LCD skins VUplus Ultimo
Thanks my friend
Is this intended for me ?
If it is for me, Of course I know that you can use ten fonts in the skin
If you want to.
Rgd MX
No m8 .
Is for the beginners like "me" who want to try and make the VFD skins that suits them best.
regards Hija31
Ok I found a program that can resize image files quickly.
I have converted all the astra 1 and hb picons that have previously been uploaded, from 132x46 to 110x38 pixels (it won't do 110x40) and also 120x42 (again it won't do 120x45).
Hopefully they are of some use MX10
If not, feel free to delete this post :)
I am a new user in this community and when I have to hand the VU+ Ultimo picon bring all that the writer has created for the QBoxHD. Anyone who knows me already knows how to work. See you soon
Diamondear
Version 2 with Roller and Picon
Change
removed roller from channel selection
For speed and errors on loading event name
Support for picon
support for roller in InfoBar
support for Event_Now
support for Remaining event now
added HD ico
You can install in flash or USB
The package has everything you need
included Roller coding
included LCD Picon for HB 13E and Astra 19.2
Hi,
I hope you can help me.
My ultimo already had a skin with lcd picons.
Then I ftp your Flash_Ultimo_LcdPicons_Roller_MX_V2_bh to my box.
Now i have no picons in the display all are gone.
Did i made a mistike by ftp it to the box?
Is the usb version better, then how do i use it?
regards,
Rein
You can tryto install version from my post 11.With NO Roller.Roller is bad for image speed.
USB version is not better but you have more space to install Picone.
Okay, thanks that is clear, but I think to problem is how to install your version 11. Do I just ftp it to the box, or do i really need to install it? If the last, how do i install tgz files. I couldn;t find this on the forum. (I normally use only the extension i can load directly in the box.)
I'm at work
I do not have time.
You have to uninstall old instalation
green ...Yellow button ...uninstall BH packages
and FTP new file in to /tmp
install with green..yellow..install bh packages
I'm at work
I do not have time.
Thanks for your help, i will try tonight.
(i am also at work)
Have a nice day
be possible in the next release for vu + ultimo, choose different skin vfd, that would be fantastic
Ok I'll stop now this test
because I have something else to test.
I could not find any error
Pls test with clean image + drivers and default skin
plus my last LCD files NO roller coding and NO LCD skins with roller.
Can you provide me with some of yours skin_user.html which is compatible with BH 2.0?
Thank you.
