OpenBH 4.1 Vu+ Solo4K
no problem ;) from 2 dots i knewed recording and iptv streaming on the right side, but from the other 2 i didn't know till now thx
hello friends i want to change the font of my solo 4k what should i do?i have transferred the font.ttf file to the address usr/share/font
You need to edit the skin.xml file of the skin that you're using.
For example I'm using the Maestra skin, and at the beginning of skin.xml file there is a <fonts> section where regular font is determined as 'tiny.ttf'. You need to change this to 'font.ttf' and restart GUI.
Try it, I think it should work. If it doesn't, revert back to original and ask Matrix10 how to do it. ;)
i installed this . it is Excellent image.you try to solve every weakness that exist in black hole image.and you did it.you exactly knew what did you want.i suprised.thank you.
hello i have the same problem in font of the YOUTUBE titles in persian and in SUBTITLES.
could you please guide me how to change the above fonts?
Hi,
I'm looking for the image OpenBH 4.1.007 release for Solo4k. Can somebody upload to me those release?
Thank You for Ur help.
Regards,
DJWeed
