Open BlackHole Online Update
An update shouldn't change anything.
I've just checked, on my VU+ Duo2, following the latest update, and I can still do the quick connect, with Filezilla.
Have you checked just in case your receivers IP Address has altered?
Internal VU+ Tuner. not VU+TURBO
I didn't say that there are tuning problems; only that the value is not the same it was before the update.
Obviously, is only a relative measurement: nonetheless, it has got its meaning.
I've just checked also the VU+Turbo and with it the SNR displayed is not a fixed value of 100% like for the internal tuner.
Hi Everyone, I using Obh v4.2.001 on Duo2. For about a week now I am not able to do any update. Please see attached photos. Thanks & Best Regards
Se avessi letto i post dell'altro forum, ora sapresti che ci sono problemi per il dominio, e quindi per i server OBH / BH.
Leggi almeno questo:
http://www.vuplus-community.net/board/threads/temporary-fix-for-bh-obh-feeds.37601/#post-251130
Ciao, tutti siamo a conoscenza dei problemi della nostra BH.
Per poter fare l'aggiornamento si deve fare qualche procedura ( se si, potete informarci della procedura da fare) oppure dobbiamo pazientare che venga ripristinato il dominio?
Ti ringrazioo della vostra pazienza e collaborazione che date a tutti.
hey there
guys i can not still update my solo4k box to the latest version of obh4.2.04
is there any solution to this?any scripts?patch?
