BlackHole Vu+ Solo v. 1.4.4 Multiboot
So my first hdtv recording on the ntfs formatted USB has finished and DVR Studio HD says one error.
But I can't believe that the result with the NAS is so bad.
I changed the network.
Now my internet surfing can't interfere with the NAS.
I've read that ext4 is much better than ext3.
Can I use a ext4 formatted disk with BlackHole?
I have no NAS but it must work better than my network computer
with WinXp I think
I have test CIFS with my network PCs and I can use
recording on WINXP PCs is perfect and without problems
with CIFS.
So to me it is not clear why you have problems with the NAS.
So my first box is in (vu+ solo my duo is coming later) istalled black hole and its working like charm,only dvd player i can not instal it says not compatible but i try to instal it from bh addon server?
can somebody help.
upnp works great but i need dvd player to play ts files
installed first hotplug then dvd player then reboot, start dvdplayer selected movie ts from dlna then green screen ,installed fix from logan then dvd player no green screen but also no picture????????????????
i only tried video ts does not work,but now i want to download dvd player from bh addons server(yesterday i removed it) ,i cant find dvd player anymore
