BlackHole Vu+ Uno 1.6.5
yes, something wrong with rc SW. It works on 5.10 but not on 5.11. Any ideas how to treat this?
If you haven't got vu+ uno dedicated RC you cannot use new imgs.
With new drivers only new vu+uno RC can work on vu+uno.
You have to use BH 1.6.4.
I can not download 1.6.4, something wrong with zip file - it is downloaded only 27Mb.
About FLASH MEMORY :
If we save the picons in monted USB key, the % of flash goes up (bleu, yellow menu).
Is it normal?
Hi to every ody I am running the BH 1.6.5 but I am having problem with my transponder and I am not able to look at any channel! I did the ftpa update but nothing, please help me
Check tuner configuration and if cable is well connected.
Great image 1.6.5!!! Nice and stable !!! Thanks for all efforts and sharing with us !!!
I do have a question maybe someone does have experience with it :
When i send a dvd VIDEO_TS with VOB files to the harddisk and i want to play it with option menu --> mediaplayer i can put the files in the playlist but when the movie starts i can not select the subtitles which are embedded in the movie.
I tried the help button. The subtitle option displayed in help can not find anay available subtitles.
When playing the VOB files in VLC on pc i can go to menu and select the (Dutch) subtitles.
Is there any option to select available subtitles or is this not possible within this mediaplayer plugin ?
Anyway explended image !!! Thanks !!!
this is my tuner config:
config. simple
mod single
satellite hotbird (13.0E)
Diseqc no
I have the sat antenne directly connected to my Vu+ uno and every works fine with the old decoder
config. simple
mod single
Diseqc no
Cross-posting for SAME problem is not a good idea. Please post in ONE forum against your language.
This image is really magnificance !!
This image truely is sublime, I luckily have a Samung HD TV, the HDMI-CEC is simply amazing !!!!!!!!!!
The only option missing is: wakeup Vu + Remote Control -> wakeup TV.
A great addition to this image!
I've always used Blackhole image with no regrets ! This edition is without doubt a super image !!! stable and reliable !!!
Thank you developpers !!!
A very satisfied user.
