BlackHole Vu+ Duo 1.6 Graphics preview
Hi
I have difficulty in Show Time
Skin Change this problem is not resolved
What are your comments?
Info abt MHW2 providers in CrossEPG (DIGITAL+)
we have found
an incompatibility between the crossepg paths and Black Hole epg paths.
This problem will be fixed in the next release or image upgrade.
In the meanwhile the problem can be solved editing enigma2 settings file.
/etc/enigma2/settings
but after the CrossEPG configuration in Setup Menu >>CrossEPG>>Configure>>USB Stick
and BH Epg configuration in BlackHole Blue Panel (blue button) >>red button>>
>>Red button>>path to save Epg File >>/media/usb/epg.dat
if you using USB stick
NOW
Edit the following line in the settings file (/etc/enigma2/settings) if you using USB stick
config.misc.epgcache_filename = /media/usb/crossepg/epg.dat
and replace with
config.misc.epgcache_filename = /media/usb/epg.dat
Now from telnet
Give the following commands
and after command
Now you can use CrossEPG MHW2 providers.
I have test only with USB stick ,I think it's similar with hdd.
Rgd MX
You can see AC3+ here:
<a target='_blank' title='ImageShack - Image And Video Hosting' href='http://img823.imageshack.us/i/screenshotca.jpg/'><img src='http://img823.imageshack.us/img823/1955/screenshotca.jpg' border='0'/></a>
Uploaded with <a target='_blank' href='http://imageshack.us'>ImageShack.us</a>
On future, upload image directly on board :)
I will modify your post for you, now.
Have you the possibility to connect your box to an amplifier with HDMI connection like the one on my signature?
Hi!
Thanks for your great job!
The image has a mistake, because the DD+ doesn´t work.I can see the audio at audio selection menu, but no hear anything.
Regards from Spain!
