Latest Mediaportal
Hi
Maybe 1 of you guys has the kindness to Update the BH feed with the new MediaPortal 7.45 ?
cause if i do a MP Online Update,the Plugin updates but it is also delated from the List and
not more useable.
If i try to Install the .ipk manual i get an dependences error
only way to Install it in a BH Image is to overwrite all and everything with the new files
The Update is Fixing for example Burning-seri
Thx for your efforts
Hi
not more useable.
You can download it from the addons feeds ... @>>Artorius<< has uploaded it ... and must work with any problems.
MediaPortal 7.4.7
Thx @ all Dev´s
If you like this, please leave a thank you
Thanks @ennegi to port this to our forum and let us know for the new version:
I have repacked and appllyed the needed dependencies to install it in BlackHole / OpenBlackHole and OpenBH, and will ask to put it on the feeds too.
Until is not uploaded, you can use this new version repacked, that will install properly and with "no issues".
Why Is no time pointing to the developer further that it is A switch in the FREE menu , with the man Can make all portals during the initial installation visible , instead of always putting all individually on YES . This sucks somehow and would be really handy . All to Yes or No to all would be great. Can someone tell the developers to make this change happen?
I don't know the dev, but you are free to ask him.
Hi
Yes i try it and MediaPortal is now gone from the Addon List,as usual
if i try to Install any non BH .ipk File.
And yes it gave me an Error Massage,before i can read it the Install
Portal close and the Gui Restart Massage appears
