BlackHole Vu+ Duo 1.6.7 kernel 3.1.1 beta2
I have to say big thanks for BH team for they hard work.
Seems that everythings started work correctly after I have loaded EleganceHD_P2 skin.YouTube ... Since morning I haven't had crash yet.
I have a big problem with webbrowser, when I press Green it opens the Vu+ page and can move the cursor but the yellow button doesn't respond and cannot see the virtual keyboard. How can I have the virtual keyboard. Thanks.
This is looking good, but twice now I have added a timer recording and they have been "empty". First time the recording was 4 seconds and the second time it was 0 seconds.. Is this a known bug in the beta 2 or?
Regards,
BTJ
Thanks for the explanation.
Of course we prices a good test report
We want to have an objective test results
because it is the only way that together we make a better image.
The problem arises when someone reported a bug that We can not confirm in our tests.
In most cases it is subsequently installed plugins e.t.c that cause these problems or misconfigurations.
So i always stress the need to test first clean image,
that we can have real bugs.
This bugs most needs to be solved with the help of the VuPlus.
With plugins situation is different.
In many cases, users address the teams and not the plugins authors .
it's not good is wrong, for the solution of the problem.
We now move to the new kernel and of course some things have to re-tune
But globally this new image is a big step forward.
could you point me in the right direction im going to have a go at putting it on.
If this refers to the method of testing image.
This is simply
Test clean image without adding
and write down all the bugs and problems that are directly related to the image.
Of course it is good to know if there are bugs in plugins
we do not intend to change their coding ,because they have their author.
But it is good to know if there are bugs in them.
Rgd MX
sorry but i tested 1.6.6 and 1.6.7 and neither would even load onto my box i tryed everything had to start again and install 1.6.5
PLEASE YOUR HELP
I tried webbrowser only the first time that was released and the virtual keyb was working.
Try to press some other botton to see if you manage to open virtual keyb.
Dear Tamaki,
Tryed to press all other botton, but without sucess!!!!!!
Please check from your side.
