BlackHole Vu+ Duo 1.6 Graphics preview
No, on previous imagen neither can hear anything nor can see the audio DD+ on at audio selection menu.
Excuse me my poor english.
No Problem.
I think that this kind of audio track is correctly detected by a home theatre system or an HD amplifier via HDMI connection and the "Digital downmix" option disabled.
I cannot try this theory personally :(
On future, upload image directly on board :)
I will modify your post for you, now.
Have you the possibility to connect your box to an amplifier with HDMI connection like the one on my signature?
Thanks, I haven´t privileges for modify my posts...
I´m back to my backup of bh 1.5.1 totally configured. Tomorrow I will installed the 1.6 image and tried again with my home theatre system.
Thanks for your job again!
Info abt MHW2 providers in CrossEPG (DIGITAL+)
we have found
an incompatibility between the crossepg paths and Black Hole epg paths.
This problem will be fixed in the next release or image upgrade.
In the meanwhile the problem can be solved editing enigma2 settings file.
/etc/enigma2/settings
but after the CrossEPG configuration in Setup Menu >>CrossEPG>>Configure>>USB Stick
and BH Epg configuration in BlackHole Blue Panel (blue button) >>red button>>
>>Red button>>path to save Epg File >>/media/usb/epg.dat
if you using USB stick
NOW
Edit the following line in the settings file (/etc/enigma2/settings) if you using USB stick
and replace with
Now from telnet
Give the following commands
and after command
Now you can use CrossEPG MHW2 providers.
I have test only with USB stick ,I think it's similar with hdd.
Rgd MX
grande matrix10,:thumbup:
saludos.
Angelofosky, here in Spain, never hear it with Vu+......NEVER!! :eek:
However, straming to PC, DD+ is OK, before IMPOSSIBLE!!
Any ideas?
THANKS VERY MUCH FOR YOUR WORK!!
respect for the team black hola, thank you for your work:thumbup:
my question
Have you ever image will be updated online?
Angelofsky,
Thank you very much for the great Black Hole 1.6! But I have a problem with the epg for the channels received by Polish Rytec_Poland - do not display Polish characters. Will it be fixed?
Angelofsky,
You should ask to skinners Matrix10 & Army for this kind of requests :)
Matrix10 & Army,
saludos.
But pls you must not change agn configuration in CrossEPG in >>Configure
after your have edit/change settings file
otherwise CrossEPG will again change path
in settings file,And then you have to make all again.
we have to wait for a real fix from our coder
