HD Glass 16
HD Glass 16 ver. 10.11
- removed option "patch virtualkeyboard" - no more needed
- download menu: added option "Cleaning Picons" - clean picons for selected satellites (picon, piconOled, picon_50x30, ZZPicon)
- updated pl, sk, cz, en, ru, de, it, uk, pt, tr, es, fa, al, ro, hu, nl, et, lt
- fix displaying special info pressing button "help"
- fix some russian characters in default font (Regular)
- fix and full support for OpenATV images
- added new OLED type: "VU+ 4k Snr,Agc"
- added categories in setup of skin - you can switch quickly between categories by using RC buttons Bouquet+/- (P+/- or Ch +/-)
update is available online (setup and website)
Thanks to shamann
If you like this, please leave a thank you
HD Glass 16 ver. 10.16
- download menu: added 85.1E, 3.0E in option "Select" and "Clear picons"
- added detection "arm" architecture and full support for VU+ 4k
- added screens def for control Philips Hue Lamps etc.
- changed Menu type: List, with PIG and List 2 - pictures was moved to HDG files directory - from now any item of Menu can be autodisplayd with picture (if exists)
- download menu: added option "Download Menu Icons (540x540)" - used in Menu type: List, with PIG and List 2
- added detection of the tuner "F"-"L" (in some images with support more tuners)
- added new icon: tuners "F"-"L" (after restore icons type will be set to default type 1, so after update and autorestore you must download icons and previews and then set/select your prefered icons type)
Thanks to shamann
HD Glass 16 ver. 10.17
- fix Menu type: List, with PIG and List 2 - images with not support screen def "Menu"
- fix detection OLED definition (openATV images on DM boxes)
Thanks to shamann
HD Glass 16 ver. 10.20
- update screens def for control Philips Hue Lamps etc.
- fix detection dm820 (OLED type)
- added better detection of bitrate type (ebitratecalculator)
- weather: updated translations dictionary
- weather: updated sk, cz, en, ru, de, ro, uk, hu, pl, nl, lt, et
- main code: acceleration netstate checking
Thanks to shamann
HD Glass 16 ver. 10.30
- download menu: added 75.0E, 14.0W in all option with "Select"
- added new channel selection type: G16 events, G16 events 2
- added new option: ChannelSel. show satellite picon (work if Channelsel. %, picon is enabled - in some images not in all!!!)
- help updated in download menu
- added new option in download menu: piconSat 50x30
- some fix-es in deb version (OE2.2)
- added new set of picon Weather (6,7) - if type 6,7 is selected weather will be will be autoswitched to new skin type, after update you have to download a new sets of weather icons again
- setup: chanded from static to dynamic list (auto show/hide un/usable cfg items)
- setup: autocreate fullpath to icons if some dir in path not exists
Thanks to shamann
HD Glass 16 ver. 9.20
- added new option: Text rolling start delay (extended description - all channelselection screens)
- added support for Wicardd - infoECM plugin by Duri
bonjour .jai instaler hd glass 16 ,setup hd glsss ne donne pas le choix de configuration il est fixe.et moi je veux ajouter des picons pour info bar,aide svp?
HD Glass 16 ver. 10.36
- satellite picon and picon 50x30: ignore no UTF-8 and ASCII char in group name and support for sat. name in group name ..13.0E.., ..13,0E..
- added new options in download menu: piconSat 50x30 black and white
- added new OLED type: "Duo2 Snr,Agc,RPM,Temp. 2"
- changed option: show satellite picon - no, yes, piconSat only
- changed management of OLED type, so after update and restore will be set to default type then you can set your favourite OLED type
- added/changed: if list of cities is empty add None city only and change the first city in list as default city
Thanks to shamann
HD Glass 16 ver. 10.40
- added new option: Find a city with options - disable, in menu, in extensions
- fix restore config (setup)
- find a city: added support for searching "wc" and "fr" code
Thanks to shamann
Thanks to shamann
Hi @ennegi
Thanks by your contribution to our community, although as i have already told in other section ( Mediaportal ), and @angelofsky1980 said --> http://www.vuplus-community.net/board/threads/hd-glass-16.20366/page-3#post-194972 , the all.deb version is not for our VuPlus STB´s.
Regarding this i have edited and deleted from previous posts the all.deb files.
You only need, before testing it, to upload the all.ipk files.
Thanks in advance
HD Glass 16 ver. 10.46
- weather: added displaying error messages if connection to the provider server failed, added timeout to reading provider server data, added autoblock to multirequest (next city requirements), added autodetect and ignore if next cityhave not woeid defined and provider is yahoo, fix autocolor if units are F, added more error messages, updated weather translations, MSN - added calculate sunrise/sunset by using GPS and NOAA formula
- added new options: Show yesterday - if weather provider is MSN, Auto Reconnect time (error) - try in selected time reread data from weather provider if any error was detected
Thanks to shamann
HD Glass 16 ver. 10.48
- changed Bouquet+/- direction in the setup
- added new options: Warm color, Cold color - can be set autocolors or direct color - used in weather for High and Low temperature
Thanks to shamann
HD Glass 16 ver. 10.56
- weather: added support for translations without translation dictionary
- fix screen nimselection
- added new options: Fair color, Cold temperature (0-14), Warm temp. (15-40)
- added Enhanced Weather in: spec. info (extensions)
- added new option: show astro info (enhanced weather)
- help and menu icons updated in download menu
- enh. weather translation: updated en,sk,cz
Thanks to shamann
Hi ennegi, do you try it on the latest Black Hole? I love this skin, but installing it (v.10.56 *.ipk) on BH v.3.0.2.F and trying to change to the HD Glass16 skin, I got a message, that it is not compatible with this version of BH and do not opened. May be you know, what is incompatibility and how to fix it?
