Divx (Avi) files not fluid - Slow on media Player
Much, Much Better, AVI files are very fluid now, apparently no breaks!!
I will test on MKV to see if now we will have less stops or blocks during some movies...
CONGRATULATIONS, you are on the right track :)
I would like to remember @ ALL one thing: AVI files are CONTAINERS of audio and video streams.
These streams can be obtained with many codecs.
Remember to RESTART your box after install the beta drivers!
If one AVI file who previously had problems and with a certain version of beta drivers works correctly please post the mediainfo output for that file.
It's very important to make a correct report to Vu+ company to identify the corrected bugs and identify the missing ones.
Hi, I restart only the GUI, do I restart totally the receiver?
Tonite I'll post the mediainfo of my xvid and dvix files.
Regards
Ok, guys, better then ever! :)
But this kind of video still not working perfect:
Video
Format : MPEG-4 Visual
Format profile : Simple@L3
Format settings, BVOP : Si
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (MPEG)
Muxing mode : Packet Bitstream
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 1h 2min
Bit rate : 1 101 Kbps
Width : 640 pixel
Height : 272 pixel
Display aspect ratio : 2,35:1
Frame rate : 23,976 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressivo
Bits/(Pixel*Frame) : 0.264
Stream size : 496 Mb (71%)
Writing library : XviD 1.0.3 (UTC 2004-12-20)
Regards
Where are located the files?
What box do you use?
Report the mediainfo output of the problematic file.
vu+ uno with last bh and last driver "vuplus-dvb-modules-vuuno-2.6.18-7.3-4.4.3-20111111", the files are on hd usb 2.0 western digital.
With AC3 is good but with DTS ins't so fluid :(
Nome completo : test.mkv
Formato : Matroska
Versione del formato : Version 2
Dimensione : 4,37 GiB
Durata : 55min
BitRate totale : 11,3 Mbps
Film : test
Data di codifica : UTC 2011-03-22 20:24:07
Creato con : mkvmerge v3.0.0 ('Hang up your Hang-Ups') built on Dec 12 2009 15:20:35
Compressore : libebml v0.7.9 + libmatroska v0.8.1
Video
Formato : AVC
Formato/Informazioni : Advanced Video Codec
Profilo del formato : High@L4.0
Impostazioni del formato, CABAC : Si
Impostazioni del formato, ReFrames : 4 fotogrammi
Codec ID : V_MPEG4/ISO/AVC
Durata : 55min
BitRate : 9 699 Kbps
Larghezza : 1 920 pixel
Altezza : 1 080 pixel
AspectRatio : 16:9
Modalità FrameRate : Variabile
FrameRate : 23,976 fps
ColorSpace : YUV
ChromaSubsampling : 4:2:0
BitDepth/String : 8 bits
Tipo di scansione : Progressivo
Bit/(Pixel*Frame) : 0.195
Dimensione della traccia : 3,75 GiB (86%)
Titolo : test
Lingua : Inglese
Default : Si
Forced : No
Audio #1
Formato : AC-3
Formato/Informazioni : Audio Coding 3
Format_Settings_ModeExtension : CM (complete main)
Codec ID : A_AC3
Durata : 55min
Modalità : Costante
BitRate : 640 Kbps
Canali : 6 canali
Posizione dei canali : Front: L C R, Side: L R, LFE
SamplingRate : 48,0 KHz
BitDepth/String : 16 bits
Ritardo video : 27ms
Dimensione della traccia : 253 Mb (6%)
Titolo : Italiano AC3
Lingua : Italiano
Default : No
Forced : No
Audio #2
Formato : DTS
Formato/Informazioni : Digital Theater Systems
Codec ID : A_DTS
Durata : 55min
Modalità : Costante
BitRate : 755 Kbps
Canali : 6 canali
BitDepth/String : 24 bits
Ritardo video : 6ms
Dimensione della traccia : 299 Mb (7%)
Titolo : Italiano DTS
Lingua : Italiano
Default : Si
Forced : No
Testo
Formato : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Informazioni : UTF-8 Plain Text
Titolo : Italiano
Lingua : Italiano
Default : Si
Forced : No
@Angel
just to compare, this file works properly:
Video
Formato : MPEG-4 Visual
Profilo del formato : Advanced Simple@L5
Impostazioni del formato, BVOP : Si
Impostazioni del formato, QPel : No
Impostazioni del formato, GMC : No warppoints
Impostazioni del formato, Matrix : Personalizzato
Codec ID : XVID
Codec ID/Consiglio : XviD
Durata : 44min
BitRate : 1 805 Kbps
Larghezza : 720 pixel
Altezza : 400 pixel
AspectRatio : 16:9
FrameRate : 25,000 fps
Risoluzione : 8 bits
Colorimetria : 4:2:0
Bit/(Pixel*Frame) : 0.251
Dimensione della traccia : 576 Mb (82%)
Compressore : XviD 1.3.0.dev55
bye
Formato : Matroska
Durata : 55min
Film : test
Video
Formato : AVC
Durata : 55min
AspectRatio : 16:9
ColorSpace : YUV
Titolo : test
Lingua : Inglese
Default : Si
Forced : No
Audio #1
Formato : AC-3
Codec ID : A_AC3
Durata : 55min
Modalità : Costante
BitRate : 640 Kbps
Canali : 6 canali
Lingua : Italiano
Default : No
Forced : No
Audio #2
Formato : DTS
Codec ID : A_DTS
Durata : 55min
Modalità : Costante
BitRate : 755 Kbps
Canali : 6 canali
Ritardo video : 6ms
Lingua : Italiano
Default : Si
Forced : No
Testo
Formato : UTF-8
Titolo : Italiano
Lingua : Italiano
Default : Si
Forced : No
At this time I can make some tests with Uno only this Sunday. Thanks for the report!
