Open BlackHole Online Update
Installed 5.0.004 in Vu Ultimo 4k inadyn in the procedure of data entry with the remote control it crashes with green screen...
problem also found in previous versions.
  • Like
Reactions: Ev0
good morning
I follow the usual update procedure, but update loops all the time without updating.
Only way to unlock remove power...
Thanks
Hall
Is it possible to use lcd4linux in this version? Because it seems that generic lcd skin predominate over lcd4linux configuration
View attachment 51333View attachment 51334View attachment 51335
good morning
Thanks
Hall
Does the issue persists?
If yes, please:
- during the loop try to retrieve the content of "/var/log/backupmanager.log" and post here
- during the loop try to telnet/ssh to the box and digit following command:
mount
and post the output here...
df
You should get something like this:
root@vuultimo4k:~# df
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/root 3655616 1582092 1868112 46% /
devtmpfs 799592 4 799588 0% /dev
tmpfs 64 0 64 0% /media
/dev/sda1 488161280 259731600 228429680 53% /media/hdd
tmpfs 807912 1204 806708 0% /var/volatile
tmpfs 807912 0 807912 0% /sys/fs/cgroup
root@vuultimo4k:~#
if the command doesn't return to the prompt and it seems it never ends, probably you have an issue with mounted devices
E.
If yes, please:
mount
df
root@vuultimo4k:~#
E.
The mounted devices are the same as in OBH 4.4, with which there is no problem or did not exist until the last update.... until I can try to put OBH 4.4 in OMB using the same devices, and verify that this happens.
I have the same problem on my duo 4k and solo 4k. It is improbable to have the same problem on two stb!
Moreover It is two days that I update my stb (60/70 updates) without a change in the version that Is always obh 5 update 4.
Inviato dal mio CPH2173 utilizzando Tapatalk
004 is current version
We have fixed this, so for the next update either switch to English language, or use telnet.
Afterwards you can switch back to your chosen language.
Hello Ev0
I listened to your suggestion and used telnet and got the update to 4 version :)
Thanks
Hall
