Divx (Avi) files not fluid - Slow on media Player
Kindly I'm new to VU Family.
I have installed BH 1.6.6 on VU UNO, but I'm not able to run AVI File via Media Player. getting Blank Screen if I run any AVI file.
Please help
Please help
As stated by Angelofsky we need more info, I have just tested avi with my Uno and it plays almost perfect except for the known issue of poor fluidity.
Thank you very much, it was sort it out, it was my mistake, I used faulty USB.
Thank you for your kind support and fast response.
Regards,
I did not mount enything there, this is the first time i do this, and the image is the latest for Uno.
When i try to mount /media/net from the mount manager i get this screen :
maybe you need to give permission 755 to your directory /media/net. I notice that mine has 755 value
Thank you for your help. I can't make it work at all.
I activated djmount, butt when i press Media player i get green screen every time.
It is the same thing with Win 7 and XP.
Dear Friend.
Green screen is not a folder mount issue.
I don't have VU+ Uno but if the problem is only on your receiver,
and not reported by other owners, try to re-flash with Latest or Older image and Test again.
I know there is slow sync issue with Dvix/Avi for Uno but is going to be fixed very soon.
With WinXP use mount wizard (cifs) works perfect.
I can confirm the poor fluidity of divx videos on VU+ UNO with Mediaplayer in BH 1.6.6. Many of these divx/xvid skip or loose frames, so I'm not "happy" viewing my divx.
Mkv just works fine!
VU+ UNO is one of the best Linux sat decoders, so please update drivers!
PS: any rumor about xbmc on VU+ UNO?
Yes, on vu+ uno divx doesn't play good, mkv works fine but i have problem with mkv with dts they aren't so fluid :( (BH 1.6.6)
have you tried the new beta drivers for vu+ ???
20111109
- Improve media playback
- Add interface to control VFD in the application(ultimo)
Hallo, i have tested the 20111109 drivers.Many problems with original DivX codec are solved but the problems with alternative XviD codec continue.
Sorry for bad english.
ok just a thought.....lets hope the new drivers that Artorius mentioned work better then.
