HD Glass 16
Hi ennegi, do you try it on the latest Black Hole? I love this skin, but installing it (v.10.56 *.ipk) on BH v.3.0.2.F and trying to change to the HD Glass16 skin, I got a message, that it is not compatible with this version of BH and do not opened. May be you know, what is incompatibility and how to fix it?
Hi
Yes this Error Massages sucks i have this also sometimes.
Reboot the Box Load than the .ipk File to /tmp on your Box than press Green/Yellow/
scroll down to Manual Install Ipk packages in the pop up HDglass should be marked
press ok and wait till the Skin is Installed in the next pop up press OK E2 will be
restart and the Skin is now usable
Thank you for reply, but did not help. Restarted, than turned off with back panel switch, but when trying to select hd_glass16, got "Sorry this skin is not compatible with current Black Hole image version." BH v.3.0.2F & Vu+ Duo2
Hi
These Steps Working for me on the Vu 4K
Sorry if it won´t Work for you
Thanks for help. After some dancing with drums (reinstalling hdglass16 from BH manual install ipk packages did not help), reinstalled by command opkg install -force-overwrite /tmp/*.ipk and after restart "not compatible..." error disappeared. Can't say, that everything is OK, but skin works - sometimes crashes with spinner for some seconds and leaves such log:
<?xml version="1.0" encoding="utf-8"?>
<opendreambox>
<enigma2>
<crashdate>Sat May 28 10:11:15 2016</crashdate>
<compiledate>May 16 2016</compiledate>
<contactemail>crashlog</contactemail>
<skin>hd_glass16/skin.xml</skin>
<sourcedate>2016-05-16</sourcedate>
<branch>master</branch>
<rev>2.1.4-137-g3ada17c</rev>
<version>3.0.0</version>
</enigma2>
<image>
<kernelcmdline>libata.force=1:1.5Gbps bmem=192M@64M bmem=384M@512M memc1=788M ubi.mtd=0 root=ubi0:rootfs rootfstype=ubifs rw rootflags=sync</kernelcmdline>
<imageversion>
<![CDATA[
version=1000201604261329
</imageversion>
<imageissue>
<![CDATA[
BlackHole 3.0.2 %h
</imageissue>
</image>
<software>
<enigma2software>
<![CDATA[
enigma2 - experimental-git20121128-r137-bh32-bsp5
enigma2-defaultservices - 1.0-r8
enigma2-meta - experimental-git20121128-r137-bh32-bsp5
enigma2-plugin-cams-******-1.38d - blackhole
enigma2-plugin-extensions-addstreamurl - 2.0+git4+99b945b-r0
enigma2-plugin-extensions-cronmanager - 2.3
enigma2-plugin-extensions-cutlisteditor - experimental-git20121128-r137-bh32-bsp5
enigma2-plugin-extensions-dlnabrowser - experimental-git20121128-r137-bh32-bsp5
enigma2-plugin-extensions-dlnaserver - experimental-git20121128-r137-bh32-bsp5
enigma2-plugin-extensions-graphmultiepg - experimental-git20121128-r137-bh32-bsp5
enigma2-plugin-extensions-hbbtv - experimental-git20121128-r137-bh32-bsp5
enigma2-plugin-extensions-kodi - 1.0-20160331_r0_r0-bh3
enigma2-plugin-extensions-lcd4linux - git35+cb1eb6d-r9-bh2
enigma2-plugin-extensions-mediaplayer - experimental-git20121128-r137-bh32-bsp5
enigma2-plugin-extensions-mediascanner - experimental-git20121128-r137-bh32-bsp5
enigma2-plugin-extensions-openmultiboot - 1.1+git7+3e681c8-r10
enigma2-plugin-extensions-openwebif - 1+git1319+3131639-r1
enigma2-plugin-extensions-pictureplayer - experimental-git20121128-r137-bh32-bsp5
enigma2-plugin-extensions-remotestreamconvert - 2.0+git22+6f45040-r1
enigma2-plugin-extensions-satipclient - experimental-git20121128-r137-bh32-bsp5
enigma2-plugin-extensions-streamtv - experimental-git20121128-r137-bh32-bsp5
enigma2-plugin-extensions-subssupport - 1.5.4-r0
enigma2-plugin-softcams-wicardd - DRE-1.19.bh
enigma2-plugin-systemplugins-animationsetup - experimental-git20121128-r137-bh32-bsp5
enigma2-plugin-systemplugins-audioeffect - experimental-git20121128-r137-bh32-bsp5
enigma2-plugin-systemplugins-autoresolution - experimental-git20110215-r13-bh2
enigma2-plugin-systemplugins-autoshutdown - 0.3+git11+406e54c-r2
enigma2-plugin-systemplugins-blindscan - experimental-git20121128-r137-bh32-bsp5
enigma2-plugin-systemplugins-crossepg - 0.8.1+gitr431+18c4f08-r2-bh2
enigma2-plugin-systemplugins-firmwareupgrade - experimental-git20121128-r137-bh32-bsp5
enigma2-plugin-systemplugins-hdmicec - experimental-git20121128-r137-bh32-bsp5
enigma2-plugin-systemplugins-hotplug - experimental-git20121128-r137-bh32-bsp5
enigma2-plugin-systemplugins-manualfancontrol - experimental-git20121128-r137-bh32-bsp5
enigma2-plugin-systemplugins-netdrive - experimental-git20121128-r137-bh32-bsp5
enigma2-plugin-systemplugins-networkbrowser - experimental-git20110215-r13-bh2
enigma2-plugin-systemplugins-networkwizard - experimental-git20121128-r137-bh32-bsp5
enigma2-plugin-systemplugins-positionersetup - experimental-git20121128-r137-bh32-bsp5
enigma2-plugin-systemplugins-satfinder - experimental-git20121128-r137-bh32-bsp5
enigma2-plugin-systemplugins-skinselector - experimental-git20121128-r137-bh32-bsp5
enigma2-plugin-systemplugins-softwaremanager - experimental-git20121128-r137-bh32-bsp5
enigma2-plugin-systemplugins-transcodingsetup - experimental-git20121128-r137-bh32-bsp5
enigma2-plugin-systemplugins-uipositionsetup - experimental-git20121128-r137-bh32-bsp5
enigma2-plugin-systemplugins-videoenhancement - experimental-git20121128-r137-bh32-bsp5
enigma2-plugin-systemplugins-videomode - experimental-git20121128-r137-bh32-bsp5
enigma2-plugin-systemplugins-videotune - experimental-git20121128-r137-bh32-bsp5
enigma2-plugin-systemplugins-wirelesslansetup - experimental-git20121128-r137-bh32-bsp5
enigma2-plugin-systemplugins-wolsetup - experimental-git20121128-r137-bh32-bsp5
enigma2-plugin-systemplugins-zappingmodeselection - experimental-git20121128-r137-bh32-bsp5
enigma2-plugins-meta - experimental-git20110215-r13-bh2
enigma2-skin-hdglass16 - 10.56
enigma2-streamproxy - 1.0+git15+37a3f19-r5
enigma2-transtreamproxy - 0.1+git38+7675a1e-r11
packagegroup-vuplus-enigma2 - 1.0-r14-bh9
</enigma2software>
<dreamboxsoftware>
<![CDATA[
libdreamdvd0 - 0.9+git91+ee7b0b4-r0
</dreamboxsoftware>
<gstreamersoftware>
<![CDATA[
gstreamer1.0 - 1.4.5-r0
gstreamer1.0-libav - 1.4.5-r0
gstreamer1.0-plugin-dvbmediasink - 1.0+git63+e839734-r5
gstreamer1.0-plugin-subsink - 1.0+git6+d239267-r0-bh0
gstreamer1.0-plugins-bad - 1.4.5-r0
gstreamer1.0-plugins-bad-faad - 1.4.5-r0
gstreamer1.0-plugins-bad-fragmented - 1.4.5-r0
gstreamer1.0-plugins-bad-mms - 1.4.5-r0
gstreamer1.0-plugins-bad-mpegpsdemux - 1.4.5-r0
gstreamer1.0-plugins-bad-mpegtsdemux - 1.4.5-r0
gstreamer1.0-plugins-bad-rtmp - 1.4.5-r0
gstreamer1.0-plugins-bad-videoparsersbad - 1.4.5-r0
gstreamer1.0-plugins-base - 1.4.5-r0
gstreamer1.0-plugins-base-alsa - 1.4.5-r0
gstreamer1.0-plugins-base-app - 1.4.5-r0
gstreamer1.0-plugins-base-audioconvert - 1.4.5-r0
gstreamer1.0-plugins-base-audioresample - 1.4.5-r0
gstreamer1.0-plugins-base-ogg - 1.4.5-r0
gstreamer1.0-plugins-base-playback - 1.4.5-r0
gstreamer1.0-plugins-base-subparse - 1.4.5-r0
gstreamer1.0-plugins-base-typefindfunctions - 1.4.5-r0
gstreamer1.0-plugins-base-vorbis - 1.4.5-r0
gstreamer1.0-plugins-good - 1.4.5-r0
gstreamer1.0-plugins-good-apetag - 1.4.5-r0
gstreamer1.0-plugins-good-audioparsers - 1.4.5-r0
gstreamer1.0-plugins-good-autodetect - 1.4.5-r0
gstreamer1.0-plugins-good-avi - 1.4.5-r0
gstreamer1.0-plugins-good-flac - 1.4.5-r0
gstreamer1.0-plugins-good-flv - 1.4.5-r0
gstreamer1.0-plugins-good-icydemux - 1.4.5-r0
gstreamer1.0-plugins-good-id3demux - 1.4.5-r0
gstreamer1.0-plugins-good-isomp4 - 1.4.5-r0
gstreamer1.0-plugins-good-matroska - 1.4.5-r0
gstreamer1.0-plugins-good-rtp - 1.4.5-r0
gstreamer1.0-plugins-good-rtpmanager - 1.4.5-r0
gstreamer1.0-plugins-good-rtsp - 1.4.5-r0
gstreamer1.0-plugins-good-souphttpsrc - 1.4.5-r0
gstreamer1.0-plugins-good-udp - 1.4.5-r0
gstreamer1.0-plugins-good-wavparse - 1.4.5-r0
gstreamer1.0-plugins-ugly - 1.4.5-r0
gstreamer1.0-plugins-ugly-amrnb - 1.4.5-r0
gstreamer1.0-plugins-ugly-amrwbdec - 1.4.5-r0
gstreamer1.0-plugins-ugly-asf - 1.4.5-r0
gstreamer1.0-plugins-ugly-cdio - 1.4.5-r0
gstreamer1.0-plugins-ugly-dvdsub - 1.4.5-r0
gstreamer1.0-plugins-ugly-mad - 1.4.5-r0
libgstapp-1.0-0 - 1.4.5-r0
libgstaudio-1.0-0 - 1.4.5-r0
libgstcodecparsers-1.0-0 - 1.4.5-r0
libgstmpegts-1.0-0 - 1.4.5-r0
libgstpbutils-1.0-0 - 1.4.5-r0
libgstriff-1.0-0 - 1.4.5-r0
libgstrtp-1.0-0 - 1.4.5-r0
libgstrtsp-1.0-0 - 1.4.5-r0
libgstsdp-1.0-0 - 1.4.5-r0
libgsttag-1.0-0 - 1.4.5-r0
libgsturidownloader-1.0-0 - 1.4.5-r0
libgstvideo-1.0-0 - 1.4.5-r0
</gstreamersoftware>
</software>
<crashlogs>
<enigma2crashlog>
<![CDATA[
ma2/userbouquet.gamta_kelions_mokslas_istorija_dokumentika.tv
34 entries in Bouquet userbouquet.gamta_kelions_mokslas_istorija_dokumentika.tv
resolve: resolve ${sysconfdir}/enigma2/
resolve: -> /etc/enigma2/
loading bouquet... /etc/enigma2/userbouquet.muzikiniai_kanalai_menas.tv
26 entries in Bouquet userbouquet.muzikiniai_kanalai_menas.tv
loading bouquet... /etc/enigma2/userbouquet.humoras.tv
9 entries in Bouquet userbouquet.humoras.tv
loading bouquet... /etc/enigma2/userbouquet.sportas_ir_sveikata.tv
24 entries in Bouquet userbouquet.sportas_ir_sveikata.tv
loading bouquet... /etc/enigma2/userbouquet.filmai.tv
46 entries in Bouquet userbouquet.filmai.tv
loading bouquet... /etc/enigma2/userbouquet.vaikiki_kanalai_ir_multikai.tv
11 entries in Bouquet userbouquet.vaikiki_kanalai_ir_multikai.tv
loading bouquet... /etc/enigma2/userbouquet.lt_kanalai.tv
11 entries in Bouquet userbouquet.lt_kanalai.tv
loading bouquet... /etc/enigma2/userbouquet.trispalvis.tv
51 entries in Bouquet userbouquet.trispalvis.tv
loading bouquet... /etc/enigma2/userbouquet.lietuvikos_radijo_stotys.tv
69 entries in Bouquet userbouquet.lietuvikos_radijo_stotys.tv
loading bouquet... /etc/enigma2/userbouquet.rusikos_radijo_stotys.tv
57 entries in Bouquet userbouquet.rusikos_radijo_stotys.tv
loading bouquet... /etc/enigma2/userbouquet.usienietikos_radijo_stotys.tv
155 entries in Bouquet userbouquet.usienietikos_radijo_stotys.tv
loading bouquet... /etc/enigma2/userbouquet.inios_ir_visi_kiti.tv
63 entries in Bouquet userbouquet.inios_ir_visi_kiti.tv
14 entries in Bouquet bouquets.tv
loading bouquet... /etc/enigma2/bouquets.radio
loading bouquet... /etc/enigma2/userbouquet.favourites.radio
57 entries in Bouquet userbouquet.favourites.radio
loading bouquet... /etc/enigma2/userbouquet.radio_lt.radio
32 entries in Bouquet userbouquet.radio_lt.radio
2 entries in Bouquet bouquets.radio
Renumbering...
