Hi i am running the new 1.6.7 version on Vu+ Duo. But the same problem have also been present in 1.6.6
I have a playback problem with both mediaplayer and dvdplayer. I have pasted the following info for the file causing problem on mediaplayer.
General
Complete name : D:\Film\sublime.avi
Format : MPEG-PS
File size : 47.7 MiB
Duration : 1mn 56s
Overall bit rate : 3 446 Kbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=18
Duration : 1mn 56s
Bit rate mode : Variable
Bit rate : 2 929 Kbps
Maximum bit rate : 9 800 Kbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.283
Stream size : 40.5 MiB (85%)
Audio
ID : 189 (0xBD)-128 (0x80)
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Muxing mode : DVD-Video
Duration : 1mn 55s
Bit rate mode : Constant
Bit rate : 448 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Delay relative to video : -397ms
Stream size : 6.19 MiB (13%)
This sublime.avi is a sample of the dvd movie i am trying to play with the dvd player. The problem is the fluidness on both. The content is 30 fps but the Duo is outputting both files with 50 fps. I dont know how to force 60 fps output.
General
Format : MPEG-PS
Duration : 1mn 56s
Video
Format : MPEG Video
Duration : 1mn 56s
Width : 720 pixels
Height : 480 pixels
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Audio
Format : AC-3
Duration : 1mn 55s
Bit rate : 448 Kbps
Bit depth : 16 bits
