BlackHole Vu+ Duo 1.6 Graphics preview
Matrix10 & Army,
I have a problem with the epg for the channels received by Polish Rytec_Poland - do not display Polish characters. Will it be fixed?
I do not know what is the problem ,Im sorry I do not know Polish
This can be a problem in the EPG that uses a different code table
In this case it is not a problem of the skin and image but fonts code table
Are the letters/fonts in the image menu and panels OK with Polish language ??
if you've tried it with different skins and with Polish language in the image ??
jejeje, we are ¡¡¡los mejores!!!, jejeje.
A ver si arreglamos ese AC3+ Matrix, que hay que watch TVEHD with AC3+.
Regards!!!
ok, no problem Matrix10 is not the same as between a black man to the finish line first, to a black target you first, lol
Greetings.
Matrix10 & Army,
I have test now some channels on Cyfra +
seems to me there's all OK
I have test Polsat there is EPG wrong/bad for some
TV programs
but it is not image and skin problem
but bad EPG file.
I have test Polsat sport ,I think OK
I have test with one of my skins and Polish in the image.
but I do not know all Polish fonts/letters
Hi
I have difficulty in Show Time
Skin Change this problem is not resolved
What are your comments?
? you no made any changed in files called setting in enigma2 folder if you block read time from tranponder you will be no see good time .
TV programs
but bad EPG file.
Today it's working EPG (Rytec_EPG) perfectly. They already are the Polish characters. Thank you again for the great work and great Black Hole 1.6!
Thanks for great work.
Crosepg not working for me,reason ? On integrated epg not work D+...
CrossEPG working
If you have problems look in CrossEPG log
if you have EPG on USB stick
you have log in /media/usb/crossepg/crossepg.log
(maybe the server is not working, etc.)
You can delete log before download so you have new log file.
You can try to delete all crossepg.tmp..... files
and also epg.dat and ext.epg.dat in /media/usb/crossepg/
Restart E2 and try agn to download.
You can look in /etc/enigma2/setting if you have good path
for your epg file
for standard USB epg
config.misc.epgcache_filename=/media/usb/crossepg/epg.dat
for D+ MHW2 mod Cross EPG (read my earlier posts)
config.misc.epgcache_filename=/media/usb/epg.dat
Integrated D+ BH epg not working probably because the file on Rytec server is not good.
Use crossEPG XMLTV/XEPGDB for D+ or MHW2 D+ ,For MHW2 D+ EPG read my earlier posts.
Info abt MHW2 providers in CrossEPG (DIGITAL+)
we have found
an incompatibility between the crossepg paths and Black Hole epg paths.
This problem will be fixed in the next release or image upgrade.
In the meanwhile the problem can be solved editing enigma2 settings file.
/etc/enigma2/settings
but after the CrossEPG configuration in Setup Menu >>CrossEPG>>Configure>>USB Stick
and BH Epg configuration in BlackHole Blue Panel (blue button) >>red button>>
>>Red button>>path to save Epg File >>/media/usb/epg.dat
if you using USB stick
NOW
Edit the following line in the settings file (/etc/enigma2/settings) if you using USB stick
and replace with
Now from telnet
Give the following commands
and after command
Now you can use CrossEPG MHW2 providers.
I have test only with USB stick ,I think it's similar with hdd.
Rgd MX
Thanks a lot Matrix, the same happens for me using OPENTV and XMLTV providers. Epg.dat gets saved in media\usb\crossepg\epg.dat but of course is not loaded. I manually moved it in media\usb\epg.dat, did a manual reload and it worked. So I think your fix applies to all EPG types and not just MHW2. Btw I logged this bug on crossepg.com but is it a bug with BH image or Crossepg?
Thanks a lot again!!!
No
I think like this,
XMLTV/XEPGDB being directly in memory
and later returned to the /media/usb/epg.dat (reboot/restart returned)
So no problems there.
Problem is with MHW2,MHW go to epg.dat
BH image use standard paths for epg ../usb/epg.dat and .../hdd/epg.dat
CrossEPG uses its no standard path /media/usb/crossepg/epg.dat
p.s I have not test CrossEPG OPENTV providers
To repeat once more because there are still providers that do not work without these changes
we have found
NOW
config.misc.epgcache_filename = /media/usb/crossepg/epg.dat​
and replace with
config.misc.epgcache_filename = /media/usb/epg.dat​
Now from telnet
Give the following commands​
init 4​
and after command
init 3​
Now you can use CrossEPG for all providers.
I have test only with USB stick ,I think it's similar with hdd.​
Rgd MX​
After these changes do not go into CrossEPG>> Configure
Otherwise you have to do all over again
Thanks for the update, but the image is still a major bug. In some reboots is removed usb or cf, where are picons. It appears as mounted but not working. After a hard reset works again. I think it is time that works well.
Greetings
I do not spend what you say of picons provided an come to me first and I have them in usb and montados.
saludos;)
