Final version come out when Vu+ release a new Official Image (as usual) but we have the pleasure to publish some intermediate (stable) images for everyone to make tests and report works and non-works parts
The new kernel needs a lot of testing
I JUST COULDNT GET THIS IMAGE ON MY BOX HAS 1.6.5 AND WHEN I TRYED MY USUAL FLASHING WAY I WAS HAVING NO JOY. I KNOW THERE IS A DIFFERENT WAY OF DOING THIS IMAGE BUT I DONT UNDERSTAND WHEN I READ ABOUT HOW TO DO IT.COULD ANYONE EXPLAIN IT BETTER FOR ME OR DO YOU THINK I SHOULD JUST WAIT TILL A NORMAL FLASH IMAGE COMES OUT????? IE VULPLUS/DUO USB...............
First thing: doesen't write UPPERCASE.
Before put into your DUO the 1.6.6 or newer image you MUST upgrade DUO CFE. Be careful: DUO CFE IN DUO BOX.
After you have upgraded CFE, you can flash newer images as usual.
Button Mappings
I thinks these are the maping that I would love to have on the next BH image..... Short Red** & *** - Show current channel EPG info (Single EPG).
Long Red*** - Show current event.
Short Green** & *** - Timers.
Long Green*** - AutoTimer Timers.
Short Yellow*** - EPG Search.
Long Yellow*** - IMDB Database.
Short Blue - Extensions.
Long Blue*** - Plugins Menu.
EPG - Opens EPG.
Left/Right** - Opens QuickEPG.
Up/Down** - Open Full Screen Channel List.
Long Up/Down** - Open Simple TV List.
TV Button** - Open Full Screen Channel List.
Long TV Button - Open Bouquets List.
Button Mappings I thinks these are the maping that I would love to have on the next BH image.....
EPG - Opens EPG.
Blackhole won't change it's defaults.The main reason why so many people likes BlackHole because the way it is.
I personally love BH as it is...
Runing 1.6.7 for a fourth day -rock solid.
Big Thanks for your great work.
I have a problem. After a few min then i play HD movies on my hdd the pic go to stop .I don't have this problem with 1.66 image.
I have strange issue. After starting, if I selected any channel then vu+ duo doesn't respond to remote control, but with web interface I can change channels.
Image BH 1.6.7 installed into internal flash.
My config:
config.Nims.0.configMode=advanced
config.Nims.0.advanced.sats=360
config.Nims.0.advanced.sat.360.lnb=1
config.Nims.0.advanced.lnb.1.increased_voltage=true
config.Nims.0.advanced.lnb.1.fastDiseqc=true
config.Nims.0.advanced.lnb.1.threshold=10750
config.Nims.0.advanced.lnb.1.lofh=10750
config.Nims.0.advanced.lnb.1.lofl=10750
config.Nims.0.powerMeasurement=false
config.osd.language=ru_RU
Beautiful image as usual from Bh Team!Running BH 167 beta2 for 3 days and all is great. But i do have 2 problems. I always get green screen and crash when i press blued yellow button to get info about the box. Second problem regards recordings. I set up a timer several times and both times the recording stopped before the timer ended. Never had any problems with recordings before and i've been using BH images since beggining. Thank you for your dedication!
