BlackHole Vu+ Uno 1.6.5
About USB and Picons.
Picons are working fine but i think they are not in USB key.
I choose in mount device, USB2 and they are installed in USB.
I can see them with windows explorer in USB.
And if I take off the USB key, the picons are working fine. Normal, in fact they are not installed in the USB key.
They are installed in the flash (the % of flah is going up).
Something is strange.
About CoolTVGuide5.0 : I download it from server.
I see nothing, what is it necessary to do to see something ?
Regards.
Regards.
Your USB stick must be mounted into /media/usb !
@angelofsky : YES for PICONS in USB stick : the USB stick must be mounted into /media/usb.
All work fine. Now the PICONS are in USB stick. The % of flash used stays the same.
Thanks
Regards
Is CoolTVGuide5.0 working on VU+ UNO ?
I download it from server and i see nothing in plugins, in menu, and else ..
It just possible to remove it. (but this function doesn't work, it stays again).
Regards
Regards
I'm using it and it is working fine.
Try to install these ipk and tell me if something changes.
The problem was the EPG button (long-press).
I am trying to install picons (directory mnt/usb/picon) but nothing for the moment.
I am searching.
Regards
I am searching.
Regards
You don't see picons in your skin?
That is strange, is you pen mounted in media/usb?
@Tamaki : Picons work, it was a bad restart.
About FAN in standby.
How to stop it?
I try to put PWN value to 0 and it turn always.
I put FanOFF in StanBy and it doesn't stop.
I don't understand because i think that sometime it stop in stanbby, but not all the time.
Have you an idea?
Thank
Black Hole Vu+ Uno 1.6.5
What is new ?
Based on official image 5.11
New Skin Beyounce 14 by Matrix 10
MEDIATOMB updated to ver. 0.12.1
NTFS-3G updated to ver. 2011.4.12.
OpenVPN updated to ver. 2.2.1
VsFTPd updated to ver. 2.3.4
Dropbear updated to ver. 0.53.1
Update blind scan
Update ManualFanControl plugin
Remove udev-static
Driver Update
Lower the default FAN rpm
Increase dynamic range of FAN speed
Change key code of audio button
Change remote control response code
(remote control of uno works only in uno)
Fix occasional not moving FAN problem
Remove udev-static
Instructions to connect the box to your Hdmi-Cec compatible Tv:
1) Enter in your Tv Menu Options and enable all the Hdmi-Cec options.
2) Enter in your Vu+ box Black Hole Hdmi-Cec Panel Setup (blue->blue->Black Hole Hdmi Cec: Configure in this screen the right Hdmi connection port and enable Bh Hdmi-Cec.
3) Click Save (red) button and your box will try to connect with your Tv.
All Done. If your Tv is compatible you can now control Tv and Box with Tv rc.
Warning: You have to select the specific port option if your box is connected to an ampli.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Time Shift
Button Red = Start Record
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Devices Manager
Black Hole HDMI Cec
Manager Kernel Modules (Kernel module operator)
Black Hole Mount Wizard (Mount points)
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
Usb Tuner Panel
UPnP Client Djmount
UPnP Server Mediatomb
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Credits
Thanks to Sandro Cavazzoni for Cross EPG
Thanks to Lukino (VDR-Italy) for the source code of OpenTV.
Thanks to bigroma (vuplus-community board) for rt3070 patches.
DISCLAIMER
LASTLY, THE BLACK HOLE IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR IILEGAL PURPOSES SUCH AS CARD SHARING.
LICENSE (TERM OF USE)
ANY CHANGES OR ADDITIONS TO BLACK HOLE IMAGE THAT INVOLVE UNLAWFUL USE OF THE IMAGE SUCH AS CARD-SHARING AND EMULATORS ARE NOT ALLOWED AND CAUSE THE REWOKE OF THIS LICENSE.
Thank you
