GoTView SatelliteHD
I'm sorry. Post # 40. I wrote that the altered driver work under Windows. It was a mistake. tuner established, but the frequency scan, I did not.
Now, I decided to check out. It turned out that the driver DVBSKy S860, Cinergy S2 USB HD, under windows, too, does not scan.
Scans only with native drivers.
Sorry.
Мне очень жаль. Пост #40. Я писал, что переделанный драйвера работают под Windows. Это оказалось ошибкой. тюнер установился, но сканирование частот я не делал.
Сейчас, я решил проверить. Оказалось, что с драйверами DVBSKy S860, Cinergy S2 USB HD, под windows, тоже не сканирует.
Сканирует, только с родными драйверами
Sorry.
OK!
I've made some google searches around your device and one people has done a patch to implement your device into Debian 6.0.
It's a vey good news, but we have already tried it without success :(
I ask one thing to you: the power supply is connected to device? It's a stupid question I know but I need to know the full situation of your box and devices.
Do you mean: kernel-module-dvb-usb-dw2102_3.1.1-r4_vusolo.ipk, kernel-module-dvb-usb_3.1.1-r4_vusolo.ipk (post #14) ?
This was true for the Black Hole Vu + Solo 1.6.7 kernel 3.1.1 beta2?
And in the Black Hole Vu + Solo 1.6.7 kernel 3.1.1 beta3, update the driver?
Since Black Hole Vu + Solo 1.6.7 kernel 3.1.1 beta3, apply this patch is not possible.
There is already installed 3.1.1-r5.
I will make new IPK for 1.6.7 Beta 3 in this day.
You can add the output to a log "su3000_streaming_ctrl"?
Sorry for my big delay!
I've compiled for Solo this dw2102 driver with debug enabled as your request.
Install with Green Panel -> Yellow button of BH image and reboot your box after installation.
Let me know if something changes ...
