Open BlackHole Online Update
Always the same story with change.
Do you want to use old images your whole life ?
Of course there are a lot of bugs and plugins that don't work.
So there are only two options.
Or keep using the old image or uses new and follows developments.
The new plugins will probably no longer work on the old image.
Just like some old ones won't work with PY3 images.
This is called the transition phase ,which we had before in E2 images.
I said "for now" not forever.
Just the time to find all my plugins (or equivalent ones) written in py3 and I'll upgrade my Vu+..
Kind regards,
R.
Inviato dal mio CPH2173 utilizzando Tapatalk
OK, ma it's the software the must adapt to the O.S., not the other way round!
So, it's totally useless to complain about the O.S., in these cases: better complain to the SW authors.
There is some point in the updates (by version 4.4.13, if I'm not mistaken) that channel change has become too slow, and it remained so in version 5, too. Maybe it depends by some sort of not perfect management of my lnb (dura-sat unicable II)?
You're right، after update to obh version 5 channel change became too slow, delay in info bar appearance
I also have unicable Spaun SUS 21 and the channel change is on slow....
Yes there were some changes in the enigma2 code and the oe-core that have slowed the channel change / tuner lock a little, it is what it is though and it effects all the oe-a images from that point onwards as far as I am aware.
After several days of testing, it works perfectly: Bitrate, CacheFlush, EPGImport, LCD4linux, MultiStalker, SubsSupport, IPTVPlayer, VlcPlayer, VpnManager, XStreamity, YouTube, Chromium.
Lost MiniTV, MediaPortal, MediaPlayer2 that cannot be run, and requested repair to add MiniTV. The system starts up slowly, runs quickly, there is a problem with the backup during the upgrade, and it keeps backing up, so the upgrade can be updated with commands. The Chromium is very smooth. It would be perfect if the selected language remains unchanged. The final summary is still very stable and perfect. Thank you for your hard work.
Bitrate work for you !!!!
which type is your device plz
Master, the simplified Chinese you added is good, but the font is not called, now the garbled code, I can’t understand the font calling, please add the font calling, 5.0 is still changing, I simply fixed the Chinese content and waited for the system to change slightly. I have localized the entire system on a large scale, and now more than 90% are localized. Because I am not proficient in foreign languages, the following pictures are used to show the meaning
Please I have said to you before.
Make any pull requests for Enigma2 language files here: https://github.com/BlackHole/enigma2/pulls
And for openbh-core language files here: https://github.com/BlackHole/obh-core/pulls
I can not constantly check the boards for user submitted updates i'm afraid.