[eDVBLocalTimeHandler] enable sync local time with transponder time!
main thread is non-idle! display spinner!
add dreampackage scanner plugin
added
[FONT] adding font /usr/share/fonts/nmsbd.ttf...OK (Display)
- double buffering available!
10800kB available for acceleration surfaces.
resolution: 1280 x 720 x 32 (stride: 7680)
[FONT] adding font /usr/share/fonts/lcd.ttf...OK (LCD)
[FONT] adding font /usr/share/fonts/prive3.ttf...OK (Prive3)
[FONT] adding font /usr/share/fonts/prive3.ttf...OK (Prive4)
[FONT] adding font /usr/share/fonts/nmsbd3.ttf...OK (Regular)
[FONT] adding font /usr/share/fonts/ae_AlMateen.ttf...OK (Replacement)
[FONT] adding font /usr/share/fonts/nmsbd3.ttf...OK (Console)
[FONT] adding font /usr/share/fonts/goodtime2.ttf...OK (LCD2)
[FONT] adding font /usr/share/fonts/Army_Bold_G.ttf...OK (GVFD)
[FONT] adding font /usr/share/fonts/analog.ttf...OK (Analog)
[iInputDevices] getInputDevices <ERROR: ioctl(EVIOCGNAME): [Errno 25] Inappropriate ioctl for device >
cannot open /proc/stb/avs/0/input_choices
--> setting scaler_sharpness to: 0000000D
Renumbering...
couldn't open /proc/stb/misc/12V_output
resolve: resolve ${datadir}/enigma2/keymap.xml
resolve: -> /usr/share/enigma2/keymap.xml
[ePopen] command: ip -o addr show dev wlan0
[ePopen] command: ip -o addr show dev eth0
setLCDBrightness 153
setLCDBrightness 229
resolve: resolve ${datadir}/keymaps/
resolve: -> /usr/share/keymaps/
Activating keymap: Keyboard English
[ePopen] command: loadkmap < /usr/share/keymaps/eng.kmap
Activating language Lithuanian
language set to lt_LT
FIXME: request for unknown slot
resolve: resolve ${datadir}/enigma2/setup.xml
resolve: -> /usr/share/enigma2/setup.xml
resolve: resolve ${libdir}
resolve: -> /usr/lib
[RemoteChannelStreamConverter] fallback to default translation for Remote channel stream converter
[RemoteChannelStreamConverter] fallback to default translation for Convert remote channel list for streaming
resolve: resolve ${datadir}/fonts/
resolve: -> /usr/share/fonts/
[getFonts] fontDir: /usr/share/fonts/
[getFonts] find font Display in skin_default.xml
[FONT] adding font /usr/share/fonts/tiny.ttf...OK (tiny)
[FONT] adding font /usr/share/fonts/ae_AlMateen.ttf...OK (ae_AlMateen)
[FONT] adding font /usr/share/fonts/analog.ttf...OK (analog)
[FONT] adding font /usr/share/fonts/Army_Bold_G.ttf...OK (Army_Bold_G)
[FONT] adding font /usr/share/fonts/nmsbd3.ttf...OK (nmsbd3)
[FONT] adding font /usr/share/fonts/nmsbd2.ttf...OK (nmsbd2)
[FONT] adding font /usr/share/fonts/goodtime.ttf...OK (goodtime)
[FONT] adding font /usr/share/fonts/Festival.ttf...OK (Festival)
[FONT] adding font /usr/share/fonts/Army_Regular_L.ttf...OK (Army_Regular_L)
[FONT] adding font /usr/share/fonts/goodtime2.ttf...OK (goodtime2)
[FONT] adding font /usr/share/fonts/tuxtxt.ttf...OK (tuxtxt)
[FONT] adding font /usr/share/fonts/titles.ttf...OK (titles)
[FONT] adding font /usr/share/fonts/prive3.ttf...OK (prive3)
[FONT] adding font /usr/share/fonts/ForgottenFuturistShadow.ttf...OK (ForgottenFuturistShadow)
[FONT] adding font /usr/share/fonts/army-digital.ttf...OK (army-digital)
[FONT] adding font /usr/share/fonts/lcd.ttf...OK (lcd)
[SubsSupport] looking for custom colors in /usr/lib/enigma2/python/Plugins/Extensions/SubsSupport/colors.txt
[SubsSupport] adding custom color customcolor1
[XBMC] Desktop size [1280x720]
[LCD4linux] libusb found :) 2016-05-16-master
[LCD4linux] FritCall not registered
[LCD4linux] NcidClient not registered
[LCD4linux] Bitrate not registered
[LCD4linux] WebRadioFS not registered
[LCD4linux] Netatmo not registered
[LCD4linux] GP3 not registered
remove DVI-PC because it does not exist.
set HDMI Colorspace : Edid(Auto)
hotplug on DVI
set Videomode DVI 1080p multi
set aspect, policy, policy2, wss 16:9 panscan panscan auto
[HDMI-CEC] ** WakeUpMessage ** send message: 4 to address 0
[HDMI-CEC] ** ActiveSourceMessage ** send message: 82:10:0 to address f
[HDMI-CEC] ** Active VU Message ** send message: 85 to address f
--> setting contrast to: 00008000
--> setting saturation to: 00008000
--> setting hue to: 00008000
--> setting brightness to: 00008000
--> setting block_noise_reduction to: 00000000
--> setting mosquito_noise_reduction to: 00000000
--> setting digital_contour_removal to: 00000000
--> setting splitmode to: off
--> setting sharpness to: 00000000
--> setting auto_flesh to: 00000000
--> setting green_boost to: 00000000
--> setting blue_boost to: 00000000
--> setting dynamic_contrast to: 00000000
--> setting scaler_vertical_dejagging to: disable
--> setting smooth to: disable
--> applying pep values
[AutoShutDown] set language to lt
/usr/share/enigma2/
<ZappingModeSelection> set zapping mode : mute
NFSMOUNT {'username': False, 'sharedir': 'h', 'sharename': 'vuduo', 'active': 'True', 'ip': '192.168.1.10', 'hdd_replacement': 'False', 'password': False, 'isMounted': False, 'mounttype': 'nfs', 'options': 'rw,nolock,tcp'}
[AutoMount.py] -getAutoMountPoints:self.automounts --> {'vuduo': {'username': False, 'sharedir': 'h', 'sharename': 'vuduo', 'active': 'True', 'ip': '192.168.1.10', 'hdd_replacement': 'False', 'password': False, 'isMounted': False, 'mounttype': 'nfs', 'options': 'rw,nolock,tcp'}}
[AutoMount.py] CheckMountPoint
[AutoMount.py] activeMounts:---> 1
[AutoMount.py] CheckMountPointFinished
[AutoMount.py] result None
[AutoMount.py] retval None
LEN 0
PATH im CheckMountPointFinished /media/net/vuduo
[UIPositionSetup] write dst_left : 15
[UIPositionSetup] write dst_width : 690
[UIPositionSetup] write dst_top : 15
[UIPositionSetup] write dst_height : 546
starting hotplug handler
add device sdb to bdpoll current state: medium inserted
add device sdc to bdpoll current state: medium inserted
starting BlackHoleapi handler
It's now Sat May 28 10:11:14 2016
[timer.py] next activation: 1464419574 (in 99612 ms)
[timer.py] next activation: 1464419574 (in 99609 ms)
[browser] browser start
Looking for embedded skin
allocating new converter!
[LCD4linux Support] set LCD4linux for DUO2 (ver Black Hole Edition)
[LCD4linux] Start Black Hole Edition (False), Libusb True, /tmp/...
[LCD4linux] ATA(SanDisk SD6SB1M1) - External (128.035 GB) ATA(SanDisk SD6SB1M1)
[LCD4linux] WebIf-Init...
[LCD4linux] Child to WebIf...
[LCD4linux] use old WebIf
[LCD4linux] use OpenWebIf
[LCD4linux] Info: no usbfs-Line in fstab
[ePopen] command: ping -c 1 82.149.226.170
[ePopen] command: ping -c 1 193.99.144.85
[ePopen] command: ping -c 1 209.85.135.103
[LCD4linux] Wetter check Network...
[CrossEPG_Auto] AutoStart Enabled
[CrossEPG_Auto] Schedule Disabled at Sat May 28 10:11:15 2016
port changed to DVI
mode changed to 1080p
default ('1080p', 'numatyta')
preferedmodes ['720p', '1080i', '576p', '480p', '576i', '480i', ('1080p', 'numatyta')]
[AutoShutDown] start....
PC: 00000000
00000000 00000001 77109b10 00000000
7411c3e0 00000000 762df370 00000001
00000000 00000001 00000000 76802980
74a96a30 76808380 00000000 767fc000
7411c2e0 7411c2e0 00606f80 005e8660
00680000 00000000 00800000 00000007
0000001c 00000000 00000000 00000000
771116a0 74a96d58 74a96eb8 770f21b0
[EPGC] setCacheFile read/write epg data from/to '/hdd/epg.dat'
[EPGC] time updated.. start EPG Mainloop
before: 1
after: 1
not showing fine-tuning wizard, config variable doesn't exist
showtestcard is false
reused converter!
setValue 75
Setvolume: 100 100 (raw)
Setvolume: 0 0 (-1db)
Setvolume: 75 75 (raw)
Setvolume: 16 16 (-1db)
warning, skin is missing element beta_no in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element ecm_info in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element button_emu in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element pv_emm in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element irdeto_ecm in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element cw_emm in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element bul_no in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element nagra_ecm in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element biss_no in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element orbital_pos in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element netcard_info in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element pv_ecm in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element irdeto_emm in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element irdeto_no in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element button_cex in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element cam_info in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element bul_ecm in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element via_no in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element dre_no in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element conax_no in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element Universe in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element dre_emm in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element biss_emm in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element cw_no in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element via_ecm in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element bul_emm in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element seca_no in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element biss_ecm in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element pv_no in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element beta_emm in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element nfreq_info in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element button_fta in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element seca_ecm in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element button_spider in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element via_emm in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element nagra_no in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element button_card in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element conax_ecm in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element seca_emm in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element conax_emm in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element nds_ecm in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element nds_emm in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element dre_ecm in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element beta_ecm in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element cw_ecm in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element nagra_emm in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
warning, skin is missing element nds_no in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
reused converter!
