Latest Mediaportal
Thx for trying to solve my issue...:thanks:
This is very strange ... I don´t know more what i can do for you.
Upon updating your image ( with telnet ) ... have you tried reinstall MEDIAPORTAL?
Note: Upon installing it, don´t forget to restart your STB.
I had the exact same trouble as Steffan.
Having Argparse installed, and following steps made it work .
http://www.vuplus-community.net/board/threads/latest-mediaportal.12215/page-9#post-203926
the only thing i hadent tried myself before was
killall -9 enigma2
before updating drivers.That apperently made the trick.
thx for the help @nunigaia
I tried again...but still no luck. It installs under "Extensions", but does'nt show in Plugins. I get this "error" when trying to close Meny/Plugin:
WARNING
Some plugins are not available:
Extensions /TMDb (cannot import name eTPM)
Extensions /Mediaportal (cannot import name eTPM)
Extensions /MyTube (No module named apiclient.discovery)
How to find out if I have (or need) Argparse installed? I use Open Black Hole image....
Somehow, TMDb is also gone....before when I long pressed EPG button it showed together with Cool TV guide etc..
WARNING
I think the better is to uninstall:
  • Tmdb
  • Mediaportal
  • MyTube
Uninstall all plugins, to have plugins browser clear and not with orfan files.
AFAIK ... Mytube is not working, so you get Youtube plugin, you can get it here -> http://www.vuplus-community.net/board/threads/youtube-for-open-blackhole-0-1.24140/ --> last post ( lastest version ).
Tmdb maybe is corrupted or incomptabile with the image ... uninstall it to.
Mediaportal ... uninstall it and restart your STB.
Uninstall Mediaportal, connect to your STB by telnet, and write on the command line the follow:
opkg remove enigma2-plugin-extensions-mediaportal
Killall -9 enigma2
Uninstall argparse, connect to your STB by telnet, and write on the command line the follow:
opkg remove python-argparse
Killall -9 enigma2
Upon restart enigma:
Take hand of your (RCU) - Remote contol unit:
And install the plugin from the addons feeds.
I can't believe it......this morning Mediaportal was gone....I don't know if I shall cry or laugh.. :confused:? This is to much.
On my OpenElecBox (Wetekplay) it's working perfectly. I even managed to upgrade from 7.3.5 to 7.4.2 without any problems.
I'll give up for know with OpenBlackHole and MP. I'll think I'll try Black Hole's latest image from OpenMultiboot and see if it's working there...
(I see that this happened to others as well.)
I don´t use Mediaportal, don´t know if there´s a new version, i will investigate.
But ... how it´s gone? You can´t find the plugin? Is the plugin under /usr/lib/enigma2/python/Plugins/Extensions ??
It did not just go overnight, what did you do ?
It is on all my box's just fine.
Yes, it's there, but does'nt show up under Plugins (green button).
I have just rebooted or restarted enigma and then it does'nt "show up" any more. Some guy earlier in the thread had same experience.....
It seems that you have to follow the same steps indicated previously.
I tried to install the version above here the output of the commands
root@vusolo2:/# opkg remove enigma2-plugin-extensions-mediaportal
Removing package enigma2-plugin-extensions-mediaportal from root...
Removing MediaPortal Plugin from the system ...
root@vusolo2:/#
root@vusolo2:/#
root@vusolo2:/#
root@vusolo2:/# opkg install /tmp/enigma2-plugin-extensions-mediaportal_7.4.2_all.ipk
Installing enigma2-plugin-extensions-mediaportal (7.4.2) on root.
Checking for an older version of MediaPortal in the system...
MediaPortal was not found in the system
Checking free space...
Proceeding to installation...
Configuring enigma2-plugin-extensions-mediaportal.
Downloading http://downloads.sourceforge.net/pr...2-plugin-extensions-mediaportal-wallicons.ipk.
Installing enigma2-plugin-extensions-mediaportal-wallicons (7.4.2) on root.
Configuring enigma2-plugin-extensions-mediaportal-wallicons.
* MediaPortal installed *
* Restart the Engima2 GUI to activate the plugin *
how you can see I had no error message but still the plugin doesn't appear in the list
the same installin it from feeds
here my info about decoder is a vu+solo2
thank you
root@vusolo2:/#
root@vusolo2:/#
root@vusolo2:/#
thank you
Try doing newly all steps ...
before running uninstall MEDIAPORTAL
run this command from Telnet:
killall -9 enigma2
install MediaPortal normally from the addons feeds
