OpenBH 0.6 Vu+ Solo2
Due to some users, reporting to us, that they have still had issue's with online updates.
We have released new OpenBH 0.6 full flash files today (see 1st post of this thread).
There should be no more issue's with online updating now (we hope).
Please remember to do a full backup, before you try to update, just incase you do have issue's.
Thank you, can we use the settings back up from previous update...
FEEDBACK: updated in flash, restore settings and updated on-line and Solo2 is stuck on Strating !
I don't think so because there were no full back up on either USB or Hard Drive.
I will give it another go and will feedback.
I think there may be a problem with settings back up.
1. After update from 38/12/2016 info's
2. Backup setting restored through advance retired menu
3. Info's after backup restore, bit strange it says last updated 18/11/2016
Bit strange but I think I will have to forget about the backup restore settings and start fresh .
it seems something in your backup is corrupting the image when you restore it
I agree with you, I have just fresh installed it, once I've backup everything then I will try to do on-line update... thanks all for your help...
I have refrained from updating to latest image (openbh-0.6-vusolo2-20161228_usb_release_ee76bbf.zip) just to see if I run into problems with my existing image (attached below).
Even after applying all 'Online Updates' I have experienced no problems at all.
Nevertheless, would the advice be to reflash the box to openbh-0.6-vusolo2-20161228_usb_release_ee76bbf.zip ??
if you have done all the online updates and have no issues, then no need to reflash
DO NOT DO AN ONLINE UPDATE OF OBH UNTIL FURTHER NOTICE.
IF YOU DO, YOUR BOX WILL BE STUCK IN A BOOTLOOP
WE WILL INFORM YOU WHEN IT IS OK TO USE ONLINE UPDATE AGAIN
today i update (online) my openbh0.6 and after this i can't reboot tuner. image is freezing on "Your Vu+ Solo2 is rebooting"
Can You fix this ?