</enigma2crashlog>
<pythonMD5sum>
<![CDATA[
943167eb90dc3145e1b9f61dbd098c3b /usr/lib/enigma2/python/tools.py
41d347a6305f5523347e1d4e7b5e9989 /usr/lib/enigma2/python/GlobalActions.py
4ca5cf832f6e6c0a0f0474224d64a28d /usr/lib/enigma2/python/enigma.py
7b1eaef5e94cdd6bd40f3bc0f7f1d794 /usr/lib/enigma2/python/keymapparser.py
0b4897696936a4c0799525c7f1e73166 /usr/lib/enigma2/python/timer.py
b3422d679770a129342e52f6ca2978ad /usr/lib/enigma2/python/Tools/NumericalTextInput.py
d364549956b3cfabe13d9b6b561232df /usr/lib/enigma2/python/Tools/Import.py
d9d83467815003e745113b9a16a1473d /usr/lib/enigma2/python/Tools/DreamboxHardware.py
2bb2eab34660b5fcdf0b30f9bd1e8f44 /usr/lib/enigma2/python/Tools/Notifications.py
dbbb881f6c856e4cab017f518ba4a68a /usr/lib/enigma2/python/Tools/CList.py
b59a24f3c4925c36ab2b5c20a47d70cd /usr/lib/enigma2/python/Tools/ISO639.py
fec44e3c680135b636adcbc71044cab4 /usr/lib/enigma2/python/Tools/Event.py
a2218e726395499f00c72c393da3ba2c /usr/lib/enigma2/python/Tools/LoadPixmap.py
e3356c99fc63880d7cbe4495a03adb68 /usr/lib/enigma2/python/Tools/__init__.py
8c8b3e4062f8e5e9c72cceac90320a2f /usr/lib/enigma2/python/Tools/Profile.py
fc8e1e93a7429fba50acb0261f7f5268 /usr/lib/enigma2/python/Tools/RedirectOutput.py
bda1854fa7c66bbf581db1ec7d60b04c /usr/lib/enigma2/python/Tools/Transponder.py
b4011bd490319162c0bb7ab1fe0816f9 /usr/lib/enigma2/python/Tools/BoundFunction.py
a428aeab8edfef7d2dc4025084898ac4 /usr/lib/enigma2/python/Tools/HardwareInfo.py
a0639de72e3006e1001f4bf549017bb9 /usr/lib/enigma2/python/Tools/Directories.py
8d778f7f354f41c9d59672cfc25c4364 /usr/lib/enigma2/python/Tools/KeyBindings.py
09af65390e201fdc839573e5a5bc43f6 /usr/lib/enigma2/python/Tools/FuzzyDate.py
5e58ee8495c6b18b588e7c5b6069fa4c /usr/lib/enigma2/python/Tools/Downloader.py
c542bb10e8db238b1bd7cf3e2ca06aa9 /usr/lib/enigma2/python/Tools/XMLTools.py
cbe6d03d0dd9d165c8ec776c5c9adcce /usr/lib/enigma2/python/Tools/ASCIItranslit.py
0f292c2f68d9da26d688abc4f4f3a10d /usr/lib/enigma2/python/Tools/Alternatives.py
1c0cc241a9d4237f9ee663fe101eb379 /usr/lib/enigma2/python/skin.py
9a63922ca8a033d539a61fdb0baffb68 /usr/lib/enigma2/python/Navigation.py
5aa4cd0daae7d5ca56895527b5ef10c9 /usr/lib/enigma2/python/ServiceReference.py
2847ae9cd6ce7ef306501d30d1b675d3 /usr/lib/enigma2/python/SleepTimer.py
088bd12c66a5fe4c2b87678e274fc13a /usr/lib/enigma2/python/Components/Converter/MenuEntryCompare.py
12ce3af4bd6cd4a42268832d6863333a /usr/lib/enigma2/python/Components/Converter/ServiceInfo.py
6028ba4c8f7d61199ff5b7930089058f /usr/lib/enigma2/python/Components/Converter/HbbtvApplicationInfo.py
ba59f5b16994b087e2d5afa320cb0ac7 /usr/lib/enigma2/python/Components/Converter/g16EventTime.py
58b6e06f16433368d76847d3aba80372 /usr/lib/enigma2/python/Components/Converter/ValueToPixmap.py
2c2d157ea7d28a4a43f20b6408ac0394 /usr/lib/enigma2/python/Components/Converter/TunerInfo.py
e9ad04de2d8a3675865f942b3d45682c /usr/lib/enigma2/python/Components/Converter/g16GenerateMenuEntry.py
87e4bbae4ce58464d0c7ca9319726cd7 /usr/lib/enigma2/python/Components/Converter/MovieInfo.py
c69f2be99fd5121f983bb30976b6362c /usr/lib/enigma2/python/Components/Converter/g16ServiceNum.py
dc9a4c4fc79c6e128e0179fc30d19895 /usr/lib/enigma2/python/Components/Converter/StringListSelection.py
87c95b795e765d0651b875064d114541 /usr/lib/enigma2/python/Components/Converter/ServicePosition.py
919b568ec0ddeddd7798d2641e444c9e /usr/lib/enigma2/python/Components/Converter/StaticText.py
58fee00295729a2adb7033bf68371de7 /usr/lib/enigma2/python/Components/Converter/ProgressToText.py
003c185e53f95231e56347d12fc16184 /usr/lib/enigma2/python/Components/Converter/g16ExtraSource.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Components/Converter/__init__.py
4b8d476929f2c17190baf9d38fa70afc /usr/lib/enigma2/python/Components/Converter/SensorToText.py
f79cbe1d16c7875e1e48e45c86e52462 /usr/lib/enigma2/python/Components/Converter/g16ClockToText.py
38362c2c04914861eb86b7a7d69afa4b /usr/lib/enigma2/python/Components/Converter/ServiceName.py
a7de7fb276c23533cff437f8c978a4af /usr/lib/enigma2/python/Components/Converter/StringList.py
4078e76e1346d8f2a5e874efd2b904ac /usr/lib/enigma2/python/Components/Converter/RdsInfo.py
42b16b575d76c0e130ff3f007497d354 /usr/lib/enigma2/python/Components/Converter/ValueBitTest.py
c34a0a1a3f90265b36cbf8336ea7b7c1 /usr/lib/enigma2/python/Components/Converter/ConditionalShowHide.py
1af3046f0cd8d5a43cc89cfa20d970f5 /usr/lib/enigma2/python/Components/Converter/g16MiniTVDisplay.py
5d971edffdd2cd735683bb4c9093ef35 /usr/lib/enigma2/python/Components/Converter/ConfigEntryTest.py
17956139931985e8f54cb633cc1af8e4 /usr/lib/enigma2/python/Components/Converter/EventTime.py
73a07616a11fe77a022194d58b0940e7 /usr/lib/enigma2/python/Components/Converter/ValueRange.py
c2ce891153a2905b562e6e489554abc7 /usr/lib/enigma2/python/Components/Converter/g16GenerateMenuEntry2.py
b13c107d6ad058ba60856abcb94cb0c2 /usr/lib/enigma2/python/Components/Converter/BhAnalogic.py
3176888cde9c0efeed9ae52282e73dec /usr/lib/enigma2/python/Components/Converter/TemplatedMultiContent.py
af3845fb48965e926fd51a7439c85ee6 /usr/lib/enigma2/python/Components/Converter/Converter.py
28dde32d3346086a1ec64dc3ee1627f9 /usr/lib/enigma2/python/Components/Converter/FrontendInfo.py
2f5e9df85dd9c531dcf62a3aab5ecfe1 /usr/lib/enigma2/python/Components/Converter/Combine.py
450c953359065349aac382f76b21fdae /usr/lib/enigma2/python/Components/Converter/Poll.py
ac89bc29566c391499126b1a6f4500f6 /usr/lib/enigma2/python/Components/Converter/EventName.py
e90e83fd0a8fc7b634792ecd2a6edbda /usr/lib/enigma2/python/Components/Converter/StaticMultiList.py
15bea5fc9dbe47aac657be4a34439961 /usr/lib/enigma2/python/Components/Converter/Streaming.py
4c78fa5f5bf79d7fffe80a9a568043c0 /usr/lib/enigma2/python/Components/Converter/RemainingToText.py
a6ecc808c0328a437c61eb2ade05bea6 /usr/lib/enigma2/python/Components/Converter/ServiceTime.py
dacd153e2654877fc972f5e7171aec9f /usr/lib/enigma2/python/Components/Converter/g16ServiceNameEvent.py
da60ed1a4fde0806990486a01bd727e9 /usr/lib/enigma2/python/Components/Converter/ClockToText.py
fdd79c3bfa2aae2a5d0b6fe8951ce439 /usr/lib/enigma2/python/Components/Sensors.py
1bd1c3e110097a9e5e15b7a7ccd225ee /usr/lib/enigma2/python/Components/GUIComponent.py
ae9baee8c742036b23345f88e775a15f /usr/lib/enigma2/python/Components/Slider.py
630323f4905e84479b1ba21efdc799bd /usr/lib/enigma2/python/Components/PluginComponent.py
6d4f8f7e30285110a59c0e30c62640fd /usr/lib/enigma2/python/Components/PerServiceDisplay.py
a0ee417c4b6315857b9a2eef5d2b1a0d /usr/lib/enigma2/python/Components/ServiceScan.py
c49b29929b4e4162394dc2f7a8c772f8 /usr/lib/enigma2/python/Components/ScrollLabel.py
4bb6712fcb467e24fbe9f4aec3ca4f0a /usr/lib/enigma2/python/Components/FIFOList.py
24d7a0e6c32db9731a60dd1b5b66ca76 /usr/lib/enigma2/python/Components/TunerInfo.py
eff3a2b1612845f6e9193f4a89796a7a /usr/lib/enigma2/python/Components/VolumeControl.py
5f0b35419c901af9d211dc93b84e55d0 /usr/lib/enigma2/python/Components/HdmiCec.py
60b611b79da4d8d1099c344565670575 /usr/lib/enigma2/python/Components/ConfigList.py
8a0fe43501d2ad168ea15b4b4f147b84 /usr/lib/enigma2/python/Components/ServicePosition.py
fda2884a50d71cf31c89a54de97be5a2 /usr/lib/enigma2/python/Components/ResourceManager.py
a0185f66b4b197a347e9b10038323958 /usr/lib/enigma2/python/Components/ParentalControl.py
2e5c620136817ebddfa7b3331244113b /usr/lib/enigma2/python/Components/Task.py
9b323ecd29a78693c3fbd015f1136d4b /usr/lib/enigma2/python/Components/MediaPlayer.py
0d707152124791c90b82fbc6e844918d /usr/lib/enigma2/python/Components/HTMLSkin.py
4bb39ca2744867c41ff9d4230599e144 /usr/lib/enigma2/python/Components/Input.py
eaed1748abf9a6eda5113f38bc77031f /usr/lib/enigma2/python/Components/GUISkin.py
78c43ab613a6166cf5858eb963ba62bd /usr/lib/enigma2/python/Components/Sources/Config.py
5723d19be11ccbffd48502ade1010767 /usr/lib/enigma2/python/Components/Sources/List.py
f68dc995f78cfc88e26483ea787746ab /usr/lib/enigma2/python/Components/Sources/TunerInfo.py
44460c27e2763fb358898dc34907c140 /usr/lib/enigma2/python/Components/Sources/Clock.py
1da1958b336de06b874c9facb97d8e3e /usr/lib/enigma2/python/Components/Sources/ServiceEvent.py
b8b12180202bc1ca61007fd6b7ec7009 /usr/lib/enigma2/python/Components/Sources/StaticText.py
f2edeec29b502db62369e2283816ead4 /usr/lib/enigma2/python/Components/Sources/Event.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Components/Sources/__init__.py
7c307f1c09f73fbd61de82c2e2544d3d /usr/lib/enigma2/python/Components/Sources/EventInfo.py
8962f4fa89d8ff7fb8097e84ea120158 /usr/lib/enigma2/python/Components/Sources/HbbtvApplication.py
56c35c1b2af81757e84913b3eb816e6e /usr/lib/enigma2/python/Components/Sources/Sensor.py
c2929a5e2de2d1b3a94e2c38cd7274c5 /usr/lib/enigma2/python/Components/Sources/Progress.py
647e2f65fb79b2fae4a1c2ce5007b656 /usr/lib/enigma2/python/Components/Sources/CurrentService.py
ab296b833f2d34f06b5ac2a16c782df3 /usr/lib/enigma2/python/Components/Sources/Source.py
3059a135ceb0c3fca0867698f21fc2b7 /usr/lib/enigma2/python/Components/Sources/StreamService.py
b2b638612aa61f66e5c729d969dc96b6 /usr/lib/enigma2/python/Components/Sources/RdsDecoder.py
c6f7285e3f449c301dab92d92cfb1fce /usr/lib/enigma2/python/Components/Sources/FrontendStatus.py
d421be00754d02d85df804e4faea908f /usr/lib/enigma2/python/Components/Sources/RecordState.py
47312dcaaea9e981b3e22b2363898485 /usr/lib/enigma2/python/Components/Sources/FrontendInfo.py
11bd6ef9d574ab79c97d9f5160cabece /usr/lib/enigma2/python/Components/Sources/CanvasSource.py
ce001a44e6f7098624a6df98c1c5761b /usr/lib/enigma2/python/Components/Sources/Boolean.py
6a85468d2ac38a7f37dbc5f73415ca8f /usr/lib/enigma2/python/Components/Sources/ServiceList.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Components/components.py
ab2eef0ec82f8afbd8e5f6ed5128f02c /usr/lib/enigma2/python/Components/Keyboard.py
6b97ff9a5291eb296cfcefc28ceaceef /usr/lib/enigma2/python/Components/VariableValue.py
9624c59a9aff6a9bd343386939e8cef2 /usr/lib/enigma2/python/Components/ChoiceList.py
0e01a1e3e304e69f8d1b89a8ef22cd31 /usr/lib/enigma2/python/Components/About.py
db075a06a00091ac91dfdaae6fc66e37 /usr/lib/enigma2/python/Components/language_cache.py
6feeba1843947ec6baaeef017ad68230 /usr/lib/enigma2/python/Components/HTMLComponent.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Components/__init__.py
bd6e1b1d7ce8418c98695c1985f3d468 /usr/lib/enigma2/python/Components/ParentalControlList.py
62c655bbacc907e84cd14c4dc9972546 /usr/lib/enigma2/python/Components/BlinkingPixmap.py
d31b831df45818fd34d4d731b4483642 /usr/lib/enigma2/python/Components/Renderer/g16RefTV.py
eb1e8740111a5701267276004ddeda95 /usr/lib/enigma2/python/Components/Renderer/g16EmptyEpg.py
7dcaf7bebd1b96408b3b13f90a61d512 /usr/lib/enigma2/python/Components/Renderer/PositionGauge.py
75ac46f3148cf925f8dd66655a377496 /usr/lib/enigma2/python/Components/Renderer/g16Volume.py
