Open BlackHole Online Update
Open Black Hole 4.2, or Black Hole 3.0.6, haven't been released, for the VU+ Zero, due to the receiver not having enough power for the new features. The same as older VU+ models.
Open Black Hole 4.1 will do everything your receiver can handle.
si hay OBH 4.2004 zero . ultimo . solo . y a todos los receptores que ya no lo quieren en BH . en - vuplus-images.co.uk - .
Our team has not produced such image Open BlackHole 4.2 ( for 1st Generation Vuplus STB´s including the Zero ), though there is no support for such images ( generally also known as backed up images ).
version 4.1 is no longer updated, on another site I saw a 4.2 VUZero version ....
Remember that what you saw, if it was not, as Mick wrote, for the Zero4K, it could be a fake: you are 100% sure to download the original BHs and OBHs only in this forum, managed by their coders.
This doesn't mean you can't find (O)BH somewhereelse, too; but, why risk? ;)
When I try to do online update I get the following message ... " There has been an error, please try again later. If this issue persists, please check www.vuplus-community.net"
Any ideas on how to fix please???
Thanks.
Currently I'm on 4.2.012 software
Hi ExO that did remove the above message but I'm afraid I now get the following error ...
"Error - Problem retrieving update list." If this persists please rcheck/report on forum.
Sounds like you have internet connection issue's
A question to the developers: Is this on purpose that if the VU+ Uno 4k SE will be switched into Sleep under Open Black Hole and it's actual .img that the watched IPTV stream still continues by downloading? When I watch a IPTV stream and I switch the VU+ into sleep the network traffic stays the same - only switching off the VU+ stops downloading the stream.
With best regards
With best regards
Yes otherwise it is not possible to record iptv if the box is in standby.
Thanks. It would be appreciated to adjust this because mostly I could imagine nothing will be recorded and therefore the box needs to be switched off. If I then start again I always have to restart Enigma2 (GUI) because of the IPTV bouquet will initially not be loaded - only after Enigma restart.
Well if the coders decide to edit it, that is down to them.
However if you have an issue with your setup, then I suggest switching to a sat / cable / terrestrial (depending on your setup) channel before you put the box in standby.
