AlexWilMac
Moderator
OK, today I had more time to go deeper into this field I had never approached before. And, @Matrix10, it's more clear to meant in some post, although there a new question.
I restored the original satellites.xml and there the problem is the same than in my file: the same transponders I couldn't use as "predefined" are not in the original satellites.xml as well.
And I see that are available (either in signal finder or in automatic scan by predefined transponders) all those transponders where you have
system="0" modulation="1"
For, instance, posting here just a few about 13°E (as I said: this is now the original file, not the customised one):
<transponder frequency="10719000" symbol_rate="27500000" polarization="1" fec_inner="3" system="1" modulation="2"/>
<transponder frequency="10727000" symbol_rate="30000000" polarization="0" fec_inner="3" system="1" modulation="2"/>
<transponder frequency="10758000" symbol_rate="27500000" polarization="1" fec_inner="3" system="1" modulation="2"/>
<transponder frequency="10775000" symbol_rate="27500000" polarization="0" fec_inner="4" system="0" modulation="1"/>
<transponder frequency="10796000" symbol_rate="27500000" polarization="1" fec_inner="3" system="1" modulation="2"/>
<transponder frequency="10815000" symbol_rate="27500000" polarization="0" fec_inner="4" system="0" modulation="1"/>
only the 4th (10775) and the 6th (10815) are shown in the GUI.
So, here we don't even have the options
pilot="2" rolloff="0"
but what makes the difference are system and modulation.
So I edited these values and (after a simple GUI restart) I was able to see them among the predefined transponders. Only...
only that I see, now, that the ones listed as system="1" modulation="2" are the DVB-S2 ones, whilst the system="0" modulation="1" are the traditional DVB-S ones.
The conclusion seems to be that you can't see the DVB-S2 transponders available for signal finder or for a scan by predefined transponders not because you can't have in the satellites.xml file or because there's a problem with it but simply because DVB-S2 transponders can be used only by a complete scan and not elsewhere.
Obviously, as always, you can tune a channel by a manual scan (that, in fact, needs a choice from the user between DVB-S and DVB-S2).