97162532a308a672da8ae877f43ba6b9 /usr/lib/enigma2/python/Components/Renderer/g16RollName.py
307cbe1c7396024115dbf83e5b77ef53 /usr/lib/enigma2/python/Components/Renderer/Pig.py
51c3d5199aa64b68d73d998b68ef642f /usr/lib/enigma2/python/Components/Renderer/g16VolumeGauge.py
21b122350d330d9fe8e47357bc9a38f1 /usr/lib/enigma2/python/Components/Renderer/g16PicRef2.py
c7f1d6c32c28bcdc2248d3db6707a116 /usr/lib/enigma2/python/Components/Renderer/g16satTV.py
7b0aa9b18eb25016e3b5b3f250281731 /usr/lib/enigma2/python/Components/Renderer/FixedLabel.py
7b3fa122e2954cfe913bbfeae11b765c /usr/lib/enigma2/python/Components/Renderer/PixmapLcd4linux.py
443c21df1e8cc04e65a5e0825f9ea069 /usr/lib/enigma2/python/Components/Renderer/g16MenuEntry2.py
cc7b3ad617580d8125806336ad4a2422 /usr/lib/enigma2/python/Components/Renderer/RunningText.py
443216d1bd07bec56c0f5fca80c0c4ad /usr/lib/enigma2/python/Components/Renderer/g16ShowReference.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Components/Renderer/__init__.py
fbbf6e17eceee1951fdbf50821511830 /usr/lib/enigma2/python/Components/Renderer/g16ShowExtEpg.py
83384daaed9da756f7866d192d26b4b2 /usr/lib/enigma2/python/Components/Renderer/Canvas.py
d7be22ad384bb0a1933387ddd0c17142 /usr/lib/enigma2/python/Components/Renderer/g16RefTV3.py
f43a627a5e8fb9b7a4a5ca67db7bb42a /usr/lib/enigma2/python/Components/Renderer/Progress.py
1d37518d1e9e86746b3167f8aaed0945 /usr/lib/enigma2/python/Components/Renderer/Renderer.py
37836dbe189cb4ac497bc45964c45576 /usr/lib/enigma2/python/Components/Renderer/g16ShowTP.py
a2aa4d517c45f9f04bbfc0b4686eb5b7 /usr/lib/enigma2/python/Components/Renderer/g16RollerChar.py
80f941fbcb75a37077ce20a0195d3f78 /usr/lib/enigma2/python/Components/Renderer/g16MetrixHDRunningText.py
dee04d6cb026c838e87a4e55282b19e1 /usr/lib/enigma2/python/Components/Renderer/g16trpm.py
c947108f65672842ac96be1bf179690f /usr/lib/enigma2/python/Components/Renderer/Pixmap.py
4b43daadcd4728b9b688c14c36062240 /usr/lib/enigma2/python/Components/Renderer/Picon.py
aa1249c9a1ce56691a227df891da902b /usr/lib/enigma2/python/Components/Renderer/FrontpanelLed.py
9885ad26a9934623fd1e15d38909fe37 /usr/lib/enigma2/python/Components/Renderer/g16Ahours.py
06fcaa2166d99fb8a65da3abe9522a9e /usr/lib/enigma2/python/Components/Renderer/g16Progress.py
40a476255caa3b755c99c63bd014991c /usr/lib/enigma2/python/Components/Renderer/g16MenuEntry.py
6395adaf7ec9bd78244c6f24baf7489f /usr/lib/enigma2/python/Components/Renderer/Listbox.py
36ed7dd41eec63626eb79ce89452730a /usr/lib/enigma2/python/Components/Renderer/g16cutCHSS.py
fdc2c0963d41b40e55dcbb2bc34caeaa /usr/lib/enigma2/python/Components/Renderer/ChannelNumber.py
d1b315cd5c00d38fb9e9b8b4d7a012d1 /usr/lib/enigma2/python/Components/Renderer/g16PicRef.py
ae4183381040270c96baa391d91fb26b /usr/lib/enigma2/python/Components/Renderer/Bhclock.py
cf8426dd0124d5f852d034857dc8e1ec /usr/lib/enigma2/python/Components/Renderer/g16PicRefBig.py
04e397f071999432088ff2a954f8d707 /usr/lib/enigma2/python/Components/Renderer/g16MiniTV.py
553f5d98b7f212196fa8f84e5d52d7c4 /usr/lib/enigma2/python/Components/Renderer/g16ShowExtraEpg.py
7779d00ec0633251a4b83020ef55551a /usr/lib/enigma2/python/Components/Renderer/Label.py
5ca34b71f3b1f9f09d32a4a150498935 /usr/lib/enigma2/python/Components/Timezones.py
80b15609a3888689d42affe5e64fb864 /usr/lib/enigma2/python/Components/Harddisk.py
ee73da21a06410074bb749968c680955 /usr/lib/enigma2/python/Components/TuneTest.py
1f4cca2ae97c0322cc9e23acfca76276 /usr/lib/enigma2/python/Components/InputDevice.py
3b2edd9b322ed121c8f2e88cf76fa11f /usr/lib/enigma2/python/Components/RecordingConfig.py
c498dfaa263d90bd6f75430b02ab7ee4 /usr/lib/enigma2/python/Components/MenuList.py
0f0d4c2ed60e31e6593abaacc601c87c /usr/lib/enigma2/python/Components/EpgList.py
b0869deccb48eb53982607aef33c3978 /usr/lib/enigma2/python/Components/Gauge.py
28ae3c38f983d3306288437e1cdafaa4 /usr/lib/enigma2/python/Components/UsageConfig.py
1c4cac0789e596a771af1c7d358f2f84 /usr/lib/enigma2/python/Components/Console.py
dccd743706072981cae17fc0afcd6a52 /usr/lib/enigma2/python/Components/g16SelectionList.py
bc97eb5963b13419cfe4f1d9dc4a7c6f /usr/lib/enigma2/python/Components/DreamInfoHandler.py
a08636829f357ad582d52b123921b7ac /usr/lib/enigma2/python/Components/Lcd.py
4a5d006fa9b187e5008608b1b89bbff0 /usr/lib/enigma2/python/Components/ActionMap.py
b1849862a81e9abe67116d8be9abaebf /usr/lib/enigma2/python/Components/AVSwitch.py
5e3081a9e12c2298ddc888644346eb58 /usr/lib/enigma2/python/Components/g16ConfigList.py
cbc39aa5935ab3119f74e97329d4fef7 /usr/lib/enigma2/python/Components/SetupDevices.py
464c8a0e511dc879697d1a0d9766ef3c /usr/lib/enigma2/python/Components/Pixmap.py
4b27f5f16806fde8c7e6b0528082319f /usr/lib/enigma2/python/Components/Scanner.py
5e62e10eb42e7d7a0389834485be420f /usr/lib/enigma2/python/Components/TimerList.py
b2fe45714c4a542dc0aea365aabd3bb1 /usr/lib/enigma2/python/Components/ServiceEventTracker.py
4fdc9ae13b1284850d6f4153d44213cf /usr/lib/enigma2/python/Components/ProgressBar.py
4ef56c7d42734f87b3d5c4c3571f1301 /usr/lib/enigma2/python/Components/FileList.py
649caa4cffbd6098fc301b1e6cc49ade /usr/lib/enigma2/python/Components/Network.py
0660039b7b6e30b0f2274b222ead3741 /usr/lib/enigma2/python/Components/ConditionalWidget.py
aef22114ab5ec5233d363994f8c87b6f /usr/lib/enigma2/python/Components/SystemInfo.py
740cfba1ec935bde6fcf238d13cf103c /usr/lib/enigma2/python/Components/TimerSanityCheck.py
7d06bd081dd0e10b7019d8ac58708949 /usr/lib/enigma2/python/Components/Element.py
2d91cb867af3a14de7b63d70ca2af744 /usr/lib/enigma2/python/Components/NimManager.py
f2da3d8ed048eff55fe51e7401477d52 /usr/lib/enigma2/python/Components/HelpMenuList.py
467c4bfc1494992cceb8003b58b285c8 /usr/lib/enigma2/python/Components/PluginList.py
ed446633b70188c44fcd2d4866044bbe /usr/lib/enigma2/python/Components/VideoWindow.py
8a566189add219ba26e3204f2eb21164 /usr/lib/enigma2/python/Components/Language.py
912a9e2628776ccb2e83363fcc9c6e78 /usr/lib/enigma2/python/Components/SelectionList.py
b0e458255e15f1a8aec85f6288ef085d /usr/lib/enigma2/python/Components/Button.py
293601b503ad89e0ebe9bc8ef85c9dd8 /usr/lib/enigma2/python/Components/MultiContent.py
41e413d2ffa48a03fd0547df3b9a948b /usr/lib/enigma2/python/Components/config.py
c9da57a45f2d4465e16b51dd994bc79e /usr/lib/enigma2/python/Components/DiskInfo.py
8bcf68f46c11af120dcfc5e51ee0e720 /usr/lib/enigma2/python/Components/Playlist.py
2c1bd3117309881fef653c59d6d3b858 /usr/lib/enigma2/python/Components/RFmod.py
11000ec9591b9e5a9f5bed4037d2c91f /usr/lib/enigma2/python/Components/VolumeBar.py
7cce05e920a7a78949e4149a5eae7444 /usr/lib/enigma2/python/Components/MovieList.py
9f0161d7c0504b6ef817767d2bed97d5 /usr/lib/enigma2/python/Components/Label.py
3ad48f7632f11fc839e4773d9d399592 /usr/lib/enigma2/python/Components/ServiceList.py
7be136b6d1eaa13aaa08832390bd53ca /usr/lib/enigma2/python/Components/Ipkg.py
455a470bf796884de3cf5886fbbdbdb8 /usr/lib/enigma2/python/Components/FanControl.py
3b5dc0f7bf90523b8401499ae1c7aaec /usr/lib/enigma2/python/Components/VariableText.py
9ff38d1fbf23999885065144d273019f /usr/lib/enigma2/python/keyids.py
e5a84350b94e7e7c27dc57fcd00dff1c /usr/lib/enigma2/python/Screens/TimerEntry.py
202a551180e1dfdcf4e7ae135d8de685 /usr/lib/enigma2/python/Screens/EpgSelection.py
d0f876e8eb9172806e98e8bb849aadb2 /usr/lib/enigma2/python/Screens/SleepTimerEdit.py
0f567032df96cb79a9e7443cfb896682 /usr/lib/enigma2/python/Screens/NetworkSetup.py
c5c0ac1908fd39967894d1044d32520f /usr/lib/enigma2/python/Screens/RecordPaths.py
7b7a1f9add7e65ef4df0d89fa3162492 /usr/lib/enigma2/python/Screens/ServiceScan.py
a45a8111127038c94fe76acdcdf0cf3e /usr/lib/enigma2/python/Screens/ServiceInfo.py
a6c418ca660943e42fa2b2c72b8c2f7e /usr/lib/enigma2/python/Screens/FactoryReset.py
262b973b6346f1669ad83e2c67400a09 /usr/lib/enigma2/python/Screens/PVRState.py
fafa8e1cdfb5c7994ec52f7a627e58bd /usr/lib/enigma2/python/Screens/HelpMenu.py
6ca7aaac688af8fd97714fed42b0c771 /usr/lib/enigma2/python/Screens/ChoiceBox.py
910794de58e03cb7a9e68b5b15900fd5 /usr/lib/enigma2/python/Screens/InputBox.py
f09c91475b4d47bac3112605a1d520e1 /usr/lib/enigma2/python/Screens/InputDeviceSetup.py
5c715725c78fb2a0f4133663291994c9 /usr/lib/enigma2/python/Screens/Wizard.py
feb6b7a31bb9716fd322cec27a4166cb /usr/lib/enigma2/python/Screens/MessageBox.py
494d95e3c66df7ead1bf1adb38f7d2b1 /usr/lib/enigma2/python/Screens/Scart.py
15b19e6f30826c97c7fdfe0b35ad71c2 /usr/lib/enigma2/python/Screens/UnhandledKey.py
2348eb5cf08ee69a16de2f1815d3618b /usr/lib/enigma2/python/Screens/About.py
d501bc67ff36572c521ab3bd01da6cca /usr/lib/enigma2/python/Screens/WizardLanguage.py
bccc795a82aab24bd114c264706fedeb /usr/lib/enigma2/python/Screens/TaskView.py
df19a69823ea0743d51f8492e5719da2 /usr/lib/enigma2/python/Screens/AudioSelection.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Screens/__init__.py
372ed995725f003f56e3f231e0b3636c /usr/lib/enigma2/python/Screens/HarddiskSetup.py
9c371870eabb92c4be9f85586da55cef /usr/lib/enigma2/python/Screens/G16screens.py
cfac1258e71864b1ce1e0874fd70d854 /usr/lib/enigma2/python/Screens/LocationBox.py
5c995a40de39886c79d9fe3c3d45d7f7 /usr/lib/enigma2/python/Screens/RdsDisplay.py
1caf3058700bdc87bc00c54f2a85eceb /usr/lib/enigma2/python/Screens/NumericalTextInputHelpDialog.py
6b8536bae8bf29fc9bc49c5ada69389d /usr/lib/enigma2/python/Screens/Menu.py
a470453fae4245fc4905c768066384ae /usr/lib/enigma2/python/Screens/Screen.py
ea3df01e230dfb0e76fe1f6b8755b247 /usr/lib/enigma2/python/Screens/TimerEdit.py
3c44a1bb0a6687a3e8c4decd65b9fa43 /usr/lib/enigma2/python/Screens/MinuteInput.py
2c371a88055a052e82401b97646771e5 /usr/lib/enigma2/python/Screens/Mute.py
32afe8c8ca5e3bb865af86a296951d12 /usr/lib/enigma2/python/Screens/DefaultWizard.py
524fa9ce443eae4668e581cb996f7364 /usr/lib/enigma2/python/Screens/Console.py
89e899c61850b93498c2fbf2574db01a /usr/lib/enigma2/python/Screens/Standby.py
2fbb9c8d85a3144ac01a5d09e5219a6e /usr/lib/enigma2/python/Screens/TutorialWizard.py
4b4246ba0ca9bf6b3f9ea8cf788dc7aa /usr/lib/enigma2/python/Screens/ServiceStopScreen.py
697d7162de091ecf6dc24abdd1e2334b /usr/lib/enigma2/python/Screens/VirtualKeyBoard.py
1d812b4508da64c54eaf3aafe30eb1c5 /usr/lib/enigma2/python/Screens/Rc.py
616e4f5f8d67699c3564ac495ea4e091 /usr/lib/enigma2/python/Screens/ClockDisplay.py
b0b2b95a755c5d9d15975fe028821f3e /usr/lib/enigma2/python/Screens/EventView.py
00e41ec48fdea2fc1ec7ff36fb80fbf9 /usr/lib/enigma2/python/Screens/PluginBrowser.py
6b68c3e2070a4cadf05548549a43c785 /usr/lib/enigma2/python/Screens/Globals.py
3fe046757ebdbe062517190b33c226d1 /usr/lib/enigma2/python/Screens/ChannelSelection.py
42b427e6a8d1780a031949c731b16255 /usr/lib/enigma2/python/Screens/InfoBar.py
3d02e244781570049d5813d9f5178542 /usr/lib/enigma2/python/Screens/Ci.py
a1887da61746d8c7b190c1f9a6f79a5e /usr/lib/enigma2/python/Screens/Dish.py
e59f49df2e8ff48a45fc865e24e63308 /usr/lib/enigma2/python/Screens/PictureInPicture.py
