Open BlackHole Online Update
This is NOT a big bug: first of all because IPTV is not the main use of a satellite+DTT receiver;
As I wrote before, I have same bug (I agree with you that this is not a big bug, but it certainly is a worsening compared to version 4.13) And I do not use iptv. Only DTT and SAT
Some people have been saying that it's my plug-in problem. When the compiler finds the feedback, they should find the problem to fix, not shirk it.
I confirm that the latest update makes channel changes very slow. The tuner seems to lock very slow.
This did not happen with the former software version.
Hi, recently my Duo2 freezes after an hour or two of continuous playback of recorded show in internal harddisk. With today most recent update (v4.4.022), it also freezes. I had tried both player (Exteplayer & Original) and still the same. During that period, there were no recording or any other activity. Please help
I doubt this has anything to do with the Open Black Hole update, and you should start a new thread.
You could check your receivers temperature, and check if your hard drive is faulty.
One method is to try viewing a recording, from a USB stick. Using your PC download a film, or music videos, store them on a USB stick, then play them on your Duo2.
Hi Mike12334, thank you for the advice, I will try it out.
I correct myself
Zero 4k is updated but in the info menu on the decoder there is always the written release 4.4.22
In my case it says 4.4.020 ;) But I don't update it very often, so I don't remember what was written before. What is sure is that the automatic backup, scheduled just for today morning, wrote 4.4.020 in the filename.
openbh-4.4.013.release-vuuno4kse_usb_release is a bit old and cannot play iptv. Each update requires more than 220 patches. Please repackage a stable and complete package if you have time, thank you
Recently, the push server is obstructed and it is recommended to use vpn proxy push if the push cannot be pushed smoothly, so that the update will be completed soon
