Open BlackHole Online Update
hello i have problem with latest update of OBH when i am watching recorded movie and set up zap timer for sports event my vuplus box don't exit from movie list and don't switch to the live channel it's just switch to pip
before latest update it's use to exit from movie list and switch to live channel
how to return to previous function
Are you using OBH from flash or from OMB? There are issues with this setting if OBH runs from OMB, although not in every models.
If it is installed in flash, just check the menu
Setup/Recordings, Playback & Timeshift/Recording & Playback/
and the option "Behaviour when a movie is stopped".
hi yes I'm using OBH from OMB I and have OBH also on flash and updated too
I tried to change Behaviour when a movie is stopped to (return to previouse services) and to (return to movie list) and (ask user)
is all the same on OMB and flash. always switch to PIP only
for me on VU + UNO 4K SE after updating to version 4.4.015 the openmultiboot start menu looks like this:
syntax: syntax (flash)
syntax: syntax:
syntax: syntax:
syntax: syntax:
I confirm but... with a different experience: the only two images in OMB recognised were:
-another instance of OBH 4.4;
-ViX 5.4
Instead were not recognized
OpenPLI 8.0
OpenATV 6.4
Black Hole 3.1.0
In addiction, OBH 4.3 is not even listed.
syntax: syntax:
syntax: syntax:
syntax: syntax:
Should be fixed now if you do another online update
Using openbh for many years, she is the most perfect and most stable. There are more than two thousand Chinese users. Recently, many people are looking for simplified Chinese methods. I have uploaded my own Chinese documents. Please review and add them. Thank you.
enigma2-1/zh_CN.po at patch-1 · live526/enigma2-1 (github.com)
Fix the error
Ok this has been added to obh (should be in the next build).
For future updates, please create pull requests here: https://github.com/BlackHole/enigma2
Also please create a simplified chineese translation file for the obh-core and submit the pull request here: https://github.com/BlackHole/obh-core
... now after the next update I have this:
openbh: (flash)
openbh:
openbh:
openbh:
I can not replicate this error at the moment, however omb is still work in progress, so hopefully it will all be fixed within the next few days.
If you can not wait, once the image is booted, open omb manager and rename the images that do not show the correct names, then when you reboot the boot menu will read the labels you have set for the image names.
Thanks to the master for agreeing to join simplified Chinese, but our system is multilingual, our system can be used all over the world, sincere thanks, I will be the most accurate Chinese translation later, so that our black hole firmware will be more perfect and powerful, thank you most It’s the hard work of the developers
