LCD4Linux Uno4K SE ,Ultimo4K,Solo4K ,Duo4K ,BH server
Lcd4Linux UNO 4K SE
(thanks @WebMan )
for those who have trouble to install
Install by this order
1. Install Lcd4Linux Plugin from image server
green button >>yellow>>Addons Download Manager>> Open BH or BH Plugins >>Lcd4Linux... download and install ipk package
or install manual plugin my ipk file copy/ftp to /tmp
green button >>yellow>>Manual Install Ipk packages
2.copy/Ftp Uno4K_SE_LCD4Linux_config_bh.tgz file to /tmp
green button >>yellow>>Manual Install Bh packages
info:
background picture wall.jpg is in /usr/share/enigma2/display/
if you plan to put another background.
Attention
if you want to uninstall Lcd4Linux plugin
1. First you have to delete skin_user.xml file in /etc/enigma2/
2. Unistall Lcd4Linux Plugin
green button>>yellow>>Addons Uninstall Panel>>...lcd4linux
restart
when I try to install lcd4linux plugin, I have a failure message and I cannot install this plugin. what is the problem?
No because obh panel is blocked in our country. so I download it from this topic and manually install it.
thanks
Of course this is a problem now.
You can not download missing python files.
Try to install manually if you have an ARM processor box.
I do not know if will succeed.
copy to /tmp install manual ipk in Manual install ipk packages panel
thanks. yeah my STB is UNO 4kSE and Arm -based chipset.
I will test it tonight
hey guys, need some help here. I tried to install it on my openpli running on VU+ uno 4k se. I managed to install the first version, then tried with the tgz option (but since I couldn't find the option to install bh I unzipped and installed manuallly). In the latter case I didn't see any update i.e. no picons showed up.
Anyway, it got worse. I was in the lcd4linux screen and I hit the blue button and suddenly the lcd went off. It works if the console is idle, but its off if the console is on tv or pvr.
I tried looking at the options, can't understand what to fix
I also tried uninstalling lcd4linux including removing all the files I added manually and anything in enigma2 referring to it.
when I did that, I got the standard issue lcd and it was working but if I install lcd4linux again and reupload the files that I got from your site (fresh download)..the same problem occurs.
Please help!
.tgz files are for the Black Hole images.
If you have the Black Hole, or Open Black Hole, images, installed you have 2 options, in the installation menu, manual install of BH packages, or manual install of ipk package.
This forum is mainly dedicated to the Black Hole images.
You might be best backing up your channel list, using Dreamboxedit, or dreamset, then do a fresh installation, of your preferred image, and start from the beginning.
I have vu + one 4k SE, the latest version of blackhole, I have installed lcd4linux and the configuration from the addons, but it does not let me enter the lcd4linux web
ipdeldeco / lcd4linux when load tells me access denied to the ip, can you help me thanks
Try this....
change the ip address with the address of your computer "lcd4config" in / etc / enigma2
and also "WebConfigSite.py" change 127. 192.168. 172. 10 " in / usr / lib / enigma2 / python / Plugins / Extensions / LCD4linux / and restart the vu +...
when I do this the web config is open for me.....only when trying stutter tv/mini tv makes my box in a looping error after reboot of box.
Config-WebIF Access Deny ( IP: 192.168.0.100 )
Please check Setting in Global > WebIF IP Allow Default is: 127. 192.168. 172. 10.
This came up vhen i start openWebif
And start LCD Linux settings What shall i do ?
just as I mentioned in my post above.
if you are familiar with ftp to box.
skåne rules.......
This is my files.
its a bit tricky to find,,,but in lcd4config near the end change
WebIfAllow=11.0.0.6..... to the ip of your pc.
and in WebConfigSite.py look for,
html += "Please check Setting in Global > %s\n" % _l(_("WebIF IP Allow"))
html += "Default is: 127.***. **. **.\n"
