Open BlackHole Online Update
Hi All
I have a no problem when my uno4kse & Duo4k online update obh4.4.023 but don’t worry MR Evo boss will very soon release
obh4.5.001 with py3
Please wait all of my friends
Thank you
@lousio77 It's kind of hard to guess whats wrong so describe better what is the problem.
1 Does it boot up and you see the OBH startup screen?
2 If so how far does it go, Is straight to blackscreen or is just stopp?
3 Kan you get into your box with ftp and telnet/terminal?
4 If so check for a crashlog in location /home/root/logs.
with the latest update the problem solved!
I think he mistook, in the answer, the install by the update. Because, otherways, how can the last update date precede the install date?
I think he mistook, in the answer, the install by the update. Because, otherways, how can the last update date preceding the install date?
Because the install date is the one when you flash ( or unpack the image when using OMB ).
So ( Simple ):
Because the date of the update is previous then the installation date!
