HD Glass 16
HD Glass 16 ver. 11.56
- updated enhanced weather translations: sk, cz, en, et, lt
- updated pl, sk, cz, ru, de, it, uk, pt, tr, es, fa, al, ro, hu, nl, et, lt
- help updated in download
- fix autocenter of extra screens by enigma (all types)
- added detection of Constant CW (after restore icons type will be set to default type 1, so after update and autorestore you must download icons and previews and then set/select your prefered icons type)
- OTHERS: added Path to configuration file of HDG
- CHANNEL SELECTION: added options - Service name font size,Service info font size, Line height, Extendted description font size
- added new option: Reset all settings of HDG
- OTHERS: removed options - EPG selection type, font event act. and next
- added new section: EPG SELECTION
- EPG SELECTION: added - EPG selection type, Extendted description font size
- ENHANCED WEATHER/WEATHER: fix displaying of colors for warm and cold temperature (C <-> F)
- ENHANCED WEATHER: added - temperature unit (C, F, from /etc/ewea_city_Code.txt)
- enhanced weather - removed change units, added Select City - it is possible to add unlimited numbers of cities and choose for which will be weather displayed, all cities are stored in /etc/ewea_city_Code.txt
update is available online (setup and website)
Thanks to shamann
If you like this, please leave a thank you
HD Glass 16 ver. 11.60
- fix saving of weather location
- OLED: added OLED type - only time 2
- added alternative method to detection tuner type in some types of enigma
Thanks to shamann
HD Glass 16 ver. 11.61
- OLED: edited OLED type - only time 2
- added alternative method to detection tuner type in channel selection
Thanks to shamann
HD Glass 16 ver. 11.62
- updated default list of cities - city_Code.txt
- added error detection of website in "Find a city"
- fix restore style type and title color
Thanks to shamann
HD Glass 16 ver. 11.65
- fix cutting title renderer
- fix/corections more of screens
- added alternative method to checking of online update
Thanks to shamann
HD Glass 16 ver. 11.67
- fix support extended version of bitrate plugin
- changed update dialog
Thanks to shamann
HD Glass 16 ver. 11.79
- dir browser: added path autocutting in title
- DOWNLOAD MENU: changed results layout after files download
- fix line hight auto settings in Channel selection
- fix ECM PID displaying (deb version)
- WEATHER: removed option "Find a city" (in extensions, in menu), added option "Find a city" activated immediately press OK button
- added Extra Infobar 57
- fix "Find a city" Yahoo type searching
- TP INFO: extended support of HEVC codec
Thanks to shamann
HD Glass 16 ver. 11.84
- updated enhanced weather translations: sk, cz, et, lt
- fix some definition of screens
- fix Weather - Yahoo provider
Thanks to shamann
HD Glass 16 ver. 11.93
- added DVB-S2X detection if it is supported by enigma
- fix extrascreen/infobar 7
Thanks to shamann
HD Glass 16 ver. 12.12
- DOWNLOAD MENU: menu modification
Thanks to shamann
Please, didi21: don't quote a message for nothing. Just leave a reply, instead, if you need or a Like, if this was your intention. Thanks.
HD Glass 16 ver. 12.16
- added detection Vu+ duo4k, solo4k, ultimo4k, dm920,dm900
- updated enhanced weather translations: sk, cz, lt
- POCASIE: MSN - fix displaying of time update
- fix screen "SleepTimerEdit" (openATV only)
Thanks to shamann
HD Glass 16 ver. 12.17
- fix slider displaying
Thanks to shamann
HD Glass 16 ver. 12.22
- USER INFO: system info - fixed name
- WEATHER: MSN - fix calculation of sunrise, sunset of sun
- WEATHER: YAHOO - fix, removed option SSL certified content
- WEATHER: Find a city - Yahoo fix
- DOWNLOAD MENU: removed Pantelio picons package
Thanks to shamann
HD Glass 16 ver. 12.23
- DOWNLOAD MENU: updated piconSat, removed (27.5W) Intelsat 907, added (24.8W) AlcomSat 1
- fix curl autoinstallation in some kind of images
Thanks to shamann
HD Glass 16 ver. 12.26
- fix displaying tuners state
- ENHANCED WEATHER: added calculation of sunrise/sunset by GPS if provider data have GPS, if not sunrise/sunset is used from provider data
- ENHANCED WEATHER: add city - added option to use Virtual keyboard
- fix detection of CAID type
Thanks to shamann
Hi, any way to configure for 220x132 picon size ? HD Glass 16 does not seem to adjust picon size to fit InfoBar frame.
