Open Black Hole 0.1 update 19-06-2015 Vu+ Duo2
Hey
No it doesn't work The strange part is that all the other sections of idreamx work (streaming, control, EPG/TIMER,Movies,ftp). It is only Bouquets part where it says login failed. Idreamx contacts the sat box on all the other sections apart from Bouquets. I just can't figure out what to do!!(:
Hey
No it doesn't work The strange part is that all the other sections of idreamx work (streaming, control, EPG/TIMER,Movies,ftp). It is only Bouquets part where it says login failed. Idreamx contacts the sat box on all the other sections apart from Bouquets. I just can't figure out what to do!!:)
Sorry FTP does also not work. !!
Nope it doesnt work. What I dont understand is the movies part works, the EPG part works, So some of Idreamx works but some doesn't.
Do you have any suggestions where I should try and get some help?
You can try to see if you have a firewall that prevents you to connect with your STB, so, disable the firewall for awhile and give it a try!
Can´t help much more, cause i´m not an Mac User, sorry!
So, I've been trying several E2 images in my Vu+ Duo2, and I find Open BH the most fit to me. One of the things I like is the easy zapping in IPTV channels I have in a Favourite bouquet. In the regular BH, I had to open the full list of channels in that bouquet just to select another IPTV channels. But I really feel that Open BH needs some improvements. For me, it should be improved the media player, when watching movies with srt subs, the player hangs on a bit. On Open Droid, the player runs smoothly since the starting point. Another thing that has to be corrected is the hbbtv issue. I tryed the start/stop method but it doesn't work besides the info on the VFD. Also the YouTube TV thing, but since Google is always updating their service, I guess it will be a recurring thing. I hope the next update to Open BH can solve at least the hbbtv like it did on regular BH. Anyway, I don't want to be just a complainer, and I would like to help the project by doing a full translation to my native language, portuguese, since all the various images, even the original from Vu+ site, lacks of many things translated... How can I help?
I was looking to move from openvix to open BH because HbbTV also doesnt work on openvix. Same scenario: opera browser doesnt seem to start. Guess I will try the main BH image instead.
Hi there are many plugins don't work or available in BH any more I can't stream channels over home network etc so I painfully switch to PLI I have complained about it but BH team seem not to care so I took the highway for a while.
If you can´t stream over your home network ... is an issue you have, not the OBH image, cause i can stream with no problems. Check your network configuration!
Hi, just bought a new duo2. I do not have internet but want to update from the VU software,
Is this the file I should download 0.1? Also, do I need to redirect my tuners? Many thanks, S
PLEASE!
Can someone help me! I have tried to install XBMC from plugins but it mentions a dependency for enigma2 libgles extension is missing and will not install!
Any help resolving this without a complete reinstall would be much appreciated!
Thank you kindly...
PLEASE!
Thank you kindly...
XBMC is installed by default into OBH 0.1 / BH 2.1.7 and I don't understand WHY you should install it from plugin (?) menu.
Reflash is the better way to start from a clean and stable condition.
Because it was uninstalled :)
I really do not want to lose some of the settings I have made on the box... little tweaks and some software that runs I have spent a long time configuring...
I cannot just obtain this package that is required for opengles? install it and thats it no?
Ho un problema.
Mi sono accorto che non mi esegue la gui, devo per forza ricaricare tutto.
Se ricarico da gui il decoder rimane in carica per moltissimo tempo.
Come risolvere?
