HowTo flash/update Vu+ images
Hello mate.I use Kingston sticks on my Solo2 and the flash process takes about a couple of minutes.It'll probably take longer on a normal Duo.40 mins is way too long.
I don't recall seeing a blue LED, on the front of my VU+ Duo 2, can you please explain more.
When you switch on, from the rear switch, do you see the message VU+ Duo 2 CFE V2?
What happens if you press the menu button, on your remote?
Hi i have a problem. Cant install BH 2.1.7. Im with Vu solo SE with 2.1.3 BH. I try to install BH, but nothing happends. I unrar the files and folder put in USB. When i plug in on Vu, NOTHING HAPENDS. Starts normal, Like no USB, i change USB, but agen nothing. I dont know how to use Meoboot, if that is the problem? Did i hawe to MAP USB? I try 3 days to install, I'm about to break apart. I chose Softrware restore, and now its wors. Dont see BH 2.1.3. Did i must connect PC to Vu when im installing?
what i wrong???
IT IS VERY EASY WAY TO GET NEW IMAGES ON ALL SUCH KIND OF BOXES
GREAT JOB DONE BY YOU AND TEAM
I AM AFRAID TO BE BANNED FOR COUPLE OF WEEKS
MAY BE IT IS A VALID PLACE TO POST OR NOT SO KINDLY BE KIND AND HELP ME
IN MY SOLO SE
CAN I INSTALL IPTV S/W PLUGIN AND STREAM IPTV ON MY SE SOLO BOX
HELP PLZ
what i wrong???
KINDLY DESCRIBE YOUR BOX MODEL SO THAT I CAN HELP YOU
ALSO THE IMAGE YOU WANT TO UPDATE
IN MY SOLO SE
HELP PLZ
Would you kindly please can " write with lower case letters ", because it´s more easy to read what you wrote!
The big problem with ZERO
Hello
I just worked Zero device front lights
LAN port works but I have no video cable.
USB port does not work so I could give a new program Bhhsh
Black hHOL image was installed on Zero.
Has talked and worked first PLI image
Black Hole and got the latest version of the image after it happened.
what i wrong???
yep im having same problem, wish vu+ would sort this out, instructions are useless