586378f913a22adf52d797d07007e082 /usr/lib/enigma2/python/Screens/MovieSelection.py
74dcf98e11a972d249ce5fd011b97cb8 /usr/lib/enigma2/python/Screens/SimpleSummary.py
ca0361953b30f5fc919c4b77abfca0fb /usr/lib/enigma2/python/Screens/TextBox.py
e7bc2feca9f12a9169bc74c79d034e65 /usr/lib/enigma2/python/Screens/TimerSelection.py
bed413fe393934eb983fa308f27ae712 /usr/lib/enigma2/python/Screens/ScanSetup.py
d189f053b000b612c630638cca19912c /usr/lib/enigma2/python/Screens/LanguageSelection.py
f49c2918da9b1870bac153faa8717f91 /usr/lib/enigma2/python/Screens/TimeDateInput.py
4c7cdc559cb51a0281d41d4a3da63592 /usr/lib/enigma2/python/Screens/StartWizard.py
5fb5471b32577ac0d3f7dd07706e1616 /usr/lib/enigma2/python/Screens/Satconfig.py
21b0cca3002cf88fa8868bce113ab96c /usr/lib/enigma2/python/Screens/SessionGlobals.py
211f268cfa597d7eb6b1f17891224bcd /usr/lib/enigma2/python/Screens/SubservicesQuickzap.py
9fd6f2768180b538d3f35ce3e8cebcab /usr/lib/enigma2/python/Screens/SubtitleDisplay.py
6b6dfa299891f60e4e5365c6c04d31b7 /usr/lib/enigma2/python/Screens/Setup.py
9ff82fd344dab6739e2c11502dd2c52e /usr/lib/enigma2/python/Screens/InfoBarGenerics.py
2690da67e19ff3dc9c5bf2e9674c3353 /usr/lib/enigma2/python/Screens/ParentalControlSetup.py
30ace57c455e7f9755a5d1738671ba62 /usr/lib/enigma2/python/Screens/ConfigMenu.py
2026309d4bb26a778822e85541918335 /usr/lib/enigma2/python/Screens/Volume.py
b5bc1d71a6b661898d46e07c8152d592 /usr/lib/enigma2/python/Screens/Ipkg.py
d8ab85121817e311e336d530942f4e0c /usr/lib/enigma2/python/Screens/FixedMenu.py
5c836403cce8a029cdec5afa8538eb3c /usr/lib/enigma2/python/Screens/PiPSetup.py
796833f63a98ce6cb2284242c8a23689 /usr/lib/enigma2/python/Screens/Subtitles.py
31e52ae95724db4d598b8b6ea03e15db /usr/lib/enigma2/python/Plugins/Plugin.py
96a04c6daec7bf74e8c016e3acb7dbbb /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/SR.py
778d9117c1a1f4577c086a362e2014a9 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/wol.py
ec99af80f1eae414c6fdda2361e9032e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/stream.py
bd1fae049837d70d52bc8334234c07a5 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/ER.py
a2322b7a807ec3913099e5492ed3cb63 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/control.py
8d401668abb935117ddba258ba929c9e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/bouquets.py
1b3de99c2183bff8011216fcdad68a94 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/movies.py
6cad978ed87f7cf4bd0cb22cc26d3d65 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/satfinder.py
c6d4af208cfc6de5d1e878931aa7e6c8 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/timerlist.py
873b785056c77e1b70b9a687b54d11bf /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/channelzap.py
3b9b245ad1dbe8537f96a11cf251f0d2 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/index.py
676566fe9e5504ca76981f29c5e6712f /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/channelinfo.py
47e38910e45d66dd720c3dec222782a4 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/about.py
d0f294e40d759d859b63a06032b73ca2 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/timeradded.py
e6d6e5f294d606e483f236a88e53b85b /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/eventview.py
a745f9ee7558b2c1f3ef675b542b9b57 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/screenshot.py
14f6150deb645f167962120c46694838 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/channels.py
260121900500e65ded4f0c3bff962e0a /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/providers.py
01f7f08038a86382cc1eb4c76abda168 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/radio.py
dbdd531a44838ca1a38d2b7cd6cbc8c4 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/bouquets.py
932e94d2a477636b4686444bb0213181 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/movies.py
875b2d712a6cbd42d819e7abad359850 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/current.py
96f5e32c4b9dbac4ea57f68109f3f6f5 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/epgpop.py
b7b4e34cf259ef6bde2475bec2bf829e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/edittimer.py
c3d8578b859c27e58805cc59c9ff7fbd /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/tv.py
f990a67d28f97ffd607b55526c04ce6b /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/eventdescription.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/__init__.py
90212289e66c7d11930b03e351444302 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/at.py
b239c6aebf559b7bdfa2a05930058a41 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/powerstate.py
22bbd32e32f24b35338311a0326c652d /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/event.py
f06f7592adcdd993688bcd0d9ffe8bdf /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/settings.py
0838fb60f3343c92f33269ccc7b6d205 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/message.py
efac01ccf0473bdc430541a2a2b6f572 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/multiepg2.py
98c99e71906c204a0f852fd018a17104 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/epgdialog.py
7a55bcc925da8d86fcaa4bcfc6702782 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/timers.py
1dbaf8aba1f54a01e79a01130154533f /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/bqe.py
b2310d5674d54acb46047a3c4f5c6662 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/workinprogress.py
7016022af96aca1678efe4935e0dddd2 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/rebootdialog.py
80a804dcb5bb40a1bc87e5577b8df807 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/renderevtblock.py
a03786f862152e405ef3acdcfbff39f5 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/about.py
2c9f30564476c45fd1982f5cad07f892 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/epgr.py
0f2b2412940b086246cf0a6568d9e80c /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/satellites.py
c9edc827d635a5f718bbc63c8e397be6 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/config.py
2a67b5cc26ee8cea44992f9105b36516 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/multiepg.py
56d8c8348c73e1fcb2d6fb046656b357 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/screenshot.py
cc0fbbc59e2a7ecfc2bfa845a271e250 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/channels.py
8e0bf1b20c5c838825a658c26486f116 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/boxinfo.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/__init__.py
e744d081a14744743d6f0f2726731e54 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/movielisthtml.py
116b0e61aa649c911a45e04c1f0fce06 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgnext.py
40f7624a9215cf3de7c0f7267435c199 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgservice.py
6b518c3fc2cf6840c8ce188d0de5e96a /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/parentcontrollist.py
63f65ec103685ccc7c953c2f7588379b /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgservicenext.py
8a558fba9bf7c39721176c3e0a6d8eef /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/saveepg.py
15647c68417e01ff1a2c7a4c86883c9b /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/timerchange.py
19955e2eab43a020d4011ed3550df5eb /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/mediaplayeradd.py
d7edf72184b544c2f531d1c293fb0663 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgnow.py
3e80a4d0724fbb2694bc5b563f6ae1dd /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/deviceinfo.py
002f14391a8345dc4715def0a6745c0d /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/signal.py
9b186d863e1445142c6295a0d23340cf /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/bouquets.py
8e66e564bd46d42e1e9fbc913445513f /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgnownext.py
a079f98ccdf2b36fb6bf3510a6de7903 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/mediaplayerload.py
19373e2ead7d2026abd27e8d6f07b729 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/timercleanup.py
761e883195b0eeae1ed9d87622b79841 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/external.py
e9897b61e37856cf190e7f5dcdea2bde /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/getallservices.py
d3ed52e1611fd60bbfc9556f48c9f1a4 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/timerlist.py
95fc267dd55d0fbe45c5fc49b5f6970d /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/timeradd.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/__init__.py
58b785c7fd9ff29b5314fc3d0341c2cb /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/mediaplayercmd.py
d58b809e65c51e02e2c0f18202798aee /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgsearch.py
edc352871c1c45c971479f4c29a3499c /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/powerstate.py
7fdf9b27e03b33336e3af8e02d32dcdd /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/getlocations.py
6d17804d587b61d6004b37f614daa7b2 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/movielistm3u.py
e99a0eb1afc3366cfbce21f0b2641b7c /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/mediaplayerlist.py
4d2b2b18b51a5ac3783fa836196f26da /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/restarttwisted.py
e81f39c1b3cefd8bca185c9bdc7bfc2e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/getaudiotracks.py
f6d1952d096437e499fe643978fab1c9 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/getipv6.py
3fb21da31053763e4d5cbb05033c1903 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgsimilar.py
2e06efc5b098b8f6692e81b7b786dd32 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/mediaplayerfindfile.py
9a3a02bcde57d9092a7e3ea507925689 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/vol.py
1a526e06daf46705c7a16faceee03b79 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/settings.py
e955eab56769ed82cabf547bac073272 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/movierename.py
bab68554d073f18f5480f261379bf1d3 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgmulti.py
69e649b408e0d8c83d7986c09a3960ca /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/currenttime.py
63f1d005115955c2ea7588b6f9db2268 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/timertogglestatus.py
9ea4330472e5412be02bceaea92807b3 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/mediaplayercurrent.py
f1fb980c69488eb7a7def10fb7cde0ae /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/removelocation.py
4ca0bb7247911a7320edbd54afde40b4 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/remotecontrol.py
5938445b7f9b682429511053425ff331 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/streamsubservices.py
ce0d81e7739d65aef64ee7715130ad4a /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/gettags.py
d8c50b55223e4b5fb53666758b5aabdd /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/message.py
4e447ab1df2499f39e527e99eabf0af6 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/subservices.py
