BlackHole Vu+ Duo 1.6.7 kernel 3.1.1 beta2
Here are the last 2 green screen from tonight. Have had lots of those crashes today....might be fromCrossepg providers?
First crashlog is related to DD plugin (i think it's a subtitle plugin):
File "/usr/lib/enigma2/python/Plugins/Extensions/DD_Subt/plugin.py", line 1547, in layoutFinished
File "/usr/lib/enigma2/python/Plugins/Extensions/DD_Subt/plugin.py", line 1576, in radi
File "/usr/lib/enigma2/python/Plugins/Extensions/DD_Subt/plugin.py", line 1681, in zaSrt
File "/usr/lib/python2.6/encodings/cp1250.py", line 15, in decode
return codecs.charmap_decode(input,errors,decoding_table)
UnicodeDecodeError: 'charmap' codec can't decode byte 0x83 in position 57278: character maps to <undefined>
(PyObject_CallObject(<bound method priprematitla.layoutFinished of <class 'Plugins.Extensions.DD_Subt.plugin.priprematitla'>>,()) failed)
The second it's very strange and it's related to something of our Informational Panel.
Start with a CLEAN image and test Info Panel FIRST and then add plugin you need one at time and discover the one who cause the problem.
Problems with the Info panel
can be ,if the memory is full
reduce the number of EPG providers ,addons e.t.c, or attempt to use the SWAP
can someone explain in detail how to do this,i am well aware by now that there is somthing different to do before putting this image on but the setups guides out there are not simple for me to follow or should i say i personally dont undertsnad,could someone explain how to do this????please
ONLY for VU+ DUO
http://archive.vuplus.com/image/2011/6.0/duo_cfe_3_0_usb.zip
1.Format USB stick on your PC FAT32 format
2. Unzip the duo_cfe_3_0_usb.zip to USB stick.(There should be /vuplus/duo/cfe_cfe_auto.bin) .
3.Disconnect everything else connected to the USB ports VU+Duo
4. Insert USB stick into the front USB port of duo and power on the box.
5. It takes just a few secs to update.
6. If Duo displays the message "Finished..reboot", remove the USB stick and restart box.
7. Format again USB stick on your PC FAT32 format
8.Unzip BlackHole-1.6.7-bm750_usb.zip (download from first page) and copy to your USB stick (There should be /vuplus/duo/and 3 files)
9.Disconnect everything else connected to the USB ports
10.Insert USB stick into the front USB port of duo and power on the box.
11.If Duo displays the message "Finished..reboot", remove the USB stick and restart box.
Attention flash and bootloader updates are always on the personal responsibility
If something goes wrong.
MX
My box always has green screens when I try to view the Info Panel when using the Brushed Alu-HD skin, but not with the default skin. Apart from the previously noted problem of freezes when viewing recordings on the hdd, I have not had any other problems in the week that I've been using this image. Excellent work, Matrix10!
Brushed Alu-HD skin is not skin made ​​for our image and therefore you have a green screen.
I read that some have this problem.
This is a job for VuPlus
I think it would be fix in the following versions
Rgd MX
This is the best image since many months, the last releases did have some problems with usb DTT, seems that these problems are over now. All my USB tuners are working again like in the old days. Thx team. :thumbup::thumbup:
Remember to manual instal the newest 3.1.1 drivers to have Wlan working again.
Just missing a working personal backup . It is not compatble with the new firmware.
Beautiful image as usual from Bh Team!Running BH 167 beta2 for 3 days and all is great. But i do have 2 problems. I always get green screen and crash when i press blued yellow button to get info about the box. Second problem regards recordings. I set up a timer several times and both times the recording stopped before the timer ended. Never had any problems with recordings before and i've been using BH images since beggining. Thank you for your dedication!
The problem with recording stopping before if should was the same I had... Is this a beta image problem or a vu+ driver problem?
BTJ
Dosen't work for me, no picture or sound when change channel, tried 1.6.5 works fine, then 1.6.7 same problem, have to restart to see the channel with sound.
Did U update the boatloader?
Did U fallow MX10 post#144 (up)!
You understand me wrongly I said Barry Allen still not release one working good with lates kernel
You should explain to your self next that explained to me
I know what I do Mate
Try Elegance HD P2 from blackhole addons server.No any crashes related to that skin at all.
