Open BlackHole Online Update
Is there any chance to have in Solo4K fixed the Big PiP issue or the driver problem remains?
After all, it appeared after 4.1.023... It'd be so useful under some circumstances. As already known, it's an issue that does not affect every models (it works in my Duo2 and for sure it works on Ultimo4K and Uno4K).
https://vuplus-community.net/board/threads/big-pip-issue-only-with-the-last-obh-updates.36833/
The driver issue remains, i've not seen that Vu+ ever fixed it.
Pity...
Just out of curiosity and to say a stupid thing: is it totally absurd to use the one in earlier OBH version (prior to 4.1.023) as you coders know which is this driver responsible?
I know it's a stupid idea...
Pity...
Well I can only suppose that Vu+ removed the feature from the Solo4K drivers, for stability reasons (why else would they remove it), so yes it probably is a stupid idea to use older drivers.
Strange: I used it a lot of times without any problems. To be frank, I don't trust vuplus competence in this case... I don't know why ;) It's a true pity, anyway.
By a test I did before and after (multiple zaps made in sequence among the same group of FTA channels) and repeated in order to have an average overall time, I can testify a 22% reduction in the result now with .005.
Con un test che ho fatto prima e dopo (più zap fatti in sequenza tra lo stesso gruppo di canali FTA) e ripetuto in modo da avere un tempo medio complessivo, posso testimonia una riduzione del 22% del risultato ora con .005.
l'altro giorno ho aperto un biglietto dicendo che su duo4k_Se avevo problema di lentezza sui canali sat, openbh-5.0.001
sui dtt ( vu+turbo) e sui canali fta (sat) lo zapping è abbastanza veloce , quindi il problema è sui canali tvsat con card ( io l'ho in locale ) e sui criptati
Quando si fa zapping dal terzo canale in poi sembra che il decoder rallenti è sul display lcd il cambio dell'icona è abbastanza ritardo rispetto al canale
ieri ho installato openbh-4.4.023 , è praticamente il problema è lo stesso lentezza solo nei canali sat non FTA
ALex ho prova a scriverti in ( privato )
Devi aggiornare all 5.0.005 Il problema è stato risolto in questa versione.
The following error occurred
The uploaded file does not have an allowed extension.
Enigma2_crash_2021-12-14_23-01-05.log