72e80fb03c4278bd3e0bb516c390b8e3 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/movietags.py
10040913963c4573c04a2bcfb31057fe /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/pluginlistread.py
74bcfbdd2e0045cd436c9c287fff1ecc /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/tvbrowser.py
37fdbcddaa468a569f4ae52c869309ec /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/getservices.py
1fa8c4f19fa6dac7db3e027c2087b039 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/recordnow.py
574475edd29efae087c39011977c88f8 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/mediaplayerremove.py
f0a1fcea722e65679759f250b5dd7a2b /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/sleeptimer.py
76b1ef61ca0ff12f5a62300d3fe1c704 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/about.py
433f609585f2558a9777557d4528bf74 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/mediaplayerplay.py
228f3f2c8ac47bade5b3a4765220fa5c /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/addlocation.py
2d2f268e80f18eb0b8aad7cff728bfde /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/servicelistreload.py
3a772024b4e898ceffc03e1f071aa56d /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/servicesm3u.py
e81a417899adccb8161a1d9b728e451d /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/loadepg.py
b5c3a6a941949d96fe70a756a4837d92 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/mediaplayerwrite.py
5710000496c587b2cdaf8671d4b2119e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgsearchrss.py
6eb835c97fc0712825e0adcf94f3085e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/servicelistplayable.py
5eea31f1d46eb97fd021f6ab68ed1ba0 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/moviedelete.py
5ff05ee86fd584aec39134df58099bd5 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/getpid.py
ce5d66147e58bdfc2fca12bfb7469093 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgservicenow.py
ddd76e2e7606e44b9b1a3121f234ecf8 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/movielist.py
9b5572787c931805e4042d529c5c0c69 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/messageanswer.py
d043b137e05d92164066960abbbb6f62 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/moviemove.py
ce3733f0e18b963426d1a4012622872e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/serviceplayable.py
c7df4dadc0f855a4166e608a95ca185b /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/timeraddbyeventid.py
8e88c22b63126ebfc070a32e94c87062 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgbouquet.py
72b358e9e0ae9b16c23c57da95e2dc5c /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/timerdelete.py
4f4bec377d1776d7f02e8d93c690417a /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/getcurrlocation.py
79260f0e6a88b5ab2292bd36fba25e7b /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/timerlistwrite.py
1edab5f5ed895e8e8268ebe8d3f9bb53 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/zap.py
f6cd07939ee9645891be3c5a3d5cdf0f /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/getcurrent.py
0cbebe0a50e847afe24e478769ea6207 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/movielistrss.py
9480f3b6a0219ba4d155b19e56c389eb /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/selectaudiotrack.py
a462f6f0b4e58c3b09b58e153aa22215 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/index.py
6e90ee38d54b2d09959dc3889b8dc2e9 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/main.py
332d07098f0a0c2019fe40772783d053 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/bouqueteditor/web/getprotectionsettings.py
49b87178509d6db607df5d22a80c65d5 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/bouqueteditor/web/getservices.py
e49edbc75b3bcd8b94c9ab1d7147ba75 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/ipkg.py
9ef5cff7f69a5fa50b74a4c3a8e9462d /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/base.py
cb000fb11986d1ee928236e438ae986e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/BQE.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/__init__.py
f13f1ab6b280dc0fcb254a9918ddf047 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/file.py
48922a9613ae776c0444311106dacd0c /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/root.py
21e8dc5b66b8128ed41347e477f6a1f7 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/web.py
3b818dbd521732b5e808113332f358cd /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/transcoding.py
1ea5e1b1df3e64bf46b8c88c1dce905c /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/AT.py
36082b395498b3a7d834f09ae477f9e2 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/api.py
c6490b1e1e0c584c6c748b5ef8abfccc /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/ajax.py
c97e280db47552107c28b3f7ae749f96 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/audiotrack.py
b9415d4fabca92c961e8ebf8761d256c /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/grab.py
24cc5871e2fe7114d877a6e82b582c0a /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/control.py
e96c2191ea52666e12ceb876be67614e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/mediaplayer.py
64291e5c09671db69934f6ea236045f1 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/locations.py
caaf4889ea3a0ebcad060d41c29b4a22 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/volume.py
ad612539245c4072638b16288024c1b1 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/servicelist.py
0af930f15ab213aef8ed0927617489e4 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/plugins.py
10c62cddf1a45d6eb16f0ed30f722ff3 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/stream.py
8be55e5d80c748b250bd8e5379d4237b /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/movies.py
cca8be220f8fd882e3315e1eefb364f5 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/info.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/__init__.py
4701f2dbc8cc695f64e7c320443ec22b /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/services.py
f7e9d66dbbf98309dd09705b95f72348 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/owibranding.py
513a9d947f0aaaa2609d29e89dd8c7f6 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/message.py
a5a7d7c93f5c5a6987ad580b5014f307 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/timers.py
6252f96167c1625b2a05926bb980454b /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/config.py
ecbf4fbf65e7dbb6cdcbda0aa9009726 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/BouquetEditor.py
26adffb86769888f24d805b35bc0ddeb /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/mobile.py
c6e5150d93f6e9c127541ea8e81287c3 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/local.py
86a2d7eab5788d8523bb8346b28a8512 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/plugin.py
784196d32b5284e434340978b980e2da /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/__init__.py
adf495b2a8fb6972ae24bcf9785c3360 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/httpserver.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/backport/__init__.py
0d1aedd2f897f09061ae6bfc78c4b61f /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/backport/OrderedDict.py
a968e836df31fea63bb4adcbf12906c9 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/sslcertificate.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/BhPersonalBackup/__init__.py
b72c7859893a76cafdfc32c65e1df0fb /usr/lib/enigma2/python/Plugins/Extensions/PicturePlayer/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/PicturePlayer/__init__.py
ef3ac8110d407d6e2b486094762ab757 /usr/lib/enigma2/python/Plugins/Extensions/RemoteChannelStreamConverter/plugin.py
e3f2b4c944c3506d87e4a2fed889e7ed /usr/lib/enigma2/python/Plugins/Extensions/RemoteChannelStreamConverter/__init__.py
bd5c5ee5a860cd29927ac464bc974356 /usr/lib/enigma2/python/Plugins/Extensions/RemoteChannelStreamConverter/FTPDownloader.py
24e81ac913b5983c0acf0b2e3c537d41 /usr/lib/enigma2/python/Plugins/Extensions/DLNAServer/plugin_ORIGINAL.py
b49abd98afe0d4802143f36a8e522b56 /usr/lib/enigma2/python/Plugins/Extensions/DLNAServer/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/DLNAServer/__init__.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/BhWeather/__init__.py
d1e9446c69b2747c127cf37efe03cf7b /usr/lib/enigma2/python/Plugins/Extensions/AddStreamUrl/plugin_ORIGINAL.py
9266834501824a568a58db1ea9f2fd33 /usr/lib/enigma2/python/Plugins/Extensions/AddStreamUrl/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/AddStreamUrl/__init__.py
de5feb4a109d8ee930aa6d6485e001b3 /usr/lib/enigma2/python/Plugins/Extensions/SubsSupport/subtitlesdvb.py
b975c10a0c1823069a17f9fa00a5ed1a /usr/lib/enigma2/python/Plugins/Extensions/SubsSupport/compat.py
a8220ca33554a30e539ca6fd5192d77e /usr/lib/enigma2/python/Plugins/Extensions/SubsSupport/process.py
9862608b65932326b0a8d6389421a7fb /usr/lib/enigma2/python/Plugins/Extensions/SubsSupport/searchsubs.py
b3e7364eb43703db0b79f30ed65296a7 /usr/lib/enigma2/python/Plugins/Extensions/SubsSupport/plugin_ORIGINAL.py
0909d0dd32ff2d92e8cee5a8a409bfa9 /usr/lib/enigma2/python/Plugins/Extensions/SubsSupport/plugin.py
3c7061b368ca497942dbea67b21fe57b /usr/lib/enigma2/python/Plugins/Extensions/SubsSupport/e2_utils.py
1cc10b70c5031e4155b53921f6d53cd0 /usr/lib/enigma2/python/Plugins/Extensions/SubsSupport/__init__.py
fd847c5cd44855934de75d0e716962eb /usr/lib/enigma2/python/Plugins/Extensions/SubsSupport/seek.py
cfa728b157f1ee858f0bbcfa787c9697 /usr/lib/enigma2/python/Plugins/Extensions/SubsSupport/parsers/baseparser.py
f06e21c90b86f3d862407e12ee437c1f /usr/lib/enigma2/python/Plugins/Extensions/SubsSupport/parsers/microdvd.py
b018403bc60dba20bbbc0d20e3f08440 /usr/lib/enigma2/python/Plugins/Extensions/SubsSupport/parsers/__init__.py
84721963aa5156caadf209bec138e997 /usr/lib/enigma2/python/Plugins/Extensions/SubsSupport/parsers/subrip.py
1dd22dcf7e8bb9b397a13834f3d9537f /usr/lib/enigma2/python/Plugins/Extensions/SubsSupport/seekers/Subscene/SubsceneUtilities.py
3a63ab68309758e2e96f5d3cabaa6ceb /usr/lib/enigma2/python/Plugins/Extensions/SubsSupport/seekers/Subscene/__init__.py
5be9aa12d7be95585cfd9e4c044ab5e9 /usr/lib/enigma2/python/Plugins/Extensions/SubsSupport/seekers/Subscene/service.py
81f9ae98561123838fc2d7c203e2724e /usr/lib/enigma2/python/Plugins/Extensions/SubsSupport/seekers/Titulky/__init__.py
2a7b49d193dac9c910a5d869b5397be7 /usr/lib/enigma2/python/Plugins/Extensions/SubsSupport/seekers/Titulky/service.py
3da15e62e7e6b7b5e193a4346ad70ba6 /usr/lib/enigma2/python/Plugins/Extensions/SubsSupport/seekers/__init__.py
cd517692a4cef2d2943e991613fe943d /usr/lib/enigma2/python/Plugins/Extensions/SubsSupport/seekers/Podnapisi/pn_utilities.py
16eb720a59400e1a386d4805db6e9d10 /usr/lib/enigma2/python/Plugins/Extensions/SubsSupport/seekers/Podnapisi/__init__.py
5fce575f0317749b33c08a91a49df37a /usr/lib/enigma2/python/Plugins/Extensions/SubsSupport/seekers/Podnapisi/service.py
