Open BlackHole Online Update
has anybody has problem with transponder time my local time is 13:00 but show 21:00 with setbox I don't know if it's transponder time problem or NTP server problem but I hope get fixed
Transponder time and NTP servers are two different things!
How did you set up the Time matter?
Go to Menu/Setup/Time and, under "Sync time using" set it how you prefer. I always choose NTP and I've never had any issues.
Openblackhole 4.2.019
When is online update duo4k
Firmware is crashing
Thank you
Ahh yes, there was an issue with 019 for Duo4K.
For this update you will need to do it in telnet using the command:
opkg update && opkg upgrade
Afterwards everything should be fine again :)
Hello everyone
I'm still not clear on vu+duo4k tuner DVB-S2X FBC Twin Tuner PVR ready cannot do multistream can someone ex it well for me ?
Thanks regard
Hello,
When checking for updates, it says update. But there is no information. still update, restart again after the version again 4.2.025
Your information to be.
Regards,
