HD Glass 16
HD Glass 16 ver. 9.72
- fix if all options from: Temp.HDD, CPU/Mem, Temp/RPM, Provider are disabled
update is available online (setup and website)
Thanks to shamann
If you like this, please leave a thank you
Thank you very much ennegi for updating us with latest release. Still this skin is the best IMO.
HD Glass 16 ver. 9.76
- fix Channelsel. type: ZZPicon 4, PIP 4, PIG 4 in images based on OpenPLi
- changed options from "Enable ChannelSel. percent" and "Enable ChannelSel. doubleline list" to "Enable
ChannelSel. percent, picon" and "ChannelSel. show channel number"
- updated pl, sk, cz, en, ru, de, it, uk, pt, tr, es, fa, al, ro, hu, nl, et
- help updated in download
- fix detection of tuner type in the name of channel if is enabled
- fix (DVB-T) convert Fq to channel number (fix for python 2.7.x and older)
- added full support and detection (DVB-C, DVB-T) for tp info in channel selections screens (all types)
Thanks to shamann
HD Glass 16 ver. 9.80
- extended detection of the resolution to: SD (SD), HD (HD), Full HD (FHD), Ultra HD (UHD)
- added new icons: FHD, UHD (after restore icons type will be set to default type 1, so after update and autorestore you must download icons and previews and then set/select your prefered icons type)
- changed HBB icon like standalone dynamic icon
- added definition of screen for Extensions
Thanks to shamann
HD Glass 16 ver. 9.89
- fix check CAIDs if 2 and more CAID definitions are present for the some CA system (dynamic CAID icons)
- added display selected special info in the main menu if special info is enabled in extensions
- changed download menu to new style with automatic calculation of required and free space
- add new option in download menu: download black/white picons of all/many sat pos.
- fix detection IP service (including stream relay)
- added new set of picon Weather (5) - if type 5 is selected weather will be will be autoswitched to new skin type
Thanks to shamann
HD Glass 16 ver. 9.93
- added new option: Special info in main menu - show/do not show selected special info in main menu
- changed design weather with icon type 5
Thanks to shamann
HD Glass 16 ver. 9.99
- added new option: "Weather units"
- added option for unints in the file /etc/(my_)city_Code.txt: "C" or "F" or ""
for example:
Reykjavik-980389
Moscow-2122265-C
Washington DC-2514815-F
- added new OLED type: "VU+ Duo2 Snr,Agc,RPM,Temp."
- added "City finder" for weather - located in extensions (press long or short blue button) - finded and selected cities are writing to /etc/my_city_Code.txt
Thanks to shamann
HD Glass 16 ver. 10.01
- added detection of the tuner "e" - in some images with support more tuners
- added new icon: tuner E (after restore icons type will be set to default type 1, so after update and autorestore you must download icons and previews and then set/select your prefered icons type)
- download menu: added option "Select" in some type of picons - you can select satellites and picons will be downloaded for selected ones
Thanks to shamann
HD Glass 16 ver. 10.02
- download menu: added more satellites in option "Select" in some type of picons
Thanks to shamann
HD Glass 16 ver. 10.05
- added new option: weather reconnect time
- added new option: weather provider - Yahoo, MSN
- added lt translation (thx Vytenis Pulokas)
- updated pl, sk, cz, en, ru, de, it, uk, pt, tr, es, fa, al, ro, hu, nl, et, lt
- download menu: removed ZZPicon (all) from options
Thanks to shamann
HD Glass 16 ver. 10.06
- fix weather reconnect time
- added support for "weatherlocationcode" in my_city_Code.txt and city_Code.txt
example: London-wc:UKXX0815
Thanks to shamann
Ciao @SrDave, il file .deb si utilizza col "più nuovo" OE2.2 (OE: OpenEmbedded) mentre il file .ipk si utilizza col "più vecchio" OE2.0
eh no... BH 3.0.1 monta OE3 quindi bisognere usare il file .deb
No spe non fare confusione!
Il file deb è da usare per quelle immagini che usano sistemi DEBIAN-style (DM sostanzialmente)
IPK per tutti gli altri che usano il sistema OPKG (praticamente tutti gli altri)