b3c5e4fe2b10177d647bf145b68296ef /usr/lib/enigma2/python/Plugins/Extensions/SubsSupport/seekers/Itasa/__init__.py
0e61fedab6ff5381fa77d022a8f7dbc3 /usr/lib/enigma2/python/Plugins/Extensions/SubsSupport/seekers/Itasa/service.py
4cb44691b3e31f9083b9f958e5edb9ca /usr/lib/enigma2/python/Plugins/Extensions/SubsSupport/seekers/Titlovi/ti_utilities.py
6d0bf5584d2e11d710fc8daa36c80e87 /usr/lib/enigma2/python/Plugins/Extensions/SubsSupport/seekers/Titlovi/__init__.py
789b654b19de5647e68f9c95b5da83eb /usr/lib/enigma2/python/Plugins/Extensions/SubsSupport/seekers/Titlovi/service.py
b30594ff01caf34a5d9a2b9073273858 /usr/lib/enigma2/python/Plugins/Extensions/SubsSupport/seekers/OpenSubtitles/__init__.py
ddfb01bc5449cc2f90f3a09acc69eec6 /usr/lib/enigma2/python/Plugins/Extensions/SubsSupport/seekers/OpenSubtitles/service.py
036eeb02f13acbf315e44d6869bf4d0e /usr/lib/enigma2/python/Plugins/Extensions/SubsSupport/seekers/OpenSubtitles/os_utilities.py
5bf8707225684d6cae4e2c8b04de50f2 /usr/lib/enigma2/python/Plugins/Extensions/SubsSupport/seekers/Edna/__init__.py
a74cffb0ebee09bb42995cc63c83eed3 /usr/lib/enigma2/python/Plugins/Extensions/SubsSupport/seekers/Edna/service.py
2e7f508fba31125434a94838d43ba17b /usr/lib/enigma2/python/Plugins/Extensions/SubsSupport/seekers/SerialZone/__init__.py
a5ed939ab23812f821b1635e7a47d8a0 /usr/lib/enigma2/python/Plugins/Extensions/SubsSupport/seekers/SerialZone/service.py
6f2a1d5143dd70ca7c859964102852ec /usr/lib/enigma2/python/Plugins/Extensions/SubsSupport/seekers/utilities.py
f01957385d15165a232b080fd5a7441a /usr/lib/enigma2/python/Plugins/Extensions/SubsSupport/seekers/seeker.py
dd33c5cadd49962aaccd04403517861a /usr/lib/enigma2/python/Plugins/Extensions/SubsSupport/seekers/SubtitlesGR/__init__.py
51ffdc43bf10cd45e6af5e74f074fddd /usr/lib/enigma2/python/Plugins/Extensions/SubsSupport/seekers/SubtitlesGR/service.py
65e624b611fe06ad8b06b028b822cec1 /usr/lib/enigma2/python/Plugins/Extensions/SubsSupport/seekers/xbmc_subtitles.py
03bb9dd65349f4a8049d5593c4885d87 /usr/lib/enigma2/python/Plugins/Extensions/SubsSupport/subtitles.py
439a0383ecdd9a9493b4ba92a8f2e99d /usr/lib/enigma2/python/Plugins/Extensions/SubsSupport/utils.py
2b567aa940f4431bc0ef9f781225287f /usr/lib/enigma2/python/Plugins/Extensions/OpenMultiboot/open-multiboot-branding-helper.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/__init__.py
ad7d1b0d844ed90e83bc6ddbf332bcda /usr/lib/enigma2/python/Plugins/Extensions/HbbTV/browser.py
e48c059c6c8075908c788d7842d857a9 /usr/lib/enigma2/python/Plugins/Extensions/HbbTV/youtube.py
db371b0d5b3d25d44ab7842395b9d8fa /usr/lib/enigma2/python/Plugins/Extensions/HbbTV/aitreader.py
b9a4c14628b98c7e73faf8cc5d996c2e /usr/lib/enigma2/python/Plugins/Extensions/HbbTV/plugin_ORIGINAL.py
b047de2bfef7e385244f0ba1da2eec43 /usr/lib/enigma2/python/Plugins/Extensions/HbbTV/plugin.py
12dd9033895bbf2329cc437cc4eb86bc /usr/lib/enigma2/python/Plugins/Extensions/HbbTV/__init__.py
be7d58aee08e87f45f827ad2c7d78de3 /usr/lib/enigma2/python/Plugins/Extensions/HbbTV/vbipc.py
96f23745fca5bea86ae8b42794f29ee8 /usr/lib/enigma2/python/Plugins/Extensions/HbbTV/vbcfg.py
cc9b1ef6b60a5dd02a2a280784ad11d6 /usr/lib/enigma2/python/Plugins/Extensions/HbbTV/bookmark.py
d412c26ac3056b44160964ec25dac7df /usr/lib/enigma2/python/Plugins/Extensions/HbbTV/hbbtv.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebChilds/__init__.py
f66e93ef0623fc4838c3757df3159ebb /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebChilds/Toplevel.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebChilds/External/__init__.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/__init__.py
e495f59341b9d41c810732b50b001dc1 /usr/lib/enigma2/python/Plugins/Extensions/GraphMultiEPG/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/GraphMultiEPG/__init__.py
de13890a7a87818a991c43ef6146978e /usr/lib/enigma2/python/Plugins/Extensions/GraphMultiEPG/GraphMultiEpg.py
5a5ee3ee031612aeab6eca9207b6ad98 /usr/lib/enigma2/python/Plugins/Extensions/Kodi/plugin_ORIGINAL.py
944ad0baa783245f100c3f33c50785be /usr/lib/enigma2/python/Plugins/Extensions/Kodi/pipc.py
88c8019f91e829bcc6d190cd95a3feb8 /usr/lib/enigma2/python/Plugins/Extensions/Kodi/plugin.py
9f9107e9d0ddc7efd0a6699c9951340b /usr/lib/enigma2/python/Plugins/Extensions/Kodi/__init__.py
683b48ca286432ef10ffe6bd129151de /usr/lib/enigma2/python/Plugins/Extensions/Kodi/plogger.py
7842b316abd08722921a4505fb18e773 /usr/lib/enigma2/python/Plugins/Extensions/MediaScanner/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/MediaScanner/__init__.py
4cd3dfadedc2db72c8c0468431cf70cf /usr/lib/enigma2/python/Plugins/Extensions/MediaScanner/plugin_ORIG.py
8905ca88f7a8379ecb0118ecee9d46b2 /usr/lib/enigma2/python/Plugins/Extensions/BhFastEpg/plugin_ORIGINAL.py
72400c358f5232bc6ad91a38f7c703bc /usr/lib/enigma2/python/Plugins/Extensions/BhFastEpg/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/BhFastEpg/__init__.py
150f218b4461c255a04f694ad68dc75a /usr/lib/enigma2/python/Plugins/Extensions/CutListEditor/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/CutListEditor/__init__.py
3b4331906fa7d07df567313bac0d8fcc /usr/lib/enigma2/python/Plugins/Extensions/Cronmanager/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/Cronmanager/__init__.py
7031423d65f01ee3497123865132d459 /usr/lib/enigma2/python/Plugins/Extensions/LCD4linuxSupport/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/LCD4linuxSupport/__init__.py
574a5b9a3cd1c2aeca9b7e1ecf266c9e /usr/lib/enigma2/python/Plugins/Extensions/LCD4linux/WebSite.py
124e4ceed17d58fa70a48d8aa19a0a96 /usr/lib/enigma2/python/Plugins/Extensions/LCD4linux/dpf.py
51d26b738d0b433bbe201ab0aebddb18 /usr/lib/enigma2/python/Plugins/Extensions/LCD4linux/plugin.py
ddb5642b0c078b1a73d418670108e58b /usr/lib/enigma2/python/Plugins/Extensions/LCD4linux/__init__.py
a40b2fa879c34dfa2b5613aad839dffd /usr/lib/enigma2/python/Plugins/Extensions/LCD4linux/myFileList.py
dd922379812f8a86cd2191b9812af4f4 /usr/lib/enigma2/python/Plugins/Extensions/LCD4linux/WebConfigSite.py
0520de6eb56af61277812ec8677253f5 /usr/lib/enigma2/python/Plugins/Extensions/LCD4linux/ping.py
609e376a17080583bcce6e571dd5ddca /usr/lib/enigma2/python/Plugins/Extensions/LCD4linux/Photoframe.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/setupGlass16/__init__.py
550bed156ba4402cdab110e7fa9d9ce0 /usr/lib/enigma2/python/Plugins/Extensions/setupGlass16/weather.py
3331f493cfbebc75d19468c6667b72a8 /usr/lib/enigma2/python/Plugins/Extensions/setupGlass16/E_weather.py
26e03d391ebefd1630a7ec919efba17a /usr/lib/enigma2/python/Plugins/Extensions/setupGlass16/cfg_infoEcm_by_duri.py
c8ef66b79e32aa1abdfd1d1034b4e6fd /usr/lib/enigma2/python/Plugins/Extensions/DLNABrowser/plugin_ORIGINAL.py
40f774df6f660b6122782fab3ba5563c /usr/lib/enigma2/python/Plugins/Extensions/DLNABrowser/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/DLNABrowser/__init__.py
360fa49bfd3d8517529ecfff44ba7347 /usr/lib/enigma2/python/Plugins/Extensions/SatipClient/plugin_ORIGINAL.py
a9c53a890220b04b9c7ab979a7a0633d /usr/lib/enigma2/python/Plugins/Extensions/SatipClient/plugin.py
d784fa8b6d98d27699781bd9a7cf19f0 /usr/lib/enigma2/python/Plugins/Extensions/SatipClient/__init__.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/BhFullBackup/__init__.py
3d0b90bf193c5e092ed0f0cacaab7161 /usr/lib/enigma2/python/Plugins/Extensions/MediaPlayer/plugin.py
d784fa8b6d98d27699781bd9a7cf19f0 /usr/lib/enigma2/python/Plugins/Extensions/MediaPlayer/__init__.py
7bf99b4b797254f0536fbd08fef66f6f /usr/lib/enigma2/python/Plugins/Extensions/MediaPlayer/settings.py
325cbbddf515e2c0b07eb8773a19d9f8 /usr/lib/enigma2/python/Plugins/Extensions/StreamTV/plugin_ORIGINAL.py
e8a6c3d975409462e6ea3a588d10d2bc /usr/lib/enigma2/python/Plugins/Extensions/StreamTV/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/StreamTV/__init__.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/__init__.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/DemoPlugins/__init__.py
bb75aa44fc4c2c264890c1987759971b /usr/lib/enigma2/python/Plugins/SystemPlugins/Videomode/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/Videomode/__init__.py
557df59d0d09a31064e9b2c68865b9fe /usr/lib/enigma2/python/Plugins/SystemPlugins/Videomode/VideoWizard.py
f025dbeed240fdfafb16763bfc93da58 /usr/lib/enigma2/python/Plugins/SystemPlugins/Videomode/VideoHardware.py
b753599eda3eb9e205b33fa3a52135c2 /usr/lib/enigma2/python/Plugins/SystemPlugins/HDMICEC/plugin_ORIGINAL.py
6c111a27e09a22b0fee17b4404ce6e3c /usr/lib/enigma2/python/Plugins/SystemPlugins/HDMICEC/plugin.py
ecaa88f7fa0bf610a5a26cf545dcd3aa /usr/lib/enigma2/python/Plugins/SystemPlugins/HDMICEC/__init__.py
61f98a769c5ded0c8a64451697891120 /usr/lib/enigma2/python/Plugins/SystemPlugins/Satfinder/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/Satfinder/__init__.py
bdabe07cb8f9ee8f2e2a411007257823 /usr/lib/enigma2/python/Plugins/SystemPlugins/WOLSetup/plugin.py
dad0227408777290e6c56afc03cf6e12 /usr/lib/enigma2/python/Plugins/SystemPlugins/WOLSetup/__init__.py
d8f9b54aeb4984c2c49cb649196d3b30 /usr/lib/enigma2/python/Plugins/SystemPlugins/Hotplug/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/Hotplug/__init__.py
f4516684cc11cc6e12bf3a38eb66b3c3 /usr/lib/enigma2/python/Plugins/SystemPlugins/VideoEnhancement/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/VideoEnhancement/__init__.py
3052bd0cb91c112794c630ac519bdf84 /usr/lib/enigma2/python/Plugins/SystemPlugins/VideoEnhancement/VideoEnhancement.py
b9711f9f6bbc5c63fe41cb89447b7adc /usr/lib/enigma2/python/Plugins/SystemPlugins/AutoResolution/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/AutoResolution/__init__.py
01df99479502b3f82b288d27e87774b4 /usr/lib/enigma2/python/Plugins/SystemPlugins/AnimationSetup/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/AnimationSetup/__init__.py
ed5d1f3ba620894f6bf7ff9acc46dccf /usr/lib/enigma2/python/Plugins/SystemPlugins/AutoShutDown/plugin.py
b96ca0dcf09802b54a49653c799cafdd /usr/lib/enigma2/python/Plugins/SystemPlugins/AutoShutDown/__init__.py
76d4fc9c9dc116285294f9b79adadbc0 /usr/lib/enigma2/python/Plugins/SystemPlugins/NetDrive/plugin_ORIGINAL.py
fac376661182fcfe1a37e7c29e329fc7 /usr/lib/enigma2/python/Plugins/SystemPlugins/NetDrive/plugin.py
dad0227408777290e6c56afc03cf6e12 /usr/lib/enigma2/python/Plugins/SystemPlugins/NetDrive/__init__.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/__init__.py
da25b111fad50c4bd0e4ad9e244e3837 /usr/lib/enigma2/python/Plugins/SystemPlugins/SoftwareManager/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/SoftwareManager/__init__.py
b7c161d59170e825a894dec1d8b8c951 /usr/lib/enigma2/python/Plugins/SystemPlugins/SoftwareManager/ImageWizard.py
5cd63078da8d66aa7081d64b74692f40 /usr/lib/enigma2/python/Plugins/SystemPlugins/SoftwareManager/SoftwareTools.py
d1e4f463eeb0272a2f86f40c3a77a7aa /usr/lib/enigma2/python/Plugins/SystemPlugins/SoftwareManager/BackupRestore.py
