BlackHole Vu+ Uno 1.6.5
I download picon from VU+ Network and instal on USB Key.
I active picons from OSD settings and it doesn't work.
I try also from plugin to add NetworkBrowser and nothing appends.
I don't see this pluging on Plugin Menu.
MyTube works fine.
On HDMI-CEC TV remote control wakeup -> wakeup VU+ box, no works. (I have not tested this option before).
Regards :)
MyTube works fine.
Regards :)
You are doing something wrong.
NetworkBrowser is already in the image
in System>> Network>> Network Configuration
Picons working 100%.
If you put FAT 32 on PC formated USB stick and make only mount in Blue>>Blue button>Devices Manager>>Mountpoints (red button) (mount /media/usb and save with red button)
After you download picons from our image server
green>>yellow>>Addons Download Manager>>Picons Packges
hi guys
this morning i tried to install this new image on my vUNO but the remote (i'm using the vu DUO's as i use 1 for both) is not responding. i tried installing twice but still i can't go beyond the initial setup page with either remote or front buttons
i re-installed previous image and works immediately
do i need to use`the vuUNO's remote u think or was there an error downloading image??
thanks for any replies
hi guys
Since remote control response code is changed, I think you have to use the UNO remote.
VU remote supports different modes.
Read the instruction manual.
For Uno you have to use a remote for vu uno.
thanks for your replies guys
i have been using 1 remote for both since without fail. did something change with this new image??
thanks again
thanks again
As you know Black Hole images are based on the original vuplus release.
If you have a read the release notes in the first post you will see all the changes and not just this one.
Change remote control response code
(remote control of uno works only in uno)
Sometimes is pays to read the release notes :p
@Matrix
Picons work fine. It was a bad mounting (not USB but USB3)
For NetBrowser, i undestand now. It is my first linux box.
In fact, i need a file browser to copy, paste, delete files (in local and in network).
I don't known if there is one at this moment for the UNO (I undestand also that UNO is a new box and at this time, all is not perfect).
On HDMI-CEC TV remote control wakeup -> wakeup VU+ box, not works (I have not tested this option before) with Sony 46EX500
Regards and thanks for your help.:)
@Matrix
If you need file browser on your PC You can use Total Commander (search on net with google)
If you need file browser on your VU you can try File browser plugin you can find on our image server.
green>yellow>>Addons Download Manager>>Black Hole Image Plugins
HDMI-CEC is experimental
and TV companies do not use the same commands for HDMI-CEC and that is the problem
and this is the reason that some commands do not work on one TV while the others are ok.
FileBrowser works fine.
On Windows all work fine with Samba (Windows Explorer is OK)
What is MediaScanner for ?
Is it running fine ?
Regards
Regards
If you have some files such as jpg, png or movie ts files
you can see them.
Example on USB stick.
With MediaScanner "No displayable files found on this drive" :
There are png (on USB), and avi, mp3 (on HDD).
Not exactly ,
MediaScanner working on VU
I have test now.I have test on VU Uno and VU duo
I have not test on VU solo.Next time.
You have to use USB stick with FAT32 format
you do not need to mount USB stick and do not Format USB stick in a box use Windows FAT32 format
Just plug in the box.
you can see our little dog :D
I have test with jpg,png and movie ts file.
I have test also wav and mp3 is working.
files must be in the root directory, "the root"
can be scanned flash / usb / hdd / network drive/cifs drive
hi everybody and thank's for your great work!!
I can't find drivers for WINTV MINI STICK at this image.
Can you help me?
