OpenBH 4.1 Vu+ Solo4K
That's a very useful hint for next time, thanks. I suppose by 'almost' you mean that some files can be excluded. Just took a look there and there's a huge epg.dat for example. If you can specify which others can be left out, this will be a precious info for me. :)
Well, in my case, as there is (for instance) the file settings where you can find references to some plugins' configurations, you might have troubles if you copy it in a new image where some of these plugins are not also installed. So, you should install the same plugins you had in the old image before copying.
Be aware that this procedure IS NOT SURE it won't cause any error messages or issues, IS NOT OFFICIAL, is just what I sometimes do if I'm too lazy to rebuild and re-set every personal parameters. As I said, it works for me conditioned to what I said. You should copy in your PC the whole content of this folder before experimenting so that you can replace it if it doesn't work.
But, if it works, you'll find a lot of aspects already set, starting from the tuners configuration.
HI to all and thanks for great job..... I've problem with this image:
You can see below my old post describing a problem with OBH 1.09..... with OBH 4.1 another camera has the same problem.
Summing up:
  • using BH303 or PLI or BH04 I can see every streaming camera - all works fine
  • using OBH 1.09 I've the problem ONLY with ONE camera streaming (see below with reference to original post and example)
  • using OBH 4.1 I've the problem with two cameras in same way
Some help please? I'd like to use OBH but for me is necessary can see the camera streaming
tks in advance
g.
The only problem left for me is that described in post:
http://www.vuplus-community.net/board/threads/problemi-con-flusso-da-telecamera.31307/#post-223727
I try to translate:
I'm trying to see a camera streaming like this :
rtsp://192.168.168.54:554/11
with bh303 or other (example PLI) it works fine but with OBH impossible to see, with last version too
FELLOWS IT MAY BE RIDICULOUS ASKING THIS QUESTION HERE BUT I CAN'T HELP IT FIND SOME PROPER THREADS:
IS IT POSSIBLE FOR THE TEAM OR HAS THE ARM CHIPSETS GOT THE ABILITY FOR AN ANDROID PLATFORM
i mean a hybrid set-top-box that could handle the ANDROID? for example in VU SOLO 4K or in ULTIMO 4K?
In theory it is possible for the chipset to run Android.
But this is something Vu+ would need to do, not the BH team.
thank you Ev0 for the reply but could you please say what is needed for the android project for the start?knowing that the ANDROID is a derivation of LINUX.
hello friends i want to connect my bluetooth headphones to the vu+ solo 4k. is it possible by connecting the vu+ bluetooth 4.0 dongle?does this dongle support the audio stream?or i have to find other ways for connecting my headphones?
As far as I know it is for remote.
so i have to buy it to determine if it works. and as it is so important for me i will.but i think the vu+ company takes it so hard by making every aspect of the hardware and software(eventhough opensource) a mysterious story.i believe the developers' are working so good but for example the vpn . there's is just the openvpn.there is too many other easiest ways.or for the skins and other prohibited things(softcams)there is not a real easy working emu.TAKE IT EASY to the VU+ and to MYSELF.LOL
There are no mysteries here
I have not read anywhere that the vu+ bluetooth 4.0 dongle you can use for audio.
and no exceptions, and discussion about emulators/softcams is here not allowed
Read the rules of the forum
EXCUSE ME for the emulator talking but as everybody know one of the important and easiest functions of a bluetooth device is AUDIO transferring capability(sending and receiving audio)
Not exactly
vu+ bluetooth 4.0 dongle here has a different function.
And so it's advertised.
if you want audio you should buy bluethoot transmitter with optical input
at least I think so with Solo 4K
Beschreibung für "VU+ Wireless USB Bluetooth 4.1 USB Dongle"
Der VU+ Bluetooth Dongle erlaubt die Erweiterung aller VU+ Receiver für die Bedienung mit der VU+ Bluetooth Fernbedienung und macht Sie damit unabhängig von der herkömmlichen Infrarotsteuerung. Bedienen Sie problemlos Ihren Receiver , auch bei verdeckter Aufstellung.
optimiert für die VU+ Bluetooth Fernbedienung
geringe Stromaufnahme
Bluetooth 4.10
Bluetooth 4.1 USB Dongle passend für:
Uno 4K
Solo 4K
Description for "VU + Wireless USB Bluetooth 4.1 USB Dongle"
The VU + Bluetooth dongle allows the extension of all VU + receivers for operation with the VU + Bluetooth remote control, making you independent of the conventional infrared control. Operate your receiver without any problems, even with concealed installation.
optimized for the VU + Bluetooth remote control
low power consumption
Bluetooth 4.10
Bluetooth 4.1 USB dongle suitable for:
Uno 4K
Solo 4K
The best way to use headphones is an HDMI audio extractor and then connect to it any normal headphones, included the wireless ones. This is what I did.
hello friends i want to change the font of my solo 4k what should i do?i have transferred the font.ttf file to the address usr/share/font
to the dear administrator
would you please inform us about the latest updates of this beautifully developed image in this thread or in a new thread UPDATE MONITOR FOR OPENBH?
thank your for the hard work
When is update is see in skin in left side skin; you see grean color .
