integrated OpenEpg​
- Rytec dedicated epg.dat​
- New system epg.dat outside.​
This last feature gives the possibility to various forums or communities to create their favorite EPG data files and load them into a web space.​
Community members can then download it from our servers.​
This feature provides other benefits such as:​
Increase download speed of EPG​
Download EPG from any channel​
Schedule the download of EPG decoder even during standby​
Users can customize the providers using Add / Remove function​
OK button = Skin with simple information​
OK button x 2 = Extra Info Skin​
Blue button = Black Hole Blue Panel​
Blue button and then Red button = Black Hole Epg Panel​
Blue button and then Yellow button = System Monitor Panel​
Blue button long press = Extensions​
Yellow button = Time Shift​
Green button = Black Hole Green Panel​
Green button long press = Subservices​
Green button and then Red button = Fast Plugin Setup​
Green button x 2 = Fast Plugin​
Button Red = Start Record​
Addons​
Green button and then Yellow button takes you to:-​
Dedicated server for BlackHole addons​
Download and install additional packages from the Black Hole server​
Infobar / OSD​
Analog Clock Gui​
Channel orbital location​
Advanced Tuner Info: Sr Freq Pol Fec​
Signal SNR, BER​
Infobar picons​
Characteristics of BlackHole Panels​
Blue Panel​
Extra Settings​
Black Hole Cron Manager (Manage schedules)​
OSD Settings (OSD configuration)​
Devices Manager​
Black Hole HDMI Cec​
Manager Kernel Modules (Kernel module operator)​
Inadyn Settings (Configure Inadyn)​
Swap File Settings (Configure File Swap)​
Hard Disk Settings (Configure Hard Drive)​
Black Hole Mount Wizard (Mount points)​
OpenVPN Panel ( OpenVPN Panel)​
Samba / CIFS Panel ( Samba Panel)​
NFS Server Panel ( NFS server Panel)​
Telnet Panel ( Telnet Panel)​
FTP Panel ( FTP Panel)​
Usb Tuner Panel​
UPnP Client Djmount​
UPnP Server Mediatomb​
Info Panel​
1 - Gui Setting (Gui configurations)​
2 - Service Information (information system)​
3 - About (info)​
Memory (Memory)​
Space (capacity)​
CPU (processor)​
Process (process)​
EPG Panel​
Global settings (global settings EPG)​
Setting Provider (ISP settings)​
Green Panel​
Addons (added)​
Addons Download Manager (Manager for package downloading)​
Installation manual packages (Manual installation of Black Hole packages)​
Manual Install IPK packages (Manual installation of IPK packages)​
Addons Uninstall Panel (Uninstalled packages)​
Black Hole Statistics (See connections, top downloads and more)​
Credits​
Thanks to the group of Beta Testers.​
Thanks to Rytec for providing us with the server with all epg.dat files.​
Thanks to MaxZ4 for Integrated EPG loader.​
Thanks to Skaman for Cross EPG​
Thanks to Lukkino (VDR-Italy) for the source code of OpenTV.​
Thanks to Reinh@rd for the file satellites.xml.​
Thanks to bigroma (vuplus-community board) for rt3070 patches.​
DISCLAIMER​
THE BLACK HOLE IMAGE IS BASED ON THE OFFICIAL FIRMWARE PUBLISHED BY VU+ AND IN ACCORDANCE WITH THE LAW IT CONTAINS ONLY SYSTEM ADDITIONS & GRAPHIC CHANGES.​
LASTLY, THE BLACK HOLE IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR IILEGAL PURPOSES SUCH AS CARD SHARING.​
LICENSE (TERM OF USE)​
ANY CHANGES OR ADDITIONS TO BLACK HOLE IMAGE THAT INVOLVE UNLAWFUL USE OF THE IMAGE SUCH AS CARD-SHARING AND EMULATORS ARE NOT ALLOWED AND CAUSE THE REVOKE OF THIS LICENSE.​
Hi lorenzo64,
It could be possible to modify the setting of the webinterface and in particular the proprietis of the streaming in order to allow the direct streaming over the internet from our Vuplus?
Many thanks
I've found a little bug with listing movie files through web interface, it wont list up the list of recorded movies if you download a movie through My TubePlayer until you delete them again.
Hi lorenzo64,
Many thanks
The Web Interface plugin is not made by Black Hole team.
Therefore, this isn't the right place to report bug or to request new features.
Hi everybody.
What's the best way to a "clean" uninstall "Web Browser"?
It's just deleting it at "usr/lib/enigma2/python/Plugins/Extensions", or it's better a telnet command?
In what pastes and what files are Web Browser history and cookies?
I just want delete Web Browser to have more space in flash.
Hi everybody.
Hi my friend,
I use *******...." Remove plugin folder" tool!
I think that will remove every things related to that folder,,,its Easy & Quick!
RgdZ
a911
Hi everybody.
yes, have the web browser as a plugin in the future can be a good idea ;)
or 2 versions: with and without it, but looks more complex
Help, please.
I have tryed to upload a tar.gz file in tmp-folder. I can´t install it from the box. What am I doing wrong?
You should be able to install it by BH Addons Manager.
Menu > Addons Manager > Manual Install BH packages
Help, please.
To manual install packages file must have _bh.tgz extension.
Be careful to install BH compatible plugin or you risk to break your img.