c87765c4681a6e7aa403df4ea56f4d5e /usr/lib/enigma2/python/Plugins/SystemPlugins/SkinSelector/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/SkinSelector/__init__.py
867018726f190427b7a3e2060dd67396 /usr/lib/enigma2/python/Plugins/SystemPlugins/SkinSelector/plugin-ori.py
195ddbb7b2dbb1bdb5a304b19ac74621 /usr/lib/enigma2/python/Plugins/SystemPlugins/WirelessLanSetup/plugin.py
d784fa8b6d98d27699781bd9a7cf19f0 /usr/lib/enigma2/python/Plugins/SystemPlugins/WirelessLanSetup/__init__.py
330d7248bd8f33eae08e029eeff3fc5f /usr/lib/enigma2/python/Plugins/SystemPlugins/ManualFancontrol/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/ManualFancontrol/__init__.py
9e711050efee4fb877ac961ea365ce7f /usr/lib/enigma2/python/Plugins/SystemPlugins/ManualFancontrol/InstandbyOn.py
34014a1e03557b2ea809a95f8ab2e1f6 /usr/lib/enigma2/python/Plugins/SystemPlugins/ZappingModeSelection/plugin_ORIGINAL.py
b0c31804b336e610181c6869c683d985 /usr/lib/enigma2/python/Plugins/SystemPlugins/ZappingModeSelection/plugin.py
d784fa8b6d98d27699781bd9a7cf19f0 /usr/lib/enigma2/python/Plugins/SystemPlugins/ZappingModeSelection/__init__.py
1440586470e4335ea4e9838d1c785379 /usr/lib/enigma2/python/Plugins/SystemPlugins/PositionerSetup/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/PositionerSetup/__init__.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/BlackHoleApi/__init__.py
96b167a5bc0a61c430b35b2c8d769668 /usr/lib/enigma2/python/Plugins/SystemPlugins/FirmwareUpgrade/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/FirmwareUpgrade/__init__.py
73f624c3a4471cfaff8f186d87e217aa /usr/lib/enigma2/python/Plugins/SystemPlugins/Blindscan/plugin_ORIGINAL.py
94eddf9253f7953835d3a76e44c48291 /usr/lib/enigma2/python/Plugins/SystemPlugins/Blindscan/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/Blindscan/__init__.py
286db9f715fa9c074016e0132750128e /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/NetworkBrowser.py
2fd13d35fa6df0843208e85cfcf3bef7 /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/UserManager.py
6a352b0bfe8173ec89e5ce895b01eb6d /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/MountView.py
a9c118f12d3b3f4f0339c95f7778074e /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/AutoMount.py
da2d19e7d6c97c2f645bd34ce7fa7ff8 /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/plugin.py
19b45c6ada80382a72629591ba86580a /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/UserDialog.py
7010636521d6a0183f317e43ace396e2 /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/__init__.py
345624ddf9502612303aed3023d9e86d /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/MountEdit.py
340b79e10fdf7e759e103704b12fa2a9 /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/MountManager.py
276064d250af9c7fbe3e7ed7e2dc3998 /usr/lib/enigma2/python/Plugins/SystemPlugins/TransCodingSetup/plugin.py
2fec79ab33a706331074d99af93d6c94 /usr/lib/enigma2/python/Plugins/SystemPlugins/TransCodingSetup/__init__.py
a2008372ff89c62d07cb31e6a9de091f /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkWizard/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkWizard/__init__.py
027bd31cb0ddaaeb9cc6e967ae45403c /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkWizard/NetworkWizard.py
bb663a3aaf5263f588caac6c28b6844e /usr/lib/enigma2/python/Plugins/SystemPlugins/UIPositionSetup/plugin_original.py
df396d5eb4475e1d7658050ee406c487 /usr/lib/enigma2/python/Plugins/SystemPlugins/UIPositionSetup/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/UIPositionSetup/__init__.py
9f565e180deab436b5175874ee919ca6 /usr/lib/enigma2/python/Plugins/SystemPlugins/VideoTune/VideoFinetune.py
6307b4f8a6952cfd3532bc8bed7cb817 /usr/lib/enigma2/python/Plugins/SystemPlugins/VideoTune/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/VideoTune/__init__.py
0905898c9d2b681bde797d42cc60e63f /usr/lib/enigma2/python/Plugins/SystemPlugins/AudioEffect/plugin_ORIGINAL.py
446049d55e41f77c9d20c13138e6acac /usr/lib/enigma2/python/Plugins/SystemPlugins/AudioEffect/plugin.py
dad0227408777290e6c56afc03cf6e12 /usr/lib/enigma2/python/Plugins/SystemPlugins/AudioEffect/__init__.py
0ff6b1d31b6b25a6b7745658f179b22f /usr/lib/enigma2/python/RecordTimer.py
c8cb7ffe121f512968813014bcabf0cd /usr/lib/enigma2/python/e2reactor.py
27d752afe9f1f12d9732f09b6122ce3b /usr/lib/enigma2/python/mytest.py
46cf5439c0702ae3d52adf1e0df028af /usr/lib/enigma2/python/NavigationInstance.py
</pythonMD5sum>
</crashlogs>
</opendreambox>
Hi
Glad to hear that it Works but ............
you use a DMM Box with an VERY OLD Image so
don´t wonder if you receive some error massages
i would strongly recommend you to use a newer Image
but note it´s only my opinion ;)
Hi
Have you look at your Crashlog? there i can read:
enigma2 - experimental-git20121128-r137-bh32-bsp5
This make my think that you use an Old Image
but if the E2 stand from the Vu Boxes is 2012 than
i´m wrong so sorry for any irritations
Enigma2's recognition is "a little" failing :) But thank you for help, now I modified my HDglass16 a little and in not only works but looks fine too:
I do not like all those spanners, and other images, wasting the display area, so in place of them (on the right side) in main menu windows made a PIG.
HD Glass 16 ver. 10.66
- added next method to get HDD temperature (tryfix on some HW,SW)
- added next method to get bitrate (tryfix on some HW,SW)
- fix postinst script (ipk package)
- enh. weather translation: updated en, sk, cz
- added support and autodetect for new def. of the screen "Audioselection"
- added detection of the tuner A1, A2, B1, B2 (DMM specification)
- added new icon: tuners A1, A2, B1, B2 (after restore icons type will be set to default type 1, so after update and autorestore you must download icons and previews and then set/select your prefered icons type)
- added new renderer: g16TunersLabel - can detect max 16 tuners ans show state of each: missing, active, active at background(pip, recording), standby, all states are displayed in another color (all parameters like number of detected tuners, colors, used fond, separator can be defined in renderer)
- added new options: Enable icon Dcam, Dtype - all extrascreens
- help updated in download menu
- updated pl, sk, cz, en, ru, de, it, uk, pt, tr, es, fa, al, ro, hu, nl, et, lt
update is available online (setup and website)
Thanks to shamann
If you like this, please leave a thank you
thank you .. I have a question .. why c ant find the setup skin in main menu open pli 4 beta image .I have a message saying that plugin .pyo must be fixed ... so i c ant change any thing in this famous skin ... please reply
Sorry, but we don´t support OpenPli images, and neither this skin.
Of course you can use it, but at your own risk.
HD Glass 16 ver. 11.00
- added detection of **** (after restore icons type will be set to default type 1, so after update and autorestore you must download icons and previews and then set/select your prefered icons type)
- piconCam updated in download
- weather: yahoo pressure autofix if yahoo generate wrong recalculate units
- updated and added et translation (thx zeros, Henkka) to eWea
- fix Find a city if is selected from main menu
- added new option: Detection Progressive/Interlaced in resolution info line
- fix Channel number calculation
- added new Menu type: simply PIG
- added all config values to translations
Thanks to shamann
HD Glass 16 ver. 11.06
- fix date in some extrascreens and base infobar
- added to translation text from help pictures
- help: updated en, sk, cz translations
- added in "INFOBAR": TP type(color), TP info(color), Video resolution(color)
- added screens def.: autotimer plugin
- display info about new version as "Changelog"
Thanks to shamann
HD Glass 16 ver. 11.10
- updated enhanced weather translations
- fix multiple definition screens (deb version only)
- removed options: Autodetect HDD, Path to HDD, OLED dir, Picons/Icons path
- added option in section HDD: HDD and added new section "OLED"
- added options in section OTHER: Picons/Icons path, User defined path
- big optimalisation of the main code and changed definitions of some cfg values so after update will be some cfg/function switched to the default value and you can set your prefered options after autorestore:
Enable Enhanced Infobar
Second picon type
ECM line type
Volume type
HDD
Enable piconCam
Picons/Icons path
OLED dir
EPG selection type
Ignore infobar timeout
Enable control of network status
PIG type​
- updated help sk, cz, en
- removed section "SCREENS", items moved to section "OTHER"
- fix Extra screen 8
- weather: fix MSN if wind direction is not available
- fix user info: system info, side bar
Thanks to shamann
HD Glass 16 ver. 11.34
- updated enhanced weather translations: sk, cz, en, et, lt
- updated pl, sk, cz, ru, de, it, uk, pt, tr, es, fa, al, ro, hu, nl, et, lt
- updated help translations: sk, cz, lt, ru
- INFOBAR: removed - Simple base infobar
- INFOBAR/EXTRA INFOBAR - removed - Date format
- INFOBAR: added - Date format
- INFOBAR: added - Standard Infobar type (including def. Simle base infobar)
- EXTRA INFOBAR: added - Date format, Channel name (color), Event now (color), Event next (color)
- OTHERS: added - Ignore leading 0 in time
- INFOBAR: added - Standard Infobar type - Standard2
- fix channel number calculation - static
- MENU: added - menu type - with PIG2, with PIG3, with PIG4
- updated in download menu - Menu icons big
- fix date format parser
- added support and detection of DVB-S2X system
- TUNER: added - Hide tuner in standby or missing
- added Extra Infobar 54
- added support for DM900UHD
- OTHERS: added Single EPG type: with PIG(+number, ch.name)2
- OLED: added - oled type (DM900UHD, Vu+ 4k) - Classical, with ZZPicon
- changed Location box to Dir browser for path setting of picons/icons
- HDD: added type Auto (autodetection)
Thanks to shamann
HD Glass 16 ver. 11.38
- fix getting of HDD tmperature
- edited: Standard Infobar2 and Extra Infobar 33, 54 and Extensions list
- CHANNEL SELECTION: changed - New style(colored list) changed to New style2
- added Extra Infobar 55, 56
- help, extrascreens graphics a previews updated in download
- OLED: added - oled type (DM900UHD, Vu+ 4k) - Classical2
- fix USER INFO - system info
- WEATHER: fix SSL certificate error - Yahoo provider
- fix management of path setting of picons/icons
Thanks to shamann
HD Glass 16 ver. 11.47
- OTHERS: added volume type - Percentage2, Display Extensions as Choice box
- edited/changed texts in download menu
- CHANNEL SELECTION: added - Display remaining time in extra EPG
- added detection of fake ecm if is used
- WEATHER: added - Enable use SSL unverified content
- MENU: changed design of type List2
- fix restore config in the setup
- added detection et8500
- fix detection of tuners (A,B...,A1,A2...)
- ECM INFO: added ecm line type - CAID, SID, PCR
- fix detection of openAtv 6.0
Thanks to shamann
