lorenzo64
BlackHole Vu+ Solo v. 1.4.4 Multiboot
WHAT'S NEW?
- New Skin Army unica
- lbdreamdvd updated
- Added ntfs-3g (to mount ntfs drives in read/write)
- Added usb wifi RT3070 chip support
- NEW NEW NEW FULL UPnP and Dlna support added:
MEDIATOMB SERVER
DJMOUNT CLIENT
BLACK HOLE IMAGES OFFERS NOW THE BEST SOLUTION FOR BOX CONNECTIONS TO SHARE MEDIA FILES IN HOME NETWORK.
NOT NEED CONFIGURATIONS NO NEED MOUNTPOINTS NO NEED SAMBA CIFS NFS OR OTHER NETWORK CONNECTIONS JUST ACTIVATE MEDIATOMB ON THE BOX SERVER AND DJMOUNT ON BOX CLIENTS.
TO USE UPNP YOU HAVE TO INSTALL BH IMAGE 1.4.4 AT LEAST IN TWO BOXES
DON'T USE SAMBA NFS OR CIFS TO CONNECT BOXES !!
IN THE FIRST BOX (BOX WITH HDD) YOU WILL HAVE TO ENABLE MEDIATOMB (SERVER)
IN THE SECOND BOX (CLIENT) YOU HAVE TO ENABLE ONLY DJMOUNT (CLIENT)
AT THIS POINT YOU WILL SEE FROM THE CLIENT MEDIAPLAYER ALL THE FILES OF THE SERVER.
YOU DON'T NEED TO CONFIGURE ANYTHING, MEDIATOMB SERVER AND DJCLIENT ARE FULLY PRECONFIGURED IN BLACK HOLE IMAGES TO WORK ON YOUR BOXES !!
About Mediatomb:
You can use Mediatomb for Upnp server on your box and then connect all other boxes with Upnp client. In this way you will have the files of server available on your clients in folder /media/upnp. You will have available in MediaPlayer YOUR MEDIA files.
You don't need to configure router or other things.
Mediatomb include a webinterface too to manage your media.
Mediatomb webif url: http://ip_box:49152 (example: box ip: 192.168.0.23 - Mediatomb webif = http://192.168.0.23:49152)
If you want to play with Mediaplayer configs you can find docs and howto: http://mediatomb.cc
Location of config file: /.mediatomb/config.xml
Mediatomb features:
browse and playback your media via UPnP
metadata extraction from mp3, ogg, flac, jpeg, etc. files.
Exif thumbnail support
user defined server layout based on extracted metadata (scriptable virtual containers)
automatic directory rescans
highly flexible media format transcoding via plugins / scripts
sophisticated web UI with a tree view of the database and the file system, allowing to add/remove/edit/browse your media
support for external URLs (create links to internet content and serve them via UPnP to your renderer)
support for ContentDirectoryService container updates
Active Items (experimental feature), allows execution of server side scripts upon HTTP GET requests to certain items
highly flexible configuration, allowing you to control the behavior of various features of the server
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Time Shift
Button Red = Start Record
Addons
Infobar / OSD
Analog Clock Enigma2
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Manager Kernel Modules (Kernel module operator)
Black Hole Mount Wizard (Mount points)
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
Usb Tuner Panel
Info Panel
1 - E2 Setting (Enigma2 configurations)
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Credits
Thanks to bigroma (vuplus-community board) for rt3070 patches.
DISCLAIMER
THE BLACK HOLE IMAGE IS BASED ON THE OFFICIAL FIRMWARE PULBISHED BY VU+ AND IN ACCORDANCE WITH THE LAW IT CONTAINS ONLY SYSTEM ADDITIONS & GRAPHIC CHANGES.
LASTLY, THE BLACK HOLE IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR IILEGAL PURPOSES SUCH AS CARD SHARING.
LICENSE (TERM OF USE)
ANY CHANGES OR ADDITIONS TO BLACK HOLE IMAGE THAT INVOLVE UNLAWFUL USE OF THE IMAGE SUCH AS CARD-SHARING AND EMULATORS ARE NOT ALLOWED AND CAUSE THE REWOKE OF THIS LICENSE.
