DVB-S2X tuner
Other brands with the same tuner chip ??
What makes curiosity ??, if you indicate the receiver model, it is appreciated.
Otras marcas con el mismo chip de tuner??
Que marcas curiosidad ??, si indicas el modelo de receptor, se agradece.
PS:VU+ also has it in the VU+zero4K/VU+ tambien lo tiene en el VU+zero4K.:offtopic:
I just want to say that zgemma has it implanted, octagon also, and vu that it is the best in receiver brand has it but in the vu zero 4k, which is the smallest model!
And for the Zero 4K UHD zapper they have the licens drivers and tuners. Rest of the Vu+ boxes has another Tuner whith another chipset that need another/diffrent driver and licens.
But we can debate this to the end of time and we want get any closer to a solution unless Vu+ can work out a deal with the owner of the Drivers
Can you say some Octagon/zgemma model that uses chip 45308 (tuner FBC 4+4) that has those functions?
We all know that with other chip you have it, it is more than commented on the thread, if it is what you want, in vu + nones, only the vu + zero4k (1tuner) has that chip.
Octagon SF8008 with chip Silabs in the tuner.
Puedes decir algun modelo de Octagon/zgemma que usen chip 45308 (tuner FBC 4+4) que tengan esas funciones.?
Todos sabemos que con otros chip lo tienes, esta mas que comentado en el hilo, si es lo que quieres, en vu+ nones, solo el vu+zero4k (1tuner) tiene ese chip.
Octagon SF8008 con chip Silabs en el tuner.
ok, good and vu + knows all this, do you plan to do something about it?
You ask me? I hope you look at it ...
When you want, it's in your hand.
The rest we expect to solve this problem and others that you do not see, for some are more important, especially to be in the characteristics of the team and are already 3 years in pending tasks.
Me lo preguntas a mi? espera que lo miro.....
Cuando quieran, esta en su mano.
Al resto nos toca esperar que solucionen este problema y otros que no ves, para algunos son mas importantes, sobre todo al estar en las caracterisiticas del equipo y ya van 3 años en tareas pendientes.
I am just like you a regular user of Vu+ and the Images Blackhole and OpenBlackhole. Neither me or anyone from team Blackhole can fix this issue.
This is not the official Vu+ forum just an Hobby based forum for BH users :) so we just have to wait for Vu+ to fix this :)
Scusate la mia ingnoranza !!
Ma quando è uscito il turner 45308X FBC ???? ( non ho trovato nulla neanche in giro ne da vu ne su hm )
Il mio povero ultimo 4k monta ancora i 45208FBC
For those old tuner, nothing (tuner FBC chip 45208 DVB-S2).
You need the tuner with chip 45308 DVB-S2X.
It is an update of the chip and I think it has no solution.
The plate is identical (removing the chip).
The new tuner is € 90.+/-
Per quei vecchi sintonizzatori, niente (sintonizzatore FBC chip 45208 DVB-S2).
Hai bisogno del sintonizzatore con chip 45308 DVB-S2X.
È un aggiornamento del chip e penso che non abbia soluzione.
La piastra è identica (rimozione del chip).
Il nuovo tuner è € 90+/-.
Para esos viejos tuner, nada (tuner FBC chip 45208 DVB-S2).
Necesitas los tuner con chip 45308 DVB-S2X.
Es una actualizacion del chip y creo que no tiene solucion.
La placa es identica (quitando el chip).
El nuevo tuner son 90€uros +/-.
Hello everybody,
I am a new user of VU+ Duo2 4k equipped with dual FBC DVB-S2X based on chip 45308 DVB-S2X. I use OS VTi 14.0.3 (2019-04-25-vti-master).
For some reason I am not able to receive French FTA channels from Eutelsat 33E: TF1 HD Suisse, NT1 HD Suisse i TMC HD Suisse which transmit in DVB-S2X standard:
https://pl.kingofsat.net/sat-eutelsat33e.php
Other channels (DVB-S2) from this satellite are receivable.
Any advice how to fix it?
Kind regards
EC
I am unaware of a VU+ Duo 2 4K receiver, there is a VU+ Duo 4k, Uno 4k, Uno 4K SE, Ultimo 4K, Zero 4K, and Solo 4K.
Can you please confirm the model of your VU+ receiver.
As a desparate step I could try out BlackHole, however, I have just customized VTI version for myself hence I'd like to find a solution on this image first.
I am using VTi 14.0.3 (2019-04-25-vti-master) - do you think that Blackhole offers any additional support for DVB-S2X?
I have upgraded firmware on the box (staying on VTi 14.0.3 (2019-04-25-vti-master)), and then I was able to scan these three DVB-S2X channels manually.
Unfortunately, now I have a problem that after 1 second of reception of any of these channels, unit crashes and restarts, and again after 1 sec of signal reception crash occurs etc. sad.png
Any idea how to fix it?
EC
Unfortunately, now I have a problem that after 1 second of reception of any of these channels, unit crashes and restarts, and again after 1 sec of signal reception crash occurs etc. View attachment 46591
EC
You should be so courteous to ask these questions in the VTI forum because here we discuss BH and OBH
Oooops, sorry. Forum is named "Vu+ Hardware -> Hardware: All Vu+ models" hence I didn't realize it's OS specific, and the topic was very related to my issues.
Thanks and regards
EC
The problem is that we are user of BH and OBH, whom we know best. It might be the occasion to give BH or OBH a try
You could also use them in multiboot if you don’t want to reflash your box.
