Divx (Avi) files not fluid - Slow on media Player
Hi i am running the new 1.6.7 version on Vu+ Duo. But the same problem have also been present in 1.6.6
I have a playback problem with both mediaplayer and dvdplayer. I have pasted the following info for the file causing problem on mediaplayer.
General
Complete name : D:\Film\sublime.avi
Format : MPEG-PS
File size : 47.7 MiB
Duration : 1mn 56s
Overall bit rate : 3 446 Kbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=18
Duration : 1mn 56s
Bit rate mode : Variable
Bit rate : 2 929 Kbps
Maximum bit rate : 9 800 Kbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.283
Stream size : 40.5 MiB (85%)
Audio
ID : 189 (0xBD)-128 (0x80)
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Muxing mode : DVD-Video
Duration : 1mn 55s
Bit rate mode : Constant
Bit rate : 448 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Delay relative to video : -397ms
Stream size : 6.19 MiB (13%)
This sublime.avi is a sample of the dvd movie i am trying to play with the dvd player. The problem is the fluidness on both. The content is 30 fps but the Duo is outputting both files with 50 fps. I dont know how to force 60 fps output.
In relation to the media player i have stumbled on a mkv file where the screen is black during playback. The sound works fine as do the subtitles however.
General
Unique ID : 215211451222784367302499006152750756636 (0xA1E837C39BC8CF4CBE2709F85AC9731C)
Complete name : D:\Serier\Fate_zero\[UTW]_Fate_Zero_-_05_[h264-720p][0F358C5F].mkv
Format : Matroska
File size : 457 MiB
Duration : 23mn 39s
Overall bit rate : 2 697 Kbps
Movie name : Fate/Zero - 05: Howl of a Mad Beast
Encoded date : UTC 2011-10-30 01:36:51
Writing application : mkvmerge v4.9.1 ('Ich will') built on Jul 11 2011 23:53:15
Writing library : libebml v1.2.1 + libmatroska v1.1.1
Attachment : Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High 10@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 8 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 23mn 39s
Width : 1 280 pixels
Height : 720 pixels
Frame rate : 23.976 fps
Color space : YUV
Bit depth : 10 bits
Title : H.264 720p HDTV 10-bit
Writing library : x264 core 118 r2085+614 d1cc25d
Encoding settings : cabac=1 / ref=9 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / fade_compensate=0.95 / psy_rd=0.60:0.10 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=6 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / fgo=0 / bframes=9 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=120 / rc=crf / mbtree=1 / crf=17.0 / qcomp=0.80 / qpmin=0 / qpmax=81 / qpstep=4 / ip_ratio=1.32 / aq=1:0.93
Language : Japanese
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : A_AAC
Duration : 23mn 39s
Channel(s) : 2 channels
Channel positions : Front: L R
Title : AAC 2.0 192Kbps
Language : Japanese
Text
Format : ASS
Codec ID : S_TEXT/ASS
Codec ID/Info : Advanced Sub Station Alpha
Compression mode : Lossless
Title : Styled Subtitles
Language : English
Menu
00:00:00.000 : en: Prologue
00:01:58.993 : en:Opening
00:03:28.917 : en: Part A
00:11:06.916 : en: Part B
00:21:54.813 : en:Ending
00:23:24.861 : en: Preview
I think one of the differences between this file and other mkv files is the bit depth. This has a bit depth of 10 while other files which plays fine have a bit depth of 8. But im not sure if that is significant or not.
General
Format : Matroska
File size : 457 MiB
Duration : 23mn 39s
Video
Format : AVC
Duration : 23mn 39s
Height : 720 pixels
Color space : YUV
Bit depth : 10 bits
Language : Japanese
Audio
Format : AAC
Format profile : LC
Codec ID : A_AAC
Duration : 23mn 39s
Language : Japanese
Text
Format : ASS
Language : English
Menu
Thank you.
I reported the issue to vu+.
