Open BlackHole Online Update
WARNING! Immediately after the reboot, every files in my media/hdd/movie folder had been erased!
This is something never happened before! Terrible.
And, please, nobody try to tell it was me because I know that, immediately before the update, every recordings were there.
It deleted also many symlinks I had created.
P.S. (EDIT) The image was in omb whilst in flash there was OBH 4.2.026.
So, it was probably a bug in the kernel management from the OMB installed image.
It seems it was really a kernel management issue swapping from omb to flash. To solve I did this
1) a fschk
2) update of the image in flash. Now they are coherent, the whole content of the movie folder got back. Fortunately.
I hope this might be useful for others: probably is not a good idea to leave the image in flash less updated of the same ones in omb (although running images from omb instead that from flash is useful under many aspects).
Excuse me Alexwillmac:
I understand a lot less about you....
when I read your post (after translating it with the google translator) I worried and went to see my files recorded on HDD but I did not find anything abnormal
In my vusolo4k I have in flash OBH 4.2 (that I have updated to the 4.2.030 release) and in OMB the OBH 4.1, BH3.6, BH3.7, BH 3.8
This update introduced changes to the USB Turbo Vu + Tuner ... I will describe. After the upgrade I ran out of DVB-T channels.
Setting the tuner before updating:
FN7Lxc7.png​
The tuner is no longer configured, which did not happen before. It also has a different designation:
xMxkdIx.png​
Let's turn it on. We can choose to activate in both modes (c / t) simultaneously:
oVGWenX.png​
Here are the two modes. I can not test because I only have DVB-T. Can you deal with the two mixed types simultaneously ?:
0XjwjGU.png​
I leave here the information since, initially and not knowing this, the Zero 4K (this situation refers to the Zero 4K) the channels went through the network tuner coming from a 4K SE One.
4.2. 034 ho un problema con i canali che trasmesono in conax CI+ resta:aspeta per favore asesegnazione CI…….. con 4.2.018 funziona benisimo.
Secondo su:plugin display oe-a -lcdskin-8 vuultimo4k si bloca.
Thanks
Hi
I confirm this. With 4.2.018 my legacy cam CI Conax work very well, all releases OBH after 018 release a message of the common interface : Wait for authorization with black screen, channels not open (TNK and NC+). My box is VU+ SoloSE V2
Thanks
