GoTView SatelliteHD
It may patch the driver.
PS: Yes, more. Why does not "Lsusb"?
Into Linux boxes doesen't exist "lsusb" command but the same result is to cat the /proc/bus/usb/devices.
Thanks for the patch but it's the same I've already applied on drivers and it's contained into dw2102 ipk driver posted above.
I will check better the build process and I will inform you ASAP.
My friend I have a request for you: could you please make some hi-res photos of the internal of your USB DVB-S2 device?
I hope the chipsets and other IC are known and I can try to support it ....
More:
http://www.terratec.net/en/products/technical-data/produkte_technische_daten_en_121875.html
Driver:
http://linux.terratec.de/tv_en.html
Under Windows, the driver of DVBSKy S860 and Cinergy S2 USB HD, installed and working after editing the *. inf. Checked
I've modified linux drivers included into Vu+ SDK according to DVBSKY sources but I would like to ask you about the quoted post.
What kind of device are you using with Cinergy S2 USB HD drivers? What have you modified into inf files?
It was:
oem10.inf (windows driver DVBSKy S860)
[MyCompany.NTamd64]
%BS6831.DeviceDesc% = BS6831, USB\VID_0572&PID_6831
[MyCompany]
It became:
[MyCompany.NTamd64]
%BS6831.DeviceDesc% = BS6831, USB\VID_1fe1&PID_5456
[MyCompany]
Cinergy S2 USB HD:
It was:
%Cinergy_rev1.DeviceDesc% = Cinergy.NTx86,USB\VID_0CCD&PID_00A8
%Cinergy_rev2.DeviceDesc% = Cinergy.NTx86,USB\VID_0CCD&PID_00B0
It became:
%Cinergy_rev1.DeviceDesc% = Cinergy.NTx86,USB\VID_1fe1&PID_5456
%Cinergy_rev2.DeviceDesc% = Cinergy.NTx86,USB\VID_1fe1&PID_5456
It's all in Windows.
