Open BlackHole Online Update
My last update was the same as yours, 20/01/2019, for a VU+ Duo 2.
Updates are only required when necessary, if your receiver is working correctly you don't need it to be updated.
The next Open Black Hole version might update Kodi to 18
027 released.
Still present the Bib PiP issue on Solo4K (but this is supposed to be a VU+ driver problem) and, also, the issues about managing different types of LNBs (one SCR+ other Universal ones) through a normal DiseqC switch.
By every 4.1.x it was possible.
Probably, also this one is a VU+ driver issue, but it's the case to remember to coders the issues we are experiencing.
027 released.
SO I cannot download it
in our country internet has a bad filter and we cannot access to your servers
Without being rude about it.
This is not our problem.
We are not here to provide ways around your country internet restrictions.
If you can not access our servers from your country and you can't use a vpn or something similar, then it is probably better that you look to use another image (not that we want you to do that), but we are not going to be posting new files everytime there is an image update.
Too many users complained in the past that they had to reflash everytime there was an update, so we switched to use online updates.
Hello. Even in the last update, after shutting down the vu ultimo 4k device completely, unfortunately, the internet connection is unavailable on the internet, either in LAN or Wi-Fi. And until the network is restart, the Internet will not connect. Please correct this problem. Fix it.
Nothing to fix, problem is your end.
What I realized when connecting the power to the modem and receiver and the Tv (you want to turn on the system), the adsl modem naturally lasts at least one or two minutes until the connector. The receiver is now faster, but the notebook adsl Still, the Internet has not been turned on, it does not turn on the receiver and the Internet connection is not connected, and after the modem is plugged in, then the receiver will not be able to receive the notebook. Now if the modem is still clear and the receiver is turned on at any time. Even a few days, I'm completely silent, there's no problem. That is, it's the initial distance between the crucial receiver.
Difficult to understand what you mean, but... if I understood something, your router is not always switched on (I suppose this is because your Internet connection is not a "flat" one but you pay per hour or per Gb; otherwise it's useless to switch off a router).
So, you'd probably solve your problems switching on with the appropriate advance of time your router: when it tells you the Internet connection is ready, you can switch on the other devices.
Anyway, it's strange if your devices does not recognize an Internet connection any moment: usually, there's no need to switch on a router in advance. But, perhaps, there's some problem with DHCP.
Anyway, it's strange.
