BlackHole Vu+ Duo 1.6 Graphics preview
Thanks for the update, but the image is still a major bug. In some reboots is removed usb or cf, where are picons. It appears as mounted but not working. After a hard reset works again. I think it is time that works well.
Greetings
A USB stick problems there are many posts on the forums.
Firstly it has nothing to do with the image but with the type of USB stick
and drivers for VU
Every USB stick does not work well with VU.Try another USB stick.
If you do not use a USB stick for Multiboot
use only FAT32 format and do not not format usb stick with BH device manager, but only make a mount.
If you use the USB stick for Multiboot with MeoBoot and you have a image boot problems
make two partitions on a USB stick ext3 (because you need ext3 partitions for Multiboot) and FAT32
I wrote about it here
http://www.vuplus-community.net/board/threads/meoboot-short-user-guide.1899/#post-18869
@Fandos
I have read your post abt DVB-T
poor DTT signal in comparison with earlier versions.
I can not agree with it because I tested
in any case signal is neither worser nor better than before
with my AverMedia DVB-T
I have all the same as before,number of channels I receive is the same
there is absolutely no difference and now I can see the signal strength.
FYI
USB DVB-T Hauppauge wintv nova-td DUAL TUNER stick perfettamente gestita dalla BlackHole-1.6-bm750 con tanto di rilevazione S/N correttamente funzionante.
Fpippo
FYI
Fpippo
Thanks for report, but next time remember to write in English in this section.
Image Upgrade BH 1.6b CrossEPG FIX
and EPG backup FIX on image server
(Black Hole Plugins panel)
Info
To avoid any confusion
On our server's name changed to Upgrade
for VU duo
Upgrade VU DUO BH Img 1.6.0
This upgrade contains a fix for CrossEPG
and BlackHole EPG Backup.
I do not know what is the problem ,Im sorry I do not know Polish
This can be a problem in the EPG that uses a different code table
In this case it is not a problem of the skin and image but fonts code table
Are the letters/fonts in the image menu and panels OK with Polish language ??
if you've tried it with different skins and with Polish language in the image ??
Thank your for this new image. Could we normally install ****** on this version ? Because since the version 1.5 the installation of this ******* was impossible.
Best regards,
