Latest Mediaportal
Hi
Yes i try it and MediaPortal is now gone from the Addon List,as usual
if i try to Install any non BH .ipk File.
And yes it gave me an Error Massage,before i can read it the Install
Portal close and the Gui Restart Massage appears
Test it ... and reply.
Hi
"grauzone.seriesever" "752" "Fixed with release 7.5.2"
"music.myfreemp3" "752" "Fixed with release 7.5.2"
Current expansion / revision of Pornhub.com plugins (with this / the next update (s))
- Access to personal favorites for videos / playlists (done)
- Access to subscribed members / Pornstars / channels (done)
- Access to recently viewed videos (done)
- Add / Remove video / playlist Favorites (done)
- Video recommendations based on personal profile (done)
- Category List revised (done)
- Channel Support (done)
- Add / remove subscriptions to channels, Pornstars and Members (done)
- Personal Video Feed and Feed Community (done)
There is a free account on the website needed to utilize the additional features.
I'll probably install similar adaptations even with Xhamster and YouPorn.
Hi
Can anyone of the Devs Check MP 7.5.2 from the Feed ?
It does not Install on my VU Solo 4K
Error Massage on the Picture
@ harddriver
Hi, try to force install it over telnet: opkg install --force-depends /tmp/mediaportal*.ipk
Hi
That may possible Work,no it does not,but it does not repair the error on the
Update over the BlackHole Plugin Feed
root@vusolo4k:~# opkg install --force-depends /tmp/mediaportal*.ipk
Collected errors:
* wfopen: /tmp/mediaportal*.ipk: No such file or directory.
* pkg_init_from_file: Failed to extract control file from /tmp/mediaportal*.ip
root@vusolo4k:~#
Hi
Collected errors:
root@vusolo4k:~#
@ harddriver
Try this version ... and post your results.
thank you
Hi
As you should know i can Help myself ;)
so i have Updated it by overwriting all Files,
means with this method i deal also the dependencies Problems with Black Hole Images
Maybe another User can Test it ?
Edit:
Ok i delete it an tested it with your attached File
it Works THX
so this File should be Uploaded to the Feed also
Hi
Edit:
it Works THX
Thanks ... i´ve asked yet to put it online
Hi
The Dev´s has not Updated the BH Feed,there is still 7.5.3 on it,so this is the
the only way to Update MP for the moment
